Forced Induction Exhaust Setups & Discussion
Discussion in 'Performance and Tuning' started by Flake Boost, Mar 24, 2020.
  1. Apr 20, 2021 at 11:36 PM
    #61
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I would dual it into an X that turns into a Y right before it hits the muffler if you can. Perhaps you can replicate the sound of mine if you like the way mine does. Just an idea!
  2. Apr 20, 2021 at 11:39 PM
    #62
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    yah well see what's up. I will let him do his magic. I did not have it done last week when I was there as he did not have all the stuff and rather do it right and setup a "bitchin"setup as he put it. He could welded up quick but that would not be something we would be proud of hahahaha but it will happen. Your truck is sounding good.
  3. Apr 20, 2021 at 11:46 PM
    #63
    12TRDTacoma
    Rob
    Concordia
    Boosted
    If I was to stick to a single without all the stuff I added I totally would had done the setup I mentioned to you for sure. Thanks bro. All thanks to you for contributing the secondary muffler to help complete the parts necessary to make it a true dual.
  4. Apr 20, 2021 at 11:50 PM
    #64
    nudavinci64
    Robert
    Nice yah it likely will be something of dual to 3" collector or maybe an X. Right now DT Shorties to improved catless midsection Y deal into 3" collection or Y then 3" back to the BW and turn down at axle. I was partially considering maybe going out the side.
  5. Apr 21, 2021 at 12:07 AM
    #65
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I was initially going to do a side exit as well but the battery tray was in my way so I was like screw it, let's try the dual out with the appearance of a single, eventually it just worked out to a single exit to each side. I'm good with all of it. The only thing left to do is go headers. Eventually. Still working on modding my boat. I've almost got it EXACTLY how I want it too, and then I can pay more attention to my truck again. Lol.
  6. Nov 8, 2021 at 11:55 PM
    #66
    4runnersickness
    4runnersickness Member
    Jovany
    2009 Black Urban Runner 4x4
    URD Headers, Afe Intake, Pedal Commander, URD MAF Sensor Calibrator, Magnaflow Muffler, URD FUEL Pump conversion Kit
    Whats up Roostfactor, was doing little research and found you here so figured I'd reply here.
    I am planning on putting a Flowmaster 50 Series SUV on my 4runner strictly for sound, which will have Magnsuon S/C, 2.85 Pulley, Afe CAI Stage 2, URD CAM gears, and URD equal length headers.
    As stated, the only reason I am going with Flowmaster is for sound.
    With that said, how do you think the Flowmaster will affect the performance under 2000 rpm? I have read of people on some forums complain about loss in mpg and low end torque on their N/A.
    Once again thank you for your advise!
    Biscuits and nudavinci64 like this.
  7. Nov 17, 2021 at 11:30 AM
    #67
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    Mech_Eng likes this.
  8. Dec 23, 2021 at 7:09 AM
    #68
    Zoey'sTaco
    Zoey'sTaco Art Jockey
    Noah
    Dirty Jersey
    2020 DCSB SR5, Daily, camper-hauler, blizzard chaser, rock bouncer, tool box
    6112/5160/Maggie SC Hammer Hangers Tom Woods 1 piece Shaft ARE-DCU ARE HD leafs Rear Seat delete
    nudavinci64 likes this.
  9. Dec 23, 2021 at 10:23 AM
    #69
    devinzz1
    devin
    2023 aclb trd or mt
    get a full length exhaust out that back. dumping at the axle causes significantly more drone inside the cab. plus the extra length deepens the tone slightly
    Zoey'sTaco[QUOTED] likes this.
  10. Dec 23, 2021 at 11:30 AM
    #70
    Zoey'sTaco
    Noah
    Dirty Jersey
    Ok. Noted. I’ve assumed a 3” pipe would be best but there are way more smaller diameters available to choose from. Does it make a difference?
  11. Dec 23, 2021 at 2:27 PM
    #71
    devinzz1
    devin
    2023 aclb trd or mt
    theres probably not much more restriction with the 2.5 at these power levels. id change headers and y pipe if your looking for power gains.
  12. Dec 23, 2021 at 5:16 PM
    #72
    Zoey'sTaco
    Noah
    Dirty Jersey
    Thanks for the reply. I’ll likely skip it altogether then if that’s the case. I need cats and high flow replacements are a bridge too far once the Maggie is paid for.
  13. Dec 24, 2021 at 2:14 PM
    #73
    nudavinci64
    Robert
    You will be fine on stock Maggie setup but exhaust will help if you start to mod
  14. Dec 24, 2021 at 2:15 PM
    #74
    nudavinci64
    Robert
    What’s everyone’s take on the SPEC-U exhaust setup? I have some stuff and was planning on having a shop do their thing but also debating if it’s easier to pick up the SPEc u setup since it already is a matched Y pipe and exhaust setup. I will be adding DT shorties up front.
  15. Dec 24, 2021 at 4:44 PM
    #75
    JaxJacket
    JaxJacket Well-Known Member
    2013 DCLB
    Didn't dyno it but felt like I lost low end torque (S/c w/ 2.85). Louder than I liked. Gained a little mileage - probably because I went lighter on throttle because of the noise. Went back to stock.
  16. Dec 24, 2021 at 4:46 PM
    #76
    nudavinci64
    Robert
    Running additional tune, cam gears or any other mods? What’s did you. Boost change from with and without? I’m running around 9 at max now so sue def needs to breath
  17. Dec 26, 2021 at 4:37 PM
    #77
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    I found the Spec-U exhaust (and Ypipe) to lose low end torque. It takes a pretty big hit below 2250RPM.
  18. Dec 26, 2021 at 4:42 PM
    #78
    nudavinci64
    Robert
    Ok that’s a bummer. Def don’t want that. what are your thoughts on what to go with? I may just go Keri a shop doing it but can’t find time to go. So if I can find a kit I can bolt up I may do that.
  19. Aug 25, 2024 at 1:28 PM
    #79
    herecomesace
    herecomesace Well-Known Member
    2013 Tacoma TRD Offroad Access Cab MGM Supercharged
  20. Aug 25, 2024 at 5:27 PM
    #80
    devinzz1
    devin
    2023 aclb trd or mt
    overpriced imo. only worth it if you cant weld and just plan to cut out original and clamp on existing exhaust. if not then its a fraction of the cost to just buy a muffler of your choice and a cutout separately. which is what i plan to do and route the cutout back into the exhaust same as the valvetronic
