For those with KMC Enduro Wheels......
Discussion in 'Wheels & Tires' started by Murphy, Oct 12, 2010.
  1. Oct 12, 2010 at 3:54 PM
    Murphy
    Murphy [OP] Member
    I just installed KMC Enduro wheels for my 5 lugger Tacoma today. Pictures will be posted soon. They came with Acorn style lug nuts from Tire Rack, and the mechanic had a tough time putting them on. He kept hitting the inside of the area where the lug nut was installed. They scratched up rim by the area of the lug nut, but it is not a big deal as the lug nut now covers it up. He said that to get them off I now need to buy a Breaker bar with a thin wall socket, or the lugs will not come off. A solution was to use tuner lug nuts, but I stayed with the acorn lug nuts. For the people with the KMC Enduro wheels, what did you do? Is there another size lug nut (perhaps longer) that will work better?
    On a side note, I went with a 15X7 rim, and to be safe a 235/75/15 tire, and the tires still rub the fender when I turned the wheels. I needed to cut the fender and remove the black box and it seems to be ok, I just have not tested it with a really tight turn yet. Do any one else have this issue? I thought I only needed complete the black box mod if I went with a 30X9.5X15.
    Thanks for the time.
  2. Jul 20, 2011 at 9:34 PM
    WYOTAC
    WYOTAC Well-Known Member
    Joel
    Santa Barbara
    06 AC TRD OffRoad Desert Sand
    ICON 2.5 with JBA UCA, OME Dakar
    So does anyone have a solution for this? it is true - the thin walled socket is very tight getting on the lugs and if there are any dings on the lug the socket will not slip on.
  3. Jul 21, 2011 at 4:00 AM
    berry79
    berry79 Well-Known Member
    Homestead, FL
    08 DBL Cab LB
    Gorilla splined ET lugs
  4. Jul 21, 2011 at 9:06 PM
    WYOTAC
    Joel
    Santa Barbara
    Awesome... That's the kind of answer I was looking for.
  5. Sep 2, 2011 at 7:11 AM
    Taquito401
    Taquito401 Member
    Dan
    RI
    '11 RC MGM
    Guys,my advice fwiw is stay away from any spline nut thats is FEMALE. Because they are very thin walled and youre torqueing them from the inside,they like to split or crack. If youre VERY lucky,you can get the nut out. More often,the nut splits and is jammed up in the tiny space it occupies...bad for business. Best case scenario there is you destroy a rim or one lug itself. Easy to remember,and good advice for life....FEMALE BAD,MALE GOOD
  6. Dec 19, 2011 at 11:49 AM
    chingy
    chingy Well-Known Member
    2006 2.7 tacoma 5 lugger
    Murphy-should I get the 16x8 enduros for my 2006 5lug or 15x7?
  7. Dec 19, 2011 at 11:54 AM
    Hiatt1991
    Hiatt1991 Well-Known Member
    Hiatt
    Ventura, CA
    2022 Toyota Tacoma SR5 DCSB 4x4
    4" Bodylift 20" Offroad shock spacers Turbo Encabulator
    I used standard acorn lugs and got a normal torque ratchet and losten or tighten them that way. I just use a standard deep socket.
  8. Jan 7, 2012 at 11:27 AM
    dand
    dand You can't see me
    Dan
    SE VA
    2021 DCSB TRD Sport Army Green
    Did not have this problem.I used white knight splined acorn nuts that come with their own socket.Worked and look perfectly.
