FOUND IT! Post lift clunking and knocking.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jtweezy, Dec 23, 2015.
  1. Mar 11, 2016 at 8:38 AM
    #361
    mrsteve
    mrsteve Well-Known Member
    Leesburg, Virginia
    2012 DC TRD Sport
  2. Mar 11, 2016 at 8:41 AM
    #362
    HB Taco
    HB Taco Well-Known Member
    Curt
    Huntington Beach, CA
    2019 F150 FX4 S Crew 3.5 TT
    well I've ordered a few parts to assemble my stock OR bilstein shocks to try. We'll see if its something in the shock assembly.
  3. Mar 11, 2016 at 8:57 AM
    #363
    mrsteve
    Leesburg, Virginia
    2012 DC TRD Sport
    I'm starting to think it could be the actual shock or upper shock mount.
  4. Mar 11, 2016 at 9:19 AM
    #364
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I didn'tread through all of the pages, so someone might have mentioned this already.
    Always tighten/torque suspension components, when the vehicle's suspenion is at its normal ride height. Otherwise A LOT of popping will soon follow.
    Especially with the oem leaf spring bushings. As the bolt sleeves have what best I can describe as "spiked" ends. They will definitely need to be in their normal ride height position before fully tightening.
    mgw24 likes this.
  5. Mar 11, 2016 at 9:57 AM
    #365
    jtweezy
    jtweezy [OP] Well-Known Member
    Austin
    2014 4X4 DCSB OR V6
    No pictures of the leaf spring bushing, but I updated the OP with the info. Tried to keep it more concise because nobody's reading my super long update posts, haha.
    mouse007[QUOTED] likes this.
  6. Mar 11, 2016 at 1:55 PM
    #366
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    I'm there too. I suspect maybe the spring is chattering or the strut head is rattling in the tower. I'm putting that ES spring buffer on this weekend.
  7. Mar 12, 2016 at 10:05 AM
    #367
    1rooster
    1rooster TACOMA31750
    Georgia
    2007 Tundra crewmax
    5100's ALL WAY AROUND, 885X COILS, DRIVER SIDE LEAN SPACER, ICON PROGRESSIVE AAL W/O OVERLOAD, 265/75/16 KENDA KLEVER M/T. 1 1/4 SPIDERTRAC WHEEL SPACERS, GEN 1 TRD COLD AIR INTAKE, STOCK MUFFLER WITH CHOPPED TURNDOWN, 5% TINT OVER FACTORY, DEBADGED, TOYOTA RUBBER BED MAT, WEATHERTECH MATS,UWS TOOLBOX, UNDERCOVER SE, LOCKER MOD, REAR BUMPER, PIONEER DOUBLE DIN WITH PARKING BREAK OVER RIDE, CUSTOM OIL CATCH CAN, FULL LED INTERIOR, ARB BUMPER REPLACEMENT. COVERKING SEAT COVERS. MORIMOTO H1 MINI COVERSION WITH MINI GATLIN GUN SHROUDS AND 5000K MORIMOTO BULBS. TRAILER PLUG RELOCTED TO BUMPER. 20 INCH LED LIGHTBAR MOUNTED BEHIND CUSTOM PAINTED GRILL. STUBBY ATNENNA
    I will be pulling the LCA tomorrow and tacking the bushing in place tomorrow, if weather permits. I'll let y'all know how that goes.
    Weezy: how did the ecgs bushing go? I was reading in another category that you ran into a problem.
  8. Mar 12, 2016 at 12:44 PM
    #368
    mrsteve
    Leesburg, Virginia
    2012 DC TRD Sport
    Just noticed my driver side swaybar endlink has a nice bend in it. I honestly haven't heard a clunk in 2 days of driving on pavement. About to go give it another try on rough gravel.
    I did order Moog replacement endlinks. They appear to be the correct size but are different. One came with grease fittings installed. The other did not and I'm having a hell of a time getting one of the fittings installed. Seems like the hole isn't threaded or something.
  9. Mar 12, 2016 at 1:17 PM
    #369
    1rooster
    Georgia
    2007 Tundra crewmax
    Weird. Same model number on the boxes?
  10. Mar 12, 2016 at 1:35 PM
    #370
    jtweezy
    Austin
    2014 4X4 DCSB OR V6
    ECGS bushing and lower ball joint went well considering it was my first time doing either, and I was going at it solo. The bad vibes I got after install and initial test drive was because I'm and idiot who didn't seat his rim correctly. D'oh!
    Moog doesn't seem to like threading their grease fitting holes. The lower ball joint I put in had the same issue and it was a HUGE PITA.
