for the experts
Discussion in 'Suspension' started by bgbdwlf, Nov 10, 2010.
  1. Nov 10, 2010 at 10:28 AM
    bgbdwlf
    bgbdwlf [OP] Well-Known Member
    surprise,az
    08 PreRunner Off Road
    bone stock for now
    I have gathered my lift components and would like the experts to take a gander and see if I am covered and if I am missing anything that aren't on the list.
    I have a pre-runner so didn't get a diff drop, so here is the list of parts I have put together so far.
    5100's front and back.
    Eibach springs.
    .25 spacer.
    2" AAL.
    SPC/LR UCA's.
    This is the plan, front 5100's @ .85 w/ eibachs, .25 spacer for the lean and UCA's. I know I may not need the UCA's but since I will have the front all apart, I figured do it know instead of having to tear it apart later.
    Out back 5100's w/2" AAL.
    I have all the tools and other need wrenching items so I am covered there.
  2. Nov 10, 2010 at 11:13 AM
    bgbdwlf
    surprise,az
    bone stock for now
    got the longer bolts for the spacer.
    good point i didn't even think about checking the u-bolts.
    are you talking about the center pins in the leaf packs, if so i got those also plus 2 extra.
  3. Nov 10, 2010 at 12:15 PM
    bgbdwlf
    surprise,az
    bone stock for now
    i see what you are saying now, i am only doing the single AAL it looks like you did 3 leaf pack, but i am still going to check the u-bolts and the keepers just to make sure. i only have a 2wd pre-runner and don't offroad much made some trail riding and thats pretty much it.
    for the front 5100's i am working on getting some stock billies that someone as swapped out already. then i can disassemble them to pre-assemble the 5100's and then just swap the sets out and same some time.
  4. Nov 10, 2010 at 1:00 PM
    ToyTec Lifts
    ToyTec Lifts Toyota Suspension specialist Vendor
    Rocky Mountains
    Toyota's are awesome
    Longer top plate bolts are not required for the 1/4 inch spacer. They are for the 1/2 spacer.
    Longer U bolts are not required for the single AAL
    :thumbsup:
    -Dylan
  5. Nov 10, 2010 at 1:07 PM
    bgbdwlf
    surprise,az
    bone stock for now
    sounds good, Thank you everyone for your input. :cheers:
    I have some longer top plate bolts laying around so if do i am covered there. i didn't think i would need the u-bolts but i am going to check just in case.
    X2 for Toytec they hooked me up on my stuff also, except the UCA's (sorry Dylan).
