For those with After market UCA's (Camburg, TC, All Pro)
Discussion in 'Technical Chat' started by chris4x4, Feb 15, 2009.
  1. Oct 23, 2009 at 4:51 PM
    trd sport
    trd sport Well-Known Member
    queens,ny
    07 double cab trd sport
    So Chris4x4, are you saying to use a petroleum base grease for the upper bushings (red on totalchaos) before the installation of the long bolt and the dry lube only on the uniball?
  2. Oct 23, 2009 at 4:55 PM
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Use the recomended Grease. I have had good luck with the Mobil 1 synthetic grease. Use only a dry teflon lube on the Uniball.
  3. Oct 23, 2009 at 5:02 PM
    Sandfire
    Sandfire Well-Known Member
    southwest midwest
    06 TRD Sport DC 4x4 silver
    OME 885 springs with OME N140s shocks, Total Chaos UCA's, TSB AAL, OME N182's, MT BAHA ATZ 4ribs.
    Hey, I'm glad this resurfaced! I did use mobil 1 red synthetic grease when I assembled my bushings (still need to pump some in through the zerks) but I did nothing to the ball joints. Can this dry teflon lube wait awhile?
  4. Oct 23, 2009 at 5:25 PM
    06Bluez
    06Bluez Well-Known Member
    Phoenix, Arizona
    06 4x4
    Icon Coil-overs, TC UCA, with Bilstein 5150 and Icon 3 leaf pack. 17" Moto Metal 951 4.5" Backspacing wrapped in 285/70/17 BFG AT's. Demello front bumper and Avid offroad sliders.
    Chris4x4!!! What lube did you use on mine???
  5. Oct 26, 2009 at 1:15 PM
    06Bluez
    Phoenix, Arizona
    06 4x4
    Uh oh no answer. must be bad.
  6. Oct 26, 2009 at 1:17 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I didnt see this. :eek: I used a Dry spray lube made by CRC, iirc. :)
  7. Oct 27, 2009 at 11:20 AM
    06Bluez
    Phoenix, Arizona
    06 4x4
    you the man! :D
  8. Oct 27, 2009 at 11:24 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Are your UCA's still nice and quiet?
  9. Nov 9, 2009 at 6:21 PM
    dysfunctnlretard
    dysfunctnlretard Hi
    Manny
    CA
    2010 FJC
    55w HIDs, 16" Countersteer Offroads, Yokahama All Terrains, Demello Sliders
    Squeeks are coming back, this time from the uniball I think. I dont have to take anything off the truck to lube the uniball right? Just drop the stuff right in after I spray it down with some water and get the surface dirt particles off?
  10. Nov 9, 2009 at 6:26 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Make sure its from the uniball. SPray them off, and spray a liberal amount of teflon dry lube on the top.
  11. Apr 15, 2010 at 8:33 AM
    knickerbocker
    knickerbocker Well-Known Member
    middle
    '07 Indigo 4.0l 4x4
    the leading minor of order 1 is not positive definite.
    i wish i had seen this about 10 months ago. i got my tc ucs's used and i don't know what the guy before me did, but when i put them on my truck people on here were saying any ol' spray lube works great. so i've done that five or six times in the last 8 or 10 months. so is the damage done? how do i know when they're totally gone? should i do anything before i switch to dry lube, like try to "flush" the uniballs out or anything? also, is the cup replaceable if it does get ruined?
    does this address the same thing as pumping grease in the zerks? where "in the bushing" should i be pumping grease? thanks.
  12. Nov 3, 2010 at 3:53 PM
    stillar
    stillar Member
    Adam
    Ontario
    2002 trd
    Elite Fab front bumper, 6" fab tech lift,deck mod, rear diff ext, warn winch m8000, Looking for Ideas on rear Bumper
    Should I use dry lube on Built right UCAs as well
  13. Nov 3, 2010 at 4:00 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You should have grease zerks. And if the uniballs are worn, they will be loose. If they are, you can replace them. Wheelers off road sells rebuild kits for the TC UCA's.
    Yes.
  14. Nov 3, 2010 at 4:07 PM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    2006 Toyota 4Runner SR5 V8
    So, you are saying that liquid lube will hurt your balls.
  15. Nov 3, 2010 at 4:12 PM
    #35
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yes. :cool:
  16. Nov 3, 2010 at 4:14 PM
    #36
    JDMcQ
    Warning duly noted.
  17. Jun 5, 2012 at 10:16 PM
    #37
    RDtres
    RDtres Well-Known Member
    Albuquerque
    2012 Tacoma DC LB
    What about icon uca's? Thx
  18. Jun 5, 2012 at 10:21 PM
    #38
    KenLyns
    KenLyns 8-in. Third Member
    Belly of the Beast
    4x4 TRD Off Road Full-Auto
    All-Pro Bumper, CBI Sliders, Icon Coilovers, BudBuilt Skids, aFe Intake, Icon VS Rear Shocks, Timbren Bumpstops, All-Pro UCAs, JDM Steering Wheel, ViAir Compressor, Klearz LED 3rd Brake Light, Pop-N-Lock Tailgate Handle, Husky Front Flaps
    All the uniball UCAs should receive only dry lube on the uniball. Icon, TC, Built Right, whatever.
  19. Jun 5, 2012 at 10:28 PM
    #39
    KenLyns
    Belly of the Beast
    And if you want the absolute best uniball bearings, look up Kamatics PN KR16-CN (1.00") or KR20-CN (1.25"). They replace the teflon-impregnated cloth liner with an injected polymer liner.
  20. Jun 6, 2012 at 1:51 PM
    #40
    RDtres
    Albuquerque
    2012 Tacoma DC LB
    @ Ken. thx for the input. What would you recommend to clean up the grease after the fact. I just installed my Icon UCA setup an put very little grease coating on the uni-balls. I'd like to get it cleaned up and spray with a dry-lube. Thx