  11. Mar 12, 2016 at 1:38 PM
    #371
    1rooster
    Georgia
    2007 Tundra crewmax
    Good to hear. So you put your order in for the rear leaf bushing. Once they come in it would be an easy fix.
  12. Mar 12, 2016 at 1:43 PM
    #372
    mgw24
    mgw24 Well-Known Member
    Central Idaho
    2011 DCLB 4WD SR5, 1998 Reg cab 5 lug
    Crappy spacer lift w/AAL, Camburg Balljoint UCAs, Pioneer AVH-X2700BS
    What did you use to press out/in the balljoint? I'm wondering if I need to go that route.
    Is there a good way to test the balljoints? I've tried jacking up the front end and trying to see if there is any movement by prying on the tire, shaking it, etc.. Seems solid.
  13. Mar 12, 2016 at 2:23 PM
    #373
    jtweezy
    Austin
    2014 4X4 DCSB OR V6
    Actually got them in last night and had a window of opportunity this afternoon, so I did the driver's side. Helps with the clunking a lot. I think my issue isn't due to 1 factor. My leaves are still shifting, and I know for sure now because they've pushed out the bike inner tubes that I put in between them!
    The old bushing has rust spots on the metal sleeves, and it was cake to press out so I'm not surprised the leaf pack was shifting on it.
    I used the 23 piece ball joint press set from Advance Auto Parts (loaner tool). They had the right combo of adapters to do our lower ball joints. When I tried the traditional wheel movement test, everything felt solid. It wasn't until I got the piece that bolts to the spindle (2 19mm bolts) and to the lower ball joint (1 castle nut) off that I could feel how easy it was to move the old ball joint. Compared to the new one, it was "flimsy". I just changed mine out because this clunk is driving me bananas. FWIW, I pressed my old ones out and new ones in with hand tools. Didn't need an impact wrench on the press like some people like to do.
    mgw24[QUOTED] likes this.
  14. Mar 12, 2016 at 8:19 PM
    #374
    HB Taco
    Curt
    Okay so I'm happy to say I fixed it. I got new top hats, bushings and washers and put in my OEM shocks in. I added a 3/4" poly preload spacer (goes in place of the isolator = 1" lift) Then a 1/2" top plate spacer to at least give some lift in it. Now it is quiet and smooth again. I'm super stoked that's what it was. It actually rides pretty good seeing as the shocks only had about 4K mi on them when I replaced them with 5100's. I lost about 3/4" of lift. I went from 2.5" to 1.75". It's really only a temp solution as I will get another set of 5100's or maybe shell out some $$$ and get some Icons or Fox coilovers? Loving the quiet cush again. I went over the infamous dip that always caused a clank the last year or so 6 times and it never made a sound just cushhhhhhh! Love it.
    jtweezy[OP], 1rooster and mgw24 like this.
  15. Mar 12, 2016 at 8:57 PM
    #375
    1rooster
    Georgia
    2007 Tundra crewmax
    Good to hear you fixed it!
  16. Mar 12, 2016 at 9:20 PM
    #376
    HB Taco
    Curt
    Thanks Bud. It's really satisfying to fix something like this DIY. I was fearing the worst and wasn't too confident that was it.
  17. Mar 13, 2016 at 7:09 AM
    #377
    mrsteve
    Leesburg, Virginia
    2012 DC TRD Sport
    Left and right are different part numbers.
  18. Mar 13, 2016 at 7:12 AM
    #378
    mrsteve
    Leesburg, Virginia
    2012 DC TRD Sport
    Here is what my stock driver's side endlink looks like. A little bent huh? I'm actually convinced the clunk I had was a combination of bent endlink and swaybar hitting coils plus loose cambolts. I drove over a nasty gravel road yesterday with no noise.
  19. Mar 13, 2016 at 9:46 AM
    #379
    HB Taco
    Curt
    How did that get bent. That would take a big hit to do that. I like those Moog end links especially since they're greasable. Yea sounds like your good to go. If the LCA cam bolts are not torqued to 100+ you can get noise. That helped but didn't cure mine.
  20. Mar 13, 2016 at 3:37 PM
    #380
    jtweezy
    Austin
    2014 4X4 DCSB OR V6
    Anything wrong with driving around the neighborhood with the rear shocks disconnected from the top mounts?
    I got under the truck and shifted it side-to-side by grabbing the spare tire and got it to knock. I think the OME Nitrochargers are too big for the bottom shock mounts. Mine's a 2014 and I thought only the 2015s had this problem, but the clearance is VERY minimal.
