For those with the new trd cold air intake or K&N cold air intake
Discussion in '3rd Gen. Tacomas (2016-2023)' started by huskert, Dec 2, 2016.
  1. Dec 16, 2016 at 1:12 AM
    faultball
    faultball Well-Known Member
    WHT2017SR5DCLB2WD
    Usually cold air intakes should be taking in "cold air" from outside or have some kind of box to keep hot air separated from intake.
  2. Dec 16, 2016 at 6:08 AM
    BadKitty
    BadKitty Well-Known Member
    Indianapolis
    2017 Black Tacoma TRD-offRoad 6spd
    TRD Intake, TRD exhaust
  3. Dec 16, 2016 at 6:22 AM
    Nirvana
    Nirvana Tesla Auto
    Kris
    Morgan Hill, U.S.A
    2006 Off Road 4X4
    Icon ext. travel 2.5RR in front, Icon ext. travel 2.0RR in rear, BuiltRight uniball UCAs, Wheelers Superbumps, Goodridge steel braided brake lines, BruteForce front plate bumper w/ Warn M9000+synth line, American Auto Horns ACDF, Pelfrey Bussman mount+Sandman bussman fuse block (soon), 255/75R16s on painted stockers...because I'm not paying $800 to rock rash new wheels you scrubs. Shok Industries 2/0 big 4 upgrade and sound deadener.
    And the companies also claim X HP, Y Torque Gains!!! while the little writing on the bottom says, "Results not normal". Compare your previous vehicle intakes to the one on your Tacoma. If you're already drawing air from outside of the engine bay you're drawing cold or cooler air rather than the hot air trapped in the engine bay and that's more or less the theory. No need for a fancy box or foam filter.
    As an aside, be aware of any sensors downstream of the air filter if you switch to an oiled filter like a K&N as they can cause performance issues if over oiled and that oil coats the electronics. Furthermore seeing any gains with those kinds of filters is because they aren't filtering to as small of a micron level as a paper filter would. As long as you're okay with potential engine damage, as unlikely as it probably is, then go for it.
  4. Dec 16, 2016 at 6:36 AM
    BadKitty
    Indianapolis
  5. Dec 16, 2016 at 6:41 AM
    Taco Addiction
    Taco Addiction We found Jimmy
    Houston, TX
    2004 Black TRD Offroad
    Kings, SCS Wheels and other mall crawling crap
    Uhh...got it.
  6. Dec 16, 2016 at 6:55 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    Well said
