Forgot to put oil in
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jlee91w, Oct 14, 2016.
  1. Oct 20, 2016 at 11:24 AM
    #341
    Shelf Life
    Shelf Life Well-Known Member
    Rob
    Central Oregon
    '06 ACC CAB 4x4 TRD OFF ROAD
    I concur with the new motor crowd. I wouldn't trust some smoke and mirror tests from the same dealer that forgot to put oil in. Half a mile of driving without proper lube, that engine has lost some serious life span.
    File IFR and Sith Taco 15 like this.
  2. Oct 20, 2016 at 11:32 AM
    #342
    Brooky816
    Brooky816 Well-Known Member
    06 Tacoma SR5 Prerunner double cab
    None
    Absolutely! They made a mistake.They owe you an engine without a doubt. Do not let up on
    them replacing it. They certainly do not want to but it's their fault.
  3. Oct 20, 2016 at 11:36 AM
    #343
    Clearwater Bill
    Billy
    Largo Florida
    Didn't wade though the pages. But if no one suggested sending an oil sample to an independent lab for a test, do it.
    While looking for sparkles is good enough on your own, it's not good enough in court.
    Lab results are. Because they will tell you exactly what the particles consist of and what kind of components in the engine are made from those.
    I'm potentially with the new motor crowd. Depending on your lab test results. Which I predict would be problematic. However, if it's clean as a whistle.........
    Small claims court and a newspaper consumer reporter could be good friends with you soon.
    Get your own sample of the current oil out BEFORE you take it to them on the 1st.
    Taco16LB likes this.
  4. Oct 20, 2016 at 11:49 AM
    #344
    Taco16LB
    Taco16LB Well-Known Member
    Tell Toyota headquarters to buy the truck and pay someone to drive it for 100,000 miles then do a TV add talking about how - even after running with no oil for ...... and then after 100,000 miles , it still runs as new ! If its never heard about again , we will know !
  5. Oct 20, 2016 at 1:05 PM
    #345
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    This is why I said IF. That is only the first and most obvious indication and clearly can't be as precise as an oil analysis.
    I once had a lot of large metal shavings in my oil. Enough to be concerned. Turned out that the thrust bearing had somehow falling out and got chewed up by the engine and was in the oil pan. Upon this assembly none of the bearings on any of the journals or bad. But the main cap where the thrust bearing was, well yeah that was definitely ground to a new surface.
    Point is the metal shavings warrant clearly indicative of where the damage was. And it just goes back to say that without disassembly and inspection you never really know. Which complements what krosis for saying
  6. Oct 20, 2016 at 1:09 PM
    #346
    brich999
    brich999 Well-Known Member
    Bryan
    16 Tacoma TRD Sport AC
    all tore up already
    just afraid hes going to get to the shop, they will show him a "clean" filter and that will be the last the shop feels responsible. UOA would be the least id ask for
  7. Oct 20, 2016 at 1:14 PM
    #347
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    If all else fails..ass beating
    Torspd likes this.
  8. Oct 20, 2016 at 1:16 PM
    #348
    Vince the prince
    Vince the prince Well-Known Member
    2006 Tacoma
    AMEN!!!! If your satisfied with the results and your good with what they saying then don't worry about a lot of these guys running the mouths ...
    EatSleepTacos likes this.
  9. Oct 20, 2016 at 1:42 PM
    #349
    Clearwater Bill
    Billy
    Largo Florida
    Absolutely. Answer for everything. Especially something like this. While he's locked up for assault, no worries about the truck breaking down.
  10. Oct 20, 2016 at 2:15 PM
    #350
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    New motor or bust.... plain and simple. The motor you have will NEVER be the same and it will NEVER last as long as a motor that had not been ran without oil.
    DO NOT ACCEPT ANY FUCKING THING LESS THAN THIS.
    TexasWhiteIce likes this.
  11. Oct 20, 2016 at 2:57 PM
    #351
    Vince the prince
    2006 Tacoma
    Some of you guys are outta control
    14 Tacoma and EatSleepTacos like this.
  12. Oct 20, 2016 at 3:03 PM
    #352
    FinnJ
    FinnJ Well-Known Member
    Finland
    2007 FJ Cruiser 6M/T
    TRD SC, UCON, CNG conversion, RC 6" (lifted 4"/3" air suspension) w/FOX 2.5, 315/70R17 Duratracs, RECARO seats, etc.
    What was that sound? Like it seized? But started again normally?
  13. Oct 20, 2016 at 3:27 PM
    #353
    O906
    O906 Well-Known Member
    Why?
  14. Oct 20, 2016 at 3:27 PM
    #354
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    They already drained what was left the first time and tossed the filter, those should have been sent out for a sample. Sticking a borescope in through the drain plug hole is not going to show the crankshaft bearings and sticking down the sparkplug holes is just going to show scratches on the cylinder walls that they are going to tell you is normal. My personal opinion is that they are blowing smoke up you, it is your truck and you can decide if you think its fair.
    brah.coma likes this.
  15. Oct 20, 2016 at 3:40 PM
    #355
    Vince the prince
    2006 Tacoma
    A lot of blaming him because he doesn't change his own oil ??? That's fucked up . To each his own .
    Plain Jane Taco likes this.
  16. Oct 20, 2016 at 3:42 PM
    #356
    O906
    Well I didn't blame him for not changing his own oil but I did say that if he had done it this wouldn't have happened. Which is true.
  17. Oct 20, 2016 at 3:48 PM
    #357
    Vince the prince
    2006 Tacoma
    Yeah it is true ..others blamed him because he's lazy,or he must not care for his vehicle so he got what he deserved
  18. Oct 20, 2016 at 4:04 PM
    #358
    kenstar
    kenstar Get a Lil Mud on the Tares
    Ken
    Wrenching in the garage.
    10 4x4 TRD OR
    Pop 'n' Lock, EGR In-Chan, Bakflip G2, 6112, 5160, Dakar Set. Redline hood struts. WildPeak At3. TRD Pro Wheels. Apex Fab Fog lights; Other shit I can't remember.
    "Yes sir, I assure you everything is fine." Pack it up folks. Nothing to see here, his motor is good to go.
    Torspd likes this.
  19. Oct 20, 2016 at 4:13 PM
    #359
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    With what you quoted, either rod knock or bearings squeaking as the metal surfaces sheared into each other. I bet there is rod end discoloration, from excessive heat.
  20. Oct 20, 2016 at 4:22 PM
    #360
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB SR5 4x4
    Icon 2.5 RR/w CDCV 700# springs Front Shocks JBA UCA's Wheeler's Offroad Superbump Front Bump Stops Icon 2.5 RR/w CDCV 4"+ Rear Shocks AllPro Expo Rear Leaf Pack Timbren Rear Bump Stops ARB Front Bumper @Shmellmopwho Rock Sliders w/ Kickout RCI Aluminum Front Skid Plate Prinsu Roof Rack Roll-N-Lock Tonneau Cover CBI Ditch Light Brackets Cali-Raised LED Ditch Lights Cali-Raised Amber Fogs Cali-Raised Flush Mount LED Pods
    Sending an oil sample to a lab to check for metal in the oil is the best way to check for damage in the engine.
    You have no idea of the extentire of damage done to bearings on the rod and crank.
    My bosses dad ran a Cat loader without oil TWICE. Point of failure each time was a spun rod bearing. You can't inspect that with a bore scope or cutting open an oil filter.
    Minimum from the dealer would be a lifetime warranty on the motor.
    I would get this resolved, then trade in the truck for another truck for peace of mind.
