for those who have installed an aux. tranny cooler....
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacomaman06, Mar 30, 2011.
  1. Mar 30, 2011 at 3:51 PM
    tacomaman06
    tacomaman06 [OP] Carolina Alliance: Enforcer
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    did you bypass the radiator...or go ahead and keep it as is and run thru it? im getting a cooler soon, and im probably gonna keep it ran thru the radiator as is now(yeah....no tow package on my truck), but i figured i'd see how ya'll did it.
  2. Mar 30, 2011 at 3:56 PM
    98tacoma27
    Ben
    Not Beech Creek
    Just a thought Will, but if the bypass the rad you eliminate the risk of the coolant getting into the tranny should the rad fail. That's a rarity in happening so it's just a small plus for bypassing it.
  3. Mar 30, 2011 at 4:04 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    this is very true.....
  4. Mar 30, 2011 at 10:34 PM
    Hambone155
    Hambone155 Well-Known Member
    omaha
    Causing Butthurt is my job
    port and polish intake manifold, supercharger, pulley for charger, lifted, tires, deckplate, (doing full engine build)
    ive actually been doing alot of looking into this chris anddddd this might be the only time i ever help you instead of me.
    what im going to do is is split the lines cap the lines and mount a new cooler with an electric water pump and fan in my spare tire spot. or on the tire gate im going to make.
    you could do it for under 200 and it will be kick butt.
  5. Mar 30, 2011 at 11:41 PM
    Hambone155
    omaha
    my bad i thought it was chis's post.
  6. Mar 31, 2011 at 8:25 AM
    brs127s
    brs127s Well-Known Member
    O'Fallon, MO
    04 D-Cab 4x4 Limited TRD
    TRD Headers, Aero Turbine AT2525XL Deckplate Mod, TRD tranny cooler, King Coilovers, LR UCAs, Alcan 5 Leaf springs and Bilstein 5100s, Shrockworks front bumper, CBI rear bumper.
    I got a steal of a deal on a TRD cooler and just hooked it up as directed. I can't remember if it hooks in after the tranny fluid goes into the radiator or before. Regardless, my tranny fluid still goes into my radiator.
  7. Mar 31, 2011 at 12:53 PM
    TacoTaro
    TacoTaro Well-Known Member
    Los Angeles
    04 DC 4x4
    King Coilovers, Light Racing UCA, OME Dakar leafs w/ extra leaf and SB10" Bilstein 7100's and a U-bolt flip. 4.56's, eLocker rear, ARB front, Marlin rear bumper, ARB Bull Bar w/ Warn M8000. BAMF Sliders. Manual hub conversion with functioning ABS. Tundra front brakes. Manual hub conversion with functioning ABS. SCS F-5's w/ 255/85 Toyo MT's
    I bypassed the radiator. Used a Trucool. Coolant temp is about 190. That is too hot to be an effective trans cooler. Plus the strawberry milkshake threat is there.
  8. Mar 31, 2011 at 1:18 PM
    vantaco
    vantaco Well-Known Member
    02 Taco Xtracab TRD Step Side
    definetly bypass it...the only benefit of having it run through the rad would be to help warm up the tranny oil possibly....but i'd think the tranny would warm up before the engine coolant anyways
  9. Mar 31, 2011 at 6:44 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    Anyone wanna elaborate on the "strawberry milkshake"deal?
  10. Mar 31, 2011 at 6:51 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    Ah.....I see. I'm prolly gonna install the cooler and run it as is now and keep it going thru the radiator. It's probably few and far between on milkshake incidents anyway. I keep my radiator clean....so unless something rupture one of the lines at some point....I should be good to go.
  11. Mar 31, 2011 at 9:27 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnuson MP62 Supercharger w/2.37" Pulley Haltech Elite 2000 Standalone ECU Denso 650cc Fuel Injectors Doug Thorley Headers Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Magnaflow Hi-Flow CAT, Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    I think there are some advantages to running thru the radiator, especially in colder climates.
    According to my scangauge, the water temps come up to running temp well before the tranny fluid temps do from a cold start. Under these circumstances, it would seem as though the radiator is actually helping.
    Again, according to my SG, in normal road driving the radiator alone is enough to keep the TF temps reasonable. The real advantage for the external cooler is in severe conditions. Low speed wheelin on warmer days is the only time I've seen the TF temps exceed the water temps.
    Not sure if there are long term implications if the tranny fluid is lower than its ideal running temps. Not even sure what those ideal temps are.
  12. Apr 1, 2011 at 5:38 AM
    turtletaco
    turtletaco Active Member
    VA
    01 SR5 XCab 4x4 Manual, 2021 SR5 4x4 DCLB
    Not sure about what parts are the same across the trucks but if you search the 4runner forums the milkshake is a common problem on the 3rd gen models.
    Haven't had much time with my truck but preventitive mods are on my list.
  13. Apr 1, 2011 at 5:57 AM
    magog45
    magog45 Well-Known Member
    Canada, just south of Santa
    98 tacoma 4x4 extended cab
    5100's all around, 2.75 inch lift, polyurethane body mounts, gibson exhaust, variation of the deckplate mod, intake resonators removed 285-75-16 goodyear AT
    Having installed tranny coolers on most of my vehicles including a class C motorhome I always run the lines into the auxillary cooler first and then into the radiator. If you do it the other way you will transfer a good deal of the heat from an overworked tranny to the engine coolant and not using the radiator at all would mean a pretty large tranny cooler would be required and you lose the ability of the engine coolant to bring the tranny up to its proper operating temperature, something important for proper shifting and simple survival of the tranny, at least her in the frigid north.
  14. Apr 1, 2011 at 11:04 PM
    TacoBlitz
    TacoBlitz Well-Known Member
    Jake
    Omaha, Nebraska
    01 DoubleCab SR5 TRD, white
    Topper, Yakima Racks, Yakima Loadwarrior roof basket (lights all around) 20% window tint (all 4 doors), Spectre ProFab Air Intake System, Black grille, Rino Lined rocker panels, rear bumper and flares Suspension: New OME 881 coils and OME 5 leaf rear springs, Blilstein shocks and struts, Daystar Greasable lift shackels Extended rear brake line
    Has anyone really ever had problems with their tranny overheating on a tacoma? I have been thinking about getting a cooler also because I do some towing on occasion and am just wondering if it is a common problem with our trucks
  15. Apr 2, 2011 at 7:33 AM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    I blew the intermediate clutch pack out of my A43D auto in less than 100miles @ 12psi. Too much slippage and heat.
    Im running the biggest trans cooler summitracing has available. I welded a temp bung in the pan, but I havent driven the truck to know what my temps will be.
  16. Apr 2, 2011 at 7:41 AM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    I would run through the radiator as in the winter it would take too long to heat up the trans fluid and delay shifts, I also think that by leaving it hooked to the radiator the cooling effect would be more efficient useing both especially in the summer!
  17. Apr 2, 2011 at 10:58 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    Bats how I'm looking at it as well,Tom.
