FOUND IT! Post lift clunking and knocking.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jtweezy, Dec 23, 2015.
  1. Mar 10, 2016 at 4:16 PM
    #341
    mrsteve
    mrsteve Well-Known Member
    Leesburg, Virginia
    2012 DC TRD Sport
    I sure do. But I swear the clunk happens the moment I hit a bump with my front tire.
  2. Mar 10, 2016 at 4:23 PM
    #342
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Damn! This thread has some mad folks in it. Best of luck to everyone solving their noises. I feel a bit lucky as my rig presently makes no unwanted noises.
    To try and help, I will add this. On my truck, it used to make popping noise when going over speed bumps slowly at an angle, or creaking noise when opening my drivers door. It was a true mother-source of irritation and frustration. That problem as it turns out was laminated sheet metal moving in the body around the door sill / A-pillar. The solution to that problem was to spray penetrating oil into the pinch weld. Years later, I did it to the passenger side and no more noise on that side either.
    I run the the extra spring on the brake pad, currently my pads are too new to know if it's going to make a difference. I changed out the OEM pads when they wore down to 4mm, just because I didn't like the noise when reversing direction.
    I wouldn't bother. 99% of the Dakar spring noise is caused by the main spring vibrating against the second spring. The noise is caused at both the front and rear. I used zip ties to separate the leaves which proved highly effective. They eventually broke months later, I drove the springs apart and hit them with Dry Moly lube which has been working very well.
    Not exactly. Some select black ES bushings have graphite as an added lubricant, red do not have this quality. Link
    Best of luck to all.
  3. Mar 10, 2016 at 4:24 PM
    #343
    mrsteve
    Leesburg, Virginia
    2012 DC TRD Sport
    livpool14 likes this.
  4. Mar 10, 2016 at 4:25 PM
    #344
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    I think you'd need to grease these every year or so, and the stock LCA doesn't have provisions to screw in zerk fittings.
  5. Mar 10, 2016 at 4:26 PM
    #345
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Do you have the part number to the springs that you used to add the secondary ones up top by chance?
    I swear my clunking is brake related. After going through it up and down I have found no visual reason as to why else it would clunk. Everything is very tight.
  6. Mar 10, 2016 at 4:45 PM
    #346
    Spoder514
    Spoder514 New Member
    Sac. Ca.
    2013 Tacoma
    King Camburg Fox SCS wheels Custom fab work and mods, it never ends
    I have ran into this issue before, the slip yolk in the steering shaft gets dry of grease and clunks. Grease it up with some thick grease, good to go. Just throwing it out there and hope it helps someone cure their clunk.
    Typically felt at slow speeds, random clunks.
  7. Mar 10, 2016 at 5:04 PM
    #347
    jtweezy
    jtweezy [OP] Well-Known Member
    Austin
    2014 4X4 DCSB OR V6
    I swore up and down that my clunk was from the front and I think I had ONE up front, but the lower ball joint fixed that.
    The one I have now sounds and feels like it's from the driver's side leaf pack. I checked out my front bushings and the driver's side is clearly off center. You can also see some contact areas in the "bucket" that the front of the leaf pack slides into. I have the poly bushings on order, gonna try to swap them in soon.
  8. Mar 10, 2016 at 5:33 PM
    #348
    mrsteve
    Leesburg, Virginia
    2012 DC TRD Sport
    Mine is very intermittent. It's almost like something is bound up and then the right bump or amount of flex releases it. I drove 15 miles to work today without a sound. The on the way home I went though one intersection and sure enough it clunked on damn near every crack in the roadway.
  9. Mar 10, 2016 at 5:46 PM
    #349
    jtweezy
    Austin
    2014 4X4 DCSB OR V6
    Paying closer attention, mine happens when there is lateral force on the rear axle. Sometimes it's when I hit a bump in the road with one rear wheel only. It definitely happens going over a speed bump one rear wheel at a time.
    When I turn up/down a sloped driveway it sometimes happens, and I think it depends on which way I entered the driveway, and therefore which side of the bushing the leaf pack shifted to. Since it can then only go in the opposite direction.
