Forgot to put oil in
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jlee91w, Oct 14, 2016.
  1. Oct 17, 2016 at 5:29 AM
    #221
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    This post doesn't even make sense.... why not buy the materials a day or so before? Why are you doing a tire rotation ? Everything you're saying in this post is about I don't want to do this or that , if that's the case yes stick to the dealer changing your oil cause you'd rather waste time driving there, waiting, and getting charged more money.
  2. Oct 17, 2016 at 5:30 AM
    #222
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    How could they drain oil if they forgot to put it in the engine to begin with?
    File IFR likes this.
  3. Oct 17, 2016 at 5:33 AM
    #223
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    They probably filled it up. Ran it for a bit, drained it to check for shaving or deposits from any damage that could have occured
  4. Oct 17, 2016 at 6:01 AM
    #224
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    The filter is a bypass filter. The entire load of oil needs to be filtered while draining the pan.
    Just autopsy of the filter is not going to give you the entire picture. Don't let them drain into a dirty oil drain pan.
    asuchemist likes this.
  5. Oct 17, 2016 at 6:05 AM
    #225
    Jerry311SD
    Jerry311SD Well-Known Member
    Jerry
    Ramona Ca SAN DIEGO
    2019 tacoma TRD Quicksand
    KDMaxx tune K&N drop in AFE catback Oil catch can Bill's 6112/5160 Dynomat whole inside of cab TRD skid plate
    Wow I'd make damm sure I got a new motor after that.
  6. Oct 17, 2016 at 6:49 AM
    #226
    StevoNB
    StevoNB Well-Known Member
    NB, Canada
    2020 DCSB TRD Sport 6MT
    Once I realized there was no oil in the engine, I probably would have said fuck it and just drove it until it died. They'd pretty much have to give you a new engine then.
    O906, File IFR, TRDSport10 and 4 others like this.
  7. Oct 17, 2016 at 7:08 AM
    #227
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    I can understand not doing that. We love our trucks and are not going to intentionally blow the engine even if its for a purpose.
    Vince the prince likes this.
  8. Oct 17, 2016 at 7:40 AM
    #228
    beetlevegas
    beetlevegas You are no Vader. You are just a child in a mask!
    JP
    Las Vegas NV
    2011 silver Tacoma TRD 6 Speed double cab
    stuff
    WOW that amazing that you drove it that fare. We had a LX570 that a tech forgot to put oil in. It was runing for about 5 mins in his bay and the motor blew up.
  9. Oct 17, 2016 at 7:56 AM
    #229
    Lester Lugnut
    That's an interesting thought. You have a receipt in hand that shows an oil change done by them that same day, a bone dry dip stick and frozen motor.
  10. Oct 17, 2016 at 8:09 AM
    #230
    Nalex
    Nalex Well-Known Member
    2012 Tacoma DC TRD OffRoad
    That explains why my GX engine is so smooth and quite and my Tacomas engine sounds like a Diesel engine.
    Rough engines = more durable :amen:
    beetlevegas[QUOTED] likes this.
  11. Oct 17, 2016 at 8:42 AM
    #231
    HDMac07
    HDMac07 Active Member
    2011 Tacoma Standard Cab 4x4
    Now THAT cost the dealership a pretty penny, even at THEIR cost.
  12. Oct 17, 2016 at 10:10 AM
    #232
    Vince the prince
    Vince the prince Well-Known Member
    2006 Tacoma
    This thread turned into a oil change debate but nevertheless I really want to know the outcome,so please post it as soon as you find I'd really appreciate it thanks
  13. Oct 17, 2016 at 10:40 AM
    #233
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    just a heads up if this ever happens again...
    according to the owners manual...
    Low Engine Oil Pressure Warning Light: "Do not drive vehicle with the warning light on- even for a block. It may ruin the engine."
  14. Oct 17, 2016 at 11:43 AM
    #234
    Taco16LB
    Taco16LB Well-Known Member
    Good point ! If push comes to shove the dealer may say he should have not restarted and drove back . I hate to say it and I really feel for the OP. but it depends if he told them what happened . He would have been best off saying it made a noise and he came right back and did not see any light.
    OP - without being unreasonable , insist for more than a warranty . I would get them to take it in trade for full value and get a new one. They should not take money off of the value for something they pretend is not a problem . This way you will never have any guilt for selling it to someone while knowing it is a problem .
  15. Oct 17, 2016 at 11:51 AM
    #235
    indetrucks
    indetrucks Well-Known Member
    Christian
    Southern CA
    Supercharged 03 TRD Tacoma 4x4 Xtra Cab 5spd
    Don't forget the minimum wage earning 18yr old tech who will also get fired.
  16. Oct 17, 2016 at 12:01 PM
    #236
    Taco16LB
    Are you saying that if a minimum wage earner did it the owner should take the hit ? He would be fired anyway because it happened . How about the minimum wage earner that cross threads your oil pan plug . It could take days for the oil to get low enough to cause a problem and then they deny it all because you should have seen oil dripping . It happened and the dealer should take the hit.
  17. Oct 17, 2016 at 12:02 PM
    #237
    HDMac07
    The technician will not get fired if it's his first mistake.
  18. Oct 17, 2016 at 12:10 PM
    #238
    Taco16LB
    I correct my post now after thinking more about it.
    NOT that the OP did because I read most of this and believe he was wronged ! But how many times does someone screw up their own home oil change and forget to put in the oil . Drive it for a bit and say oh Crap !!! . then go to the dealer and have it done , then leave , drain it out and drive it until it seizes and blame it on the dealer ? I bet it has been done before . The dealer has to be sure as to what happened also .
  19. Oct 17, 2016 at 12:10 PM
    #239
    TucTaco520
    TucTaco520 Well-Known Member
    Phil
    It's a dry heat
    11 Hooptie
    OME 90000s+887s, LR UCAs. AllPro Expos + 5100. KM Fab hybrid sliders w/kickout. KM Fab bed rack. 48" hi-lift. 16" FJ Trail Team wheels. 285/75/16 Hankook Dynapro ATMs. Magnaflow cat-back. K&N filter. TRD short-throw shifter. Murdered out via plasti-derp front grille and rear bumper. LED interior. De-badged tailgate. Rock lights (7). G2V 3x2 ditch lights.
    My brother worked at the local Subaru dealership for a while taking pictures for internet listings. In '15, this exact thing happened. The dealership decided to give the guy full trade in value, regardless of the blown motor. He ended up getting into a brand new vehicle for the $5K or so difference in price. And yes, the tech got fired on the spot. First mistake or not, the guy was an obvious liability for them and they had to correct it.
  20. Oct 17, 2016 at 1:02 PM
    #240
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    Our mechanic was fired, but the parts dept hired him and he's actually a pretty good guy.
