For those with URD intake....
Discussion in 'Performance and Tuning' started by tc2008, Sep 14, 2008.
  1. Sep 14, 2008 at 10:29 PM
    tc2008
    tc2008 [OP] Well-Known Member
    Garden Grove, CA
    06 Speedway Blue
    8000K HID light, LED map and dome light, cluster + AC blue, Camburg 2.5 front and rear, Deaver 10 Packs. Satoshi Grille, Eyelids, Carbon fiber hood w/ scoop, BHLM, 285/75/16 km2s, KMC enduros
    Hey guys, I don't know if it just my engine problem or is it my intake problem but I noticed since I put that intake in my engine fails on me 3 times already (this happens after 24hrs I put the intake in) but yea the first time it fails on local street, second time on Freeway SCARED THE SHIT OUT OF ME!!! THIRD TIME WAS TODAY WHEN I WAS MAKING A RIGHT TURN and the engine just shuts down and my steering wheel was frozen thought i was heading straight for the other car that was waiting for left turn.
    So anything I can do about this?? I don't know if its the effect of the intake or the sensor since I didn't solder like the instruction told to, or is it that I haven't installed the MAF calibrator yet?...please, I need help quick!!!
  2. Sep 15, 2008 at 5:27 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    maf cal has nothing to do w/ it. are u getting a CEL? its more than likely b/c u didnt solder the connections. how did you connect them? wirenuts, twist and tape...etc?
  3. Sep 15, 2008 at 7:34 AM
    tc2008
    Garden Grove, CA
    06 Speedway Blue
    yea just wirenuts, twist and tape, so that is my main reason?
  4. Sep 15, 2008 at 7:47 AM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    I bet it is because you didn't solder. You should solder them right away before any corrosion starts starts forming on the wires.
  5. Sep 15, 2008 at 8:28 AM
    tc2008
    Garden Grove, CA
    06 Speedway Blue
    I don't know how to solder that's the problem...
  6. Sep 15, 2008 at 8:54 AM
    Hotdog
    Hotdog
    Wet Okole Underwear
    it is pretty easy.
    First: Slide the heatshrink onto the wires.
    Second: Look at my attached picture and do one wire at a time
    Third: Get a soldering iron and some electronic solder (NOT the plumbing stuff)
    Fourth: Heat the back of the wires with the solder.
    Fifth: Feed the solder into the front of the wires (opposite the soldering iron)
    Sixth: You want the solder to be drawn in fully. You should still be able to make out the wires when you're done.
    Seventh: Mash down any sharp edges from the wires protruding and slide heat shrink over the connection. You can use a cigarette lighter to shrink the tubing.Wire Connections.pdf
  7. Sep 15, 2008 at 8:58 AM
    The_Hodge
    SC
    if u dont wanna get fancy, just get a roll of solder from autozone, advanced, etc and a cigarette lighter. roll out about 6" of the solder, heat it up w/ the lighter til it melts up, then quickly touch that to the wires that are twisted together....then wrap them in electrical tape afterwards. easy to do.
  8. Sep 15, 2008 at 9:15 AM
    Hotdog
    Hotdog
    Wet Okole Underwear
    This will probably work fine, but your best connections will come from the wire being heated first.
  9. Sep 15, 2008 at 12:50 PM
    SoCalTacoma
    SoCalTacoma Well-Known Member
    I bet its your connections. Twisting wires and taping does not work. if its a loose connections theres no signal from the maf.
