for the 1sr genners with cb radios
Discussion in '1st Gen. Tacomas (1995-2004)' started by beefcake, Apr 13, 2011.
  1. Apr 13, 2011 at 5:38 PM
    beefcake
    beefcake [OP] J-rob
    J-Rob
    Central California
    98 4WD V6
    Debadged,Deck Plate mod, Helix throttle body spacer, magnaflow two chamber, smoked corner marker lamps, cb radio, smoked headlights, grillcraft mesh grill, URD short throw shifter, ultagauge, billstein 5100 front struts, spidertrax 1.25 spacers on all four
    I was re-routing my cb antenna wire today and making a new mount for it. I looked for the a moment and found an area where no drilling is required. I searched and didnt find anything on this so here you go
    Ran the antenna wire along the top of the frame and ran the wire up through the stock access to behind taillights
    Had to remove the tailights but that was easy 4 bolts and it's off
    then i wriggles the wire through the top of the bed, where the end piece of the bed and the top of the bed meet, there is an opening about a 1/2 inch in diameter,
    fnished, a nice clean look, with no drilling required at least no drilling into your truck for the wires:rolleyes:
  2. Apr 13, 2011 at 5:56 PM
    SpazzyB
    SpazzyB Master of the Prius...
    Ryen
    neuf un six
    '04.5 vw stance machine
    Cool.
  3. Apr 13, 2011 at 5:57 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    Very cool:)
  4. Apr 13, 2011 at 7:48 PM
    jblair
    jblair Well-Known Member
    Colorado
    99 taco 2.7L I4
    lift, big boy tires, deck plate, no more sway bar, painted stuff
    now you tell me
  5. Apr 13, 2011 at 7:54 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    I better add in though to avoid those kinks and crushes and sharp bends-they change the resistance of the coax. Sensitive stuff setting up a transmitter-you need to treat that feedline with gentle hands. OP if you have extra coax laying around I would change out that crushed feedline.
  6. Apr 13, 2011 at 8:17 PM
    beefcake
    beefcake [OP] J-rob
    J-Rob
    Central California
    98 4WD V6
    i dont see where it's crushed:confused: and the radio works
  7. Apr 13, 2011 at 8:19 PM
    52419 Well-Known Member
    someplace
    03 tacoma lifted 6in on 35s
    fabtech 6in lift, 35.12.50.16s,on mt classics
    ran mine to the plastic plug under my carpet and close to the frame and up behind the cab to my antenna on the drivers side of my bed.
  8. Apr 13, 2011 at 8:21 PM
    jblaze805
    jblaze805 Well-Known Member
    Ventura/Fresno, CA
    04 trd pre-runner
    2.5" king coilovers, caburg uca, magnaflow exhaust, aem intake
    good stuff beef.
  9. Apr 13, 2011 at 8:22 PM
    Monkeysuncle
    Monkeysuncle My Cat's breath Smells like Cat Food
    Kevin
    Florida
    99 Tacoma SR5 4x4 5 speed Manual Hubs
    Diff Breather,CB thingy,GPS,Cop Shocks,Cop Brakes, old Man Emu 881's Dakar Leaf Springs and Nitro sport shocks. Deck Plate mod
    I ran my diff breather up behind my lights there. Isn't there something about the length of the coax going to the antenna though?Like coil the excess or dont coil it? I don't know.
  10. Apr 13, 2011 at 8:25 PM
    SpazzyB
    Ryen
    neuf un six
    did the same thing with mine.
  11. Apr 13, 2011 at 8:28 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    Cool if it works but it's got a crush and some slight kinks in the taillight area. Not criticizing just trying to help and offering some old school rule. Sorry.
  12. Apr 13, 2011 at 8:30 PM
    beefcake
    beefcake [OP] J-rob
    J-Rob
    Central California
    98 4WD V6
    No hard feelings and thanks for the advice:thumbsup: if i have any problems thats where i'll start
  13. Apr 13, 2011 at 8:39 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    Just my radio analness <<? poppin through:D mixed with OCD
  14. Apr 13, 2011 at 8:41 PM
    beefcake
    beefcake [OP] J-rob
    J-Rob
    Central California
    98 4WD V6
    haha well im sure you know more than i do, i tuned it with a swr meter and thats about the extent of it, i usually only use it for trails, but it's always on my truck
  15. Apr 13, 2011 at 8:46 PM
    01tacoprerunner
    01tacoprerunner 01 4WD Prerunner
    Brian
    Raleigh, NC
    01 4WD Prerunner
    Ingenuity, i like it man.
  16. Apr 13, 2011 at 8:50 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    Nono-I wouldn't say I know more-I am just a perfectionist when it comes to feedline. I am so glad you mentioned SWR tuning-most folks seem to think CB is plug-n-play. In most cases the antennas for CB are around the ballpark of operatability out of the pkg. but when you actually tune that thing down to get max power to flow down that line and out that whip it is so much better as you know:)
    I digress-good setup there BC-and that line route is clever.
  17. Apr 14, 2011 at 2:50 PM
    jblair
    Colorado
    99 taco 2.7L I4
    DON'T coil it. If you do, it tends not to work, the guy at the truckstop said one guy bought three different CBs in a week saying they were all crap, turns out he coiled his coax. When we installed ours we even avoided sharp turns in the wire.
  18. May 23, 2011 at 8:56 AM
    saundern
    saundern Swerve for nothing
    Nick
    Simpsonville, SC
    2005 TRD Sport
    the bracket that mounts the antenna to your truck, is that custom or did you get it somewhere?
  19. May 23, 2011 at 9:45 AM
    Southern01Taco
    Southern01Taco Well-Known Member
    Sean
    Holden, La
    01 V6 4x4 Xtra Cab SR5
    It looks like its just a piece of angle iron with the corners rounded a little.
  20. May 23, 2011 at 10:10 AM
    Rhino
    Rhino Well-Known Member
    Laurel, Mississippi
    03 TRD SR5 4x4
    gray wire mod, blacked out, debadged, toolbox foglights, cb in dash, system, bilstein 5100's in front wrapped in eibach coils, 5125's in the rear with 2 inch aal and 1 inch shackle, diff drop kit, extended rear brake line, 8000 lb smittybuilt winch on a custom winch bumper, 2 4 inch 100 watt kc's and 2 6 inch 100 watt kc's on the bumper, sometimes a ladder rack,much more to come
    i ran mine under the toolbox then i went over the top of my bed under my bedliner and went in the cab through a vent in the back which opened into the storage compartment under the seat in extended cabs.. sorry no pics.. i had to remove my bedliner to do this tho and get my 5 year old brothers small hands to remove the vent
