Forced Induction Exhaust Setups & Discussion
Discussion in 'Performance and Tuning' started by Flake Boost, Mar 24, 2020.
  1. Apr 29, 2020 at 10:13 AM
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    I know few guys with bungs on both banks seem to have issues with their afr sensors shitting the bed. I have mine just past the merge and have had no problems. I suspect the sensors get cooked when they are more upstream.
  2. Apr 29, 2020 at 10:25 AM
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    What are you using the truck for?
    If I had a boosted X-Runner for track (high rpm all the time) I would try the 2.5" y-pipe.
    For most, 2.25" (what I use) is a good size as it keeps exhaust velocity up at lower rpm without choking flow at higher rpm.
    After the merge I run 3".
    2.5" will have impact on high rpm flow.
  3. Apr 29, 2020 at 10:27 AM
    Roostfactor
    TX panhandle
    Why I use finned bungs!
  4. Apr 29, 2020 at 11:03 AM
    TodayWasTHeDaY
    Russ
    Calgary
    That attention to detail is why your y-pipe has the reputation it does!
  5. Apr 29, 2020 at 11:06 AM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    Thats why I am checking with all of your guys. I would have you build me a Y but being in CA I am trying to keep it as close to CA legal as I can so the cats stay.
    Flake Boost[OP] likes this.
  6. Apr 29, 2020 at 11:08 AM
    nudavinci64
    Robert
    ok that makes sense the 2.5" was an idea but wasn't sure it was needed or not. So from cats into merge keep at the 2.25" then run 3" back? I am sure crank wise it will be close to 400hp when all said and done. Also trying to future proof it some.
    It won't be a track truck, Its a off road rig/daily truck to some degree.
    Sounds like keeping the Y at 2.25" is the way to go.
  7. Apr 29, 2020 at 12:21 PM
    Roostfactor
    TX panhandle
    Much appreciated! :hattip:
  8. Apr 29, 2020 at 12:40 PM
    Roostfactor
    TX panhandle
    So you are welding factory cats to the JBA headers?
    Then also keeping stock rear cats?
    If so I would use 2" od tubing until aft of last cat. Then transition to 2.25" to merge collector.
    You want to minimize dimensional differences such as going small big small big on tube size. It makes the exhaust have to speed up, slow down, speed up, etc. Not efficient.
    Look up Bernoulli's principle.
    @nudavinci64 pm me if you want my # so we can chat about this.
    Torspd and Flake Boost[OP] like this.
  9. Apr 29, 2020 at 1:37 PM
    nudavinci64
    Robert
    Ill wrap up and we can chat. I figure yes ill be keeping all cats as needed here in CA.
  10. Apr 30, 2020 at 8:43 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Here's my 4 banger
    URD s/c stage one (~8.5lbs boost)
    MAPECU3
    5th injector
    LCE header
    URD midpipe
    Stock catback
    LCE lightweight steel flywheel
    SPEC stage 2+ clutch
    5.29 gears
    295/70/17s
    https://m.youtube.com/watch?v=pjTkBEwr_Ag
  11. May 11, 2020 at 7:12 PM
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    Yup! That’s what I got. But it would be interesting to see comparison dyno graphs between a 2.25 and 2.5. And show the high and low rpm flow differences
  12. May 11, 2020 at 8:06 PM
    Roostfactor
    TX panhandle
    Absolutely!
    What we would be looking for is velocity rate as a larger diameter would decrease velocity.
  13. May 18, 2020 at 11:48 AM
    findingthingsout
    findingthingsout Well-Known Member
    midwest
    08 Tacoma TRD O/R A.C. MT
    Boost, armor, lights, big tires, no savings.
    Has anyone used the catless afe y pipe? It has 2.5" runners and a 3" merge collector. Wondering if it hangs low, or has interference issues with skid plate. My DT pipe bomb is falling apart and want to upgrade with less restrictions. JFR is obviously the most desired but not in budget at this time.
  14. Jun 1, 2020 at 11:41 AM
    findingthingsout
    midwest
    Will be installing URD headers and catless Y pipe. Any tips on running a cat in the cat-back? I currently have a home built 3 in cat back with 2 vibrant resonators and a cheap Thrush muffler. Been dreaming of a side exit through the fender in front of the passenger side rear tire. I think I will have to swap a res for a cat to squeeze it all in.
    Suggestions/ experience on 3"in/3" out catalytic converters.
  15. Jun 1, 2020 at 12:00 PM
    #35
    Roostfactor
    TX panhandle
    I use Magnaflow 59959 3" metal spun cats.
  16. Jun 1, 2020 at 12:57 PM
    #36
    findingthingsout
    midwest
    I believe the AFE headers use Magnaflows. I think they suffer the high temps of boosted applications. Is the temp drop by the time the gasses reach the cat back section diminished enough to make these last? I will probably install with V-bands so I can swap out ever 20k mi. when the elements begin to fail.
    How many miles have you ran the magnaflow?
    TodayWasTHeDaY likes this.
  17. Jun 1, 2020 at 1:36 PM
    #37
    Roostfactor
    TX panhandle
    I run them post y-pipe.
    I have seen one fail out of probably 20 installed.
    I cant vouch for everyone but I have only seen the one failure.
    Cats require a break in procedure to seat the substrate to the case.
  18. Jun 1, 2020 at 7:58 PM
    #38
    findingthingsout
    midwest
    A break in? Tell me more, please. A sequence of heat cycles?
    I assume the failures I experienced, both cats in the twisted steel headers, were from the increased heat of boost. Do you think the location of the aftermarket cats makes that big of a difference? I ask since you are running further down stream.
    Are there any other rules of thumb that I should follow? Like, depending on how I orientate my set up, is it plain stupid to install a cat between a resonator and Muffler?
    Also, If I am at 3" from the Y pipe collector back, how critical are bends? If I can get a side exit through the fender to work, it will be with a couple extra bends. Assuming I will never be over 400HP. Hoping that if I am a bit oversized I can be a little more creative with getting around the frame and out. I have only found some first gens that were able to get the fender exit. I may be pushing it...
  19. Jun 2, 2020 at 12:06 AM
    #39
    Roostfactor
    TX panhandle
    A quick youtube search can explain the process better but basically you have the main material (ceramic or metal spun) substrate but it needs a seal between the cat material and the metal casing.
    Breaking it in (dont quote me on this) is like running at idle then maybe a bit higher rpm in neutral, then let the cat completely cool.
    Then it's broken in!
    There is basically a one time expandable media between the cat substrate and case.so you need to heat it to allow it to "seat" then cool to allow it to set.
  20. Jun 2, 2020 at 12:15 AM
    #40
    Roostfactor
    TX panhandle
    Yes, the closer to the heads the cats are will heat them up significantly.
    Exhaust:
    The importance of exhaust components in order (traditionally) is S follows from most important to least
    Headers
    Y-pipe (my application effectively extends the headers into a more efficient system)
    After y-pipe. With 3" mandrel bends your flow will be fine.
    Most of the gains are near the engine where we take advantage of scavenging.
    Torspd and findingthingsout like this.
