For those that installed LED dome and map lights, did they cause problems?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by woodsy, Dec 23, 2020.
Did your LED map and dome lights cause problems?
  1. No - I Iove them
    102 vote(s)
    71.3%
  2. Yes - It caused electrical issues
    10 vote(s)
    7.0%
  3. I think they broke my valve spring on the #5 cylinder
    31 vote(s)
    21.7%
  1. Dec 24, 2020 at 12:36 AM
    baldbeardedtaco
    baldbeardedtaco Well-Known Member
    FL
    18 TRD Sport DCSB MGM
    In all likelihood those posts that had electrical issues after installing leds inside the cab are probably installers error. Yes if you leave battery on and lights are powered and you accidentally short the contacts- you will have issues. Either they don’t realize what they did or don’t want to admit it but not being an electrician (me), that seems like a highly likely outcome and common sense. Some will insist on disconnecting battery to eliminate that chance and others, that are aware, will at the least make sure the switch is not on powering the lights your currently replacing. But what do I know
    907rx7 likes this.
  2. Dec 24, 2020 at 3:26 AM
    NJCementaco
    NJCementaco Well-Known Member
    NJ
    2021 Cement TRD OR DCSB
    I have interior leds from tacomabeast, no issues here either.
  3. Dec 24, 2020 at 5:17 AM
    woodsy
    woodsy [OP] Well-Known Member
    Ohio
    2021 Tacoma TRD Sport Premium
    Thanks for all the replies everyone. It seems like they shouldn't be a problem.
  4. Dec 24, 2020 at 5:26 AM
    Travelinman301
    Travelinman301 4 x 4 Fanatic
    Florida
    2018 Blazing Blue Pearl Tacoma TRD Sport 4 x 4 DCSB
    KDMAX-PRO-10.0 Diode Dynamics Sport Fog Lights Morimoto Clear Tail Lights TRD Skid Plate
    deAutoLED installed since 2018...no issues and very bright.
  5. Dec 24, 2020 at 5:34 AM
    Bravo64
    Bravo64 Well-Known Member
    William
    Orlando, FL
    2020 TRD Off-Road
    3rd vote for the iBrightstars. Kit was easy to install. No problems, big improvement.
  6. Dec 24, 2020 at 7:42 AM
    Tallgrass05
    Tallgrass05 Well-Known Member
    No problems with Diode Dynamics LEDs in the map lights, dome, and vanity mirrors.
  7. Dec 24, 2020 at 8:01 AM
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    I installed my own 2 LED panel dome light mod using the OEM lens to maintain the original look.
    I strongly recommend disconnecting the negative battery cable when installing LED dome lights, or pulling the fuse. There have been cases posted on TW where people shorted it out, some just blew a fuse but others caused more serious issues than just blowing a fuse costing hundreds to repair:
    Dome lights won't turn off!
    And turning the switch off will NOT remove the +12V from the dome light socket, I confirmed this with a voltmeter. The Tacoma uses negative switching so the +12V is still there.
    My $12 Dome light mod (and map lights too if you want, you get 4 LED panels and connectors for either):
    https://www.tacomaworld.com/threads/the-12-two-led-panel-dome-light-mod.692649/
  8. Dec 24, 2020 at 9:17 AM
    Mas Olas
    Mas Olas Well-Known Member
    Woody
    10 miles north or 400 miles south of the border.
    2020 Blacked-Out White DCLB TRD OffRoad 4x4
    Swapped every bulb that wasnt already to LED including head/fogs with no problem. I must be a genius.
  9. Dec 24, 2020 at 9:22 AM
    Swervin Ervin
    Swervin Ervin Active Member
    2019 Cement TRD Off Road
    TRD Front Skid Plate TRD Exhaust Black Grille Bezel Badge Blackout Tailgate Letter Insert TRD Pro Shift Knob TRD Pro Taillights MESO Ultimate Dome Light V2 MESO Ultimate Map LIghts MESO Ultimate Turn Signals Glovebox Letter Insert MESO Steering Wheel Logo Cover-Inferno KO'O Gas Cradle OEM Front Bed Rail
    Meso dome and map lights....no problems.
