FOUND IT! Post lift clunking and knocking.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jtweezy, Dec 23, 2015.
  1. Mar 5, 2016 at 3:12 PM
    #281
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
  2. Mar 5, 2016 at 3:13 PM
    #282
    jtweezy
    jtweezy [OP] Well-Known Member
    Austin
    2014 4X4 DCSB OR V6
    That's what I thought about mine. Gonna try UCAs (because I really should have them for the lift anyways) before I press out the passenger side lower ball joint.
  3. Mar 5, 2016 at 3:14 PM
    #283
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Yea I edited with link http://www.spcalignment.com/index.php?option=com_spc&task=part_description&pid=2500
    Too rich for my blood when SPC/LR works well (when properly greased)
  4. Mar 6, 2016 at 7:49 PM
    #284
    Ringwraith
    Ringwraith Well-Known Member
    Abbotsford, BC, Canada
    2006 Red Tacoma TRD Offroad Access Cab
    3" OME lift, Dakar leafs, ARB front bumper, custom high clearance rear, RTT
    Just solved my popping/clunking noise thanks to suggestions in this thread. After replacing both cv axles (one due to it breaking) and not making a difference, started checking the torque on some of the stuff mentioned in here. Ended up being the rear LCA cam bolt. Was very loose. Torqued to 100 and no more noise! Thanks guys!
    Crom, jtweezy[OP] and DrFunker like this.
  5. Mar 7, 2016 at 4:28 AM
    #285
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    That is where it feels like mine is so today is supposed to be real nice for a change up here. Gonna crawl underneath and tighten those up. Is it on the front or rear of the LCA's
    DrFunker likes this.
  6. Mar 7, 2016 at 4:40 AM
    #286
    DrFunker
    DrFunker Well-Known Member
    :yes:
    Crom likes this.
  7. Mar 7, 2016 at 4:40 AM
    #287
    DrFunker
    This week is supposed to be warm. Wednesday looks like summer.
  8. Mar 7, 2016 at 4:41 AM
    #288
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    So the bolt I have to tighten is it on the front of the Cam Bolts or rear @DrFunker
  9. Mar 7, 2016 at 4:46 AM
    #289
    DrFunker
    Oh shit. Wrong guy to ask. Sorry. I haven't done anything with mine. I wish I had an answer for you.
    I am watching this thread and your T&E to see what I have to do. hahahaha.
    Again, I would ask Drew @tacobell007 or Joe @Blackout14
    Or Cam @flyboy.co2 (How was the trip, btw?)
  10. Mar 7, 2016 at 5:05 AM
    #290
    jtweezy
    Austin
    2014 4X4 DCSB OR V6
    Nice!
    I believe for the front, the nut you turn is facing toward the front of the truck, and for the rear the nut you turn is facing the rear of the truck. So basically you'll be turning the ones on the OUTSIDE of the legs of the "A". When you get under there you'll be able to tell by looking at the bolts which side of each one turns.
    Also, torque ALL of them if you're gonna get under there. You have to remove your front-most skid plate (if you have one) to get to the front nuts.
    Blackout14 likes this.
  11. Mar 7, 2016 at 5:05 AM
    #291
    DrFunker
  12. Mar 7, 2016 at 6:32 AM
    #292
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Thanks Gents found the correct bolts to tighten, but could only tighten the backs 2 as the front I need a deep socket and with having no tools now need to go some deep sockets. Does anyone happen to know the torque specs for the nut where the shock attaches to the LCA? As far as the Drivers side rear Cam bolt I got a few turns in it before it clicked to torque. So maybe after I go get a deep socket 3/4 socket I can hit the fronts and maybe IT WILL GO AWAYYYYYYYYYYYYYYYYYYYYY
  13. Mar 7, 2016 at 6:52 AM
    #293
    Sandman614
    Tim
    '06 SR5 Off Road
    Yea front bolt you tighten the front, rear bolt you tighten the rear.
  14. Mar 7, 2016 at 6:57 AM
    #294
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    61 ft lbs
  15. Mar 7, 2016 at 6:59 AM
    #295
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Thanks I am wondering where the guy came up with 100 ft lbs for the cam bolts. My diagram shows 155 ft lbs torque for 2wd and for 4wd it states 135 ft lbs of torque
  16. Mar 7, 2016 at 7:12 AM
    #296
    neverstuck
    Guido
    Lebanon
    13 DCLB sport
    Mine says 100. PM me your email address and I will email you the pdf I use.
  17. Mar 7, 2016 at 7:14 AM
    #297
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
  18. Mar 7, 2016 at 7:15 AM
    #298
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Sweet thanks
  19. Mar 7, 2016 at 7:15 AM
    #299
    neverstuck
    Guido
    Lebanon
    13 DCLB sport
  20. Mar 7, 2016 at 7:18 AM
    #300
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Is it okay to torque the lower shock mount while the truck is on the ground???