    I also thought it was the front because it'd pop right when I started a turn, but with the stiffer suspension, it angles the truck over the rear, outer wheel instead of eating the bump in the front shocks.
  10. Mar 10, 2016 at 5:51 PM
    #350
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Check your u bolts and center pins to make sure they are all tightened down. If they are, suspect axle wrap. Are you still running stock 3 leaf/ 4 leaf packs?
  11. Mar 10, 2016 at 5:52 PM
    #351
    jtweezy
    Austin
    2014 4X4 DCSB OR V6
    U-Bolts are at 100ft-lbs now. Smooth take-off, so I don't suspect axle wrap. Also, no clunking during take-off. I have OME Dakar full packs...nothing removed.
  12. Mar 10, 2016 at 5:55 PM
    #352
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Shot bushings by chance? There is nothing back there other than the shackle and the bushings that could be clunking. Unless your shock's are somehow contacting the frame during bumps.
  13. Mar 10, 2016 at 6:02 PM
    #353
    jtweezy
    Austin
    2014 4X4 DCSB OR V6
    Yup. Leaf spring front bushings are exactly what I'm suspecting. Rears look good. I order some ES poly leaf spring bushings, hopefully pressing out the old ones won't be too bad. They're still relatively new and haven't seen snow/salt.
    12TRDTacoma[QUOTED] likes this.
  14. Mar 10, 2016 at 6:03 PM
    #354
    mgw24
    mgw24 Well-Known Member
    Central Idaho
    2011 DCLB 4WD SR5, 1998 Reg cab 5 lug
    Crappy spacer lift w/AAL, Camburg Balljoint UCAs, Pioneer AVH-X2700BS
    Did it start after your camburg UCA's? I get the same thing, seems more prominent on the drivers side though..
  15. Mar 10, 2016 at 6:09 PM
    #355
    12TRDTacoma
    Rob
    Concordia
    Boosted
    You are going to have to do that and let us know how it fares out. I have to install secondary caliper retention clips on my calipers and see if that will hold onto everything in there a little better to keep them from clacking. My noise sounds more like clacking then clunking.
  16. Mar 10, 2016 at 6:25 PM
    #356
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Happened about 2 months after it all was installed
  17. Mar 10, 2016 at 6:30 PM
    #357
    jtweezy
    Austin
    2014 4X4 DCSB OR V6
    Mine's definitely a clunk. Hopefully yours is brake pad slap. I will for sure update if the bushings were my problem. I also suspect them because ARB says to tack weld them because they might move.
  18. Mar 10, 2016 at 6:32 PM
    #358
    jtweezy
    Austin
    2014 4X4 DCSB OR V6
    1rooster and 12TRDTacoma like this.
  19. Mar 11, 2016 at 7:35 AM
    #359
    mouse007
    mouse007 Well-Known Member
    Mauricio
    Weston,Florida.
    2014 TRD Off-Road 4x4
    ICON Vehicle Dynamics Uni-Ball UCA, ICON Vehicle Dynamics Extended travel remote reservoir coilovers, with 700# Coils and CDC (Compression Damping Control) Clicker Valves. Dakar Leafs Old Man Emu Nitro Sport Shocks Toyotech U-Bolt flip kit, Goodyear F. & R. extended Stainless Steel Brake lines. aFe Pro Dry drop in air filter. ARB Bull Bar. Weld on AVID Off-Road Rock Sliders W/ Kick Out. Tires: 285/75 R16 BFGoodrich KO/TA's. Light Force Blitz 240's 12v. Warn M-8000 W/ Viking Off-Road Synthetic winch line.
    @jtweezy Do you have any pictures, how did you determine this may be the problem..? Sorry, dint fully ready everything.
  20. Mar 11, 2016 at 8:37 AM
    #360
    HB Taco
    HB Taco Well-Known Member
    Curt
    Huntington Beach, CA
    2019 F150 FX4 S Crew 3.5 TT