  10. Feb 2, 2021 at 5:45 PM
    TRD Pete
    TRD Pete Member
    Pedro
    2017 Blue Tacoma TRD Sport 4x4
    I'll be the outlier here... I installed the Headlight Revolution interior LED kit and encountered the following issue. When I get out and close my door, I attempt to use the door handle lock sensor and it will be unresponsive sometimes until the interior lights fully dim out. Once they turn off, door handle lock works just fine. Sucks for me living in South Florida since we have heavy rain and sometimes I have to get out and run.
  11. Feb 2, 2021 at 5:49 PM
    Mitch76
    Mitch76 Well-Known Member
    Mitch
    San Angelo, TX
    2021 F150 STX 4x4 5.0
    275/65-20 Cooper Discoverer XLT. Borla XR1.
    I bought the Meso dome and maps and they didnt match. The dome was blue and the maps were white. I gave the dome light away and bought a new one at Autozone and been happy ever since.
  12. Feb 2, 2021 at 6:09 PM
    ClassyTacos
    ClassyTacos National Treasure 3, Times a ticking Nickolas
    Papalote
    Florida
    2017 TRD Sport 4x4
    Stockish
    I did the Meso Map and dome lights and after 2 days I look like the cheese on the bottom of my oven.
    Wish I could say it was my idea, but no internets.
    install vid-- https://youtu.be/2WZbtBZR2x0
  13. Sep 23, 2021 at 7:04 AM
    CPTpatt
    CPTpatt New Member
    Larry
    2010 Tacoma SR5 Double Cab
    I'm really not sure what I may have done. I installed Sylvania LED Map Lights yesterday afternoon and they worked great. Went out to start the truck this morning and both low beams will not function. High beams and fog lights work. Any suggestions.
  14. Sep 23, 2021 at 7:35 AM
    dilbert
    dilbert AI Member
    PNW
    2019 DCLB TRD Off-Road
    Seriously though... Meso dual brightness dome and phillips LEDs in the front for a few years with no issues. Just switched to Meso dual color maps, still no issues.
    Rock Lobster[QUOTED] likes this.
  15. Sep 23, 2021 at 7:41 AM
    #35
    rangers12
    rangers12 Well-Known Member
    West Texas
    Check your fuses, maybe they blew when you installed the lights.
  16. Sep 23, 2021 at 7:46 AM
    #36
    CalcityRenegade
    CalcityRenegade Well-Known Member
    Calgary, Alberta, Canada, Earth
    2023 T4R ORP KDSS
    I do not have the same fob as the automatic models due to having a manual transmission but only issue I ran into was incorrect sizing on the festoon bulbs. The remedy was lightly sanding down the edges to make them fit.
  17. Sep 23, 2021 at 11:38 AM
    #37
    DogStar84
    DogStar84 Well-Known Member
    Northern California
    2021 Off-Road MGM
    AllPro Apex Rock Sliders SSO Slimline Front Bumper Baja Design lite bar 20" Baja Design Squadron SAE fog lites Mountain Hatch Tailgate Rek Gen mud flaps
    I started off with Amazon. Then Went all DD in and out. Much better output and light tone.
    The turn signal LED gave me problems so I went back to incandescent on just that one. This issue is well documented on other threads.
    No one asked but that highest power DD backup light is a gamechanger. recommend.
  18. Sep 23, 2021 at 11:49 AM
    #38
    AZPhys13
    AZPhys13 Well-Known Member
    2021 TRD OR DCLB - MGM
    No problems installing MESO dome and maps but have read about problems when battery is connected or lights are on during installation. Something shorts and leads to other complications.
  19. Sep 23, 2021 at 11:51 AM
    #39
    iblis01
    iblis01 Well-Known Member
    Austin
    2020 TRD ordcsb
    Lots
    Started out with alla leds from Amazon, bright and no issues. I have the 2 color meso dome light now and its without issues. Planning to install the meso 2 color map lights when they arrive.
  20. Sep 24, 2021 at 7:29 PM
    #40
    dalemats
    dalemats Well-Known Member
    dale
    2017 Tacoma Limited 2WD
    2017 MGM Limited 2WD DCSB, bed mat, wheel, spare & tailgate locks, Gen 2 running boards, tri-fold cover, ShiftSense Pro v2, LED interior lights, Bracketeer fire extinguisher bracket, Pop & Lock power tailgate lock,
    Going on 3 years with Amazon leds. No issues and super brightness relative to factory bulbs!
