For those who changed their limited shocks to OR bilstein shocks
Discussion in 'Suspension' started by TacomaIan, Apr 21, 2017.
  1. Apr 21, 2017 at 9:34 PM
    TacomaIan
    TacomaIan [OP] Well-Known Member
    Ian
    Alberta Canada
    2016 Canadian Limted
    Hi everyone- been doing a bit of reading on here on the Limited having the same shocks as the SR/SR5. And seeing many bilstein OR stock shocks for sale, is a guy better off upgrading?
    For those who have changed out the limited shocks for the OR shocks, what can you tell me?
    I drive a ton for work, a more refined highway ride would be nice but tell me if I'm way off?
  2. Apr 21, 2017 at 10:13 PM
    DLTACO
    DLTACO Well-Known Member
    david
    Fraser Lake, BC, Canada
    2016 Limited, BFG KO2 275/75R17, Method Wheels,Rigid Industries Grille with E 20: E-Series
    Work in Progress
    I just made the changer over to BFG KO2 LT 275/70R17 tires along with Bilstein 6112 Series Front Kit and 5160s on the rear and the ride and handling both on and off pavement is excellent.
    lynyrd3 and bobrown14 like this.
  3. Apr 21, 2017 at 10:43 PM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    I have a write up on that
    shakerhood and bobrown14 like this.
  4. Apr 22, 2017 at 12:00 AM
    illogical
    illogical Well-Known Member
    2017 TRD 4x4 OR MT
    My understanding is that the stock TRD OR shocks are "softer" on-road but better off-road. Combing through countless threads here, the 6112 and 5160 setup is the direction I'm leaning and Smitty's write up is on point.
  5. Apr 22, 2017 at 5:08 AM
    dsixnero
    dsixnero Well-Known Member
    Dan
    2016 Tacoma TRD Off Road White
    None yet
    I have an OR and would say the shocks are soft and it really helps with the crappy NJ roads but it leans on cornering and reminds me of a 2nd gen Dakota, I've come to like it and understand why they use them for off road.
  6. Apr 22, 2017 at 8:10 AM
    acemastr
    acemastr Well-Known Member
    Aaron
    Tampa, FL
    2016 Tacoma Limited 2WD AT
    OVTune
    Just changed my Limited shocks to Bilstein 5100's... night and day difference in how it drives, so much nicer, flatter, smoother, more stable.
    bobrown14 likes this.
  7. Apr 22, 2017 at 9:47 AM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    I just swapped out the rear Hitachi OEM shocks for 5100s. I should have the front done by next week's end.
    I have to watch the vid a few more times...then grow the balls needed to take on the job.
  8. Apr 22, 2017 at 9:52 AM
    bajatacoguy
    bajatacoguy Well-Known Member
    Johnny
    RI to NH
    Blk Taco
    OEM: Bed Mat Roof Rack Tri-Fold Tonneau Cover Door Sill Protectors KO2's Dobinson GTS Suspension TRD Beadlocks Timbren Bump Stops SPC UCA Rear SuperSpring SSO Slimline Winch Bumper SmittyBilt x20 Mobtown Sliders Mobtown Front Skid Avid Basket Bed Rack DECKED Draw Organizer Total Chaos Bed Stiffners Relentless Fab Bed Corner Tie Downs CBI Ditch Light Brackets ARB Dual Compressor Instant Air Tank Smittybilt RTT Road Shower II Indel-B Fridge/Freezer w/ Slide Ironman 4x4 Insulated Fridge Case Redline Tuning Hood QuickLIFT Yo_Hec - Center Console Molle Little Johnny III CB Radio KB Voodoo Flashlight Kit Switch Pro 8100 BlueSea Fuse Pelfreybilt Fuse Panel Mount Gecko - LED Bed Lights Gecko - LED Hood Lights Raptor Grill Lights Cali Raised - Bed Flag Pole Holder Center Console Tray & Organizer Weather Tech Floor Mats Weather Tech Hood Deflector TRAILER BUILD HAPPENING! Plate: Negan
    So you switched from Limited to OR shocks?
  9. Apr 22, 2017 at 9:53 AM
    smitty99
    Scottsdale
    My write up for 6112s should be similar Steps
    9th[QUOTED] likes this.
  10. Apr 23, 2017 at 2:52 PM
    bobrown14
    bobrown14 Well-Known Member
    Bob
    Philadelphia
    Gen 3
    bunch of stuff - Bro Pro style
    ^^^ That or Smitty99's setup too.... Want to ditch the lean get 885 springs up front and Progressive AAL's for the rear and that will give you about 2" lift.
    The 5100s are similar to the OR Billy's as far as valving... softer smoother ride on and off road. Change out the front springs and AALs tighten everything up quite a bit without adding any harshness to the highway ride.
  11. Apr 23, 2017 at 2:54 PM
    CanadaToy
    CanadaToy Well-Known Member
    Greg
    Toronto
    17 DCSB TRD OR Alpine
    TRD Pro grille & skid, OEM tonneau and roof racks
    My OR drives pretty well. I like the feel of the stock suspension, much more than my old TRD sport suspension.
  12. Apr 23, 2017 at 5:03 PM
    9th
    Smitty
    Tropic of Cancer
    Thanks!
  13. Apr 23, 2017 at 7:47 PM
    TacomaIan
    Ian
    Alberta Canada
    Perfect. I had a '12 TRD Sport and it was ok but I find the 2016 limited shocks are a bit lacking in soaking up bigger bumps on rough roads
  14. Apr 24, 2017 at 7:17 AM
    brich999
    brich999 Well-Known Member
    Bryan
    16 Tacoma TRD Sport AC
    all tore up already
    Limited should have the same blue hitachi junk my sport came with. Ride with an empty bed was terrible especially in the rear. I 2nd (or like 8th) the 6112/5160 combo. Rear shocks are quick and easy but the front is a fair amount of labor. If i was doing it or paying for it i wouldnt be installing slightly better oem junk. Reason so many or shocks for sale is because they arent that great but probably slight improvement over hitachi
    smitty99 likes this.
  15. Apr 24, 2017 at 11:03 AM
    TacomaIan
    Ian
    Alberta Canada
    Limited has black shocks like the SR/SR5
  16. Apr 24, 2017 at 11:10 AM
    brich999
    Bryan
    all tore up already
    Huh. I did suspension on someones 16 sr-something and it had same blue hitachi junk my sport did. Either way oem is oem. Thats the reason so many selling them wether or, sport or whatever those black ones are. Point being you are probably looking at 4 hours plus to do shocks all around. Most shops going to get 350+ for that job. I wouldnt cheap out on parts that are a pita to replace. 5100 are a very affordable setup, think i paid just under 1k shipped for my 6112/5160 combo but mine is technically for 2nd gen
  17. Apr 24, 2017 at 11:19 AM
    Larueminati
    Larueminati Well-Known Member
    Western MA.
    2013 DCSB TRD 0FF-ROAD
    Getting rid of the factory bilstein's on my OR and taking off the sway bar were some of the best things i've done, although I had both for 70,000 miles. Instantly got rid of that stiff ride, love it now.
    Hoff likes this.
  18. Jun 30, 2020 at 5:53 PM
    abhamber
    abhamber Well-Known Member
    Aman
    Alberta, Canada
    2018 BBP Tacoma TRD Sport DCLB
    How was the ride after you only swapped the rears? I'm considering the same. Was it much stiffer?
