Four Linked with fuel cell, now check engine???
Discussion in 'Long Travel Suspension' started by Dirtdevil, Feb 25, 2012.
  1. Feb 25, 2012 at 8:33 AM
    Dirtdevil
    Dirtdevil [OP] Member
    Mission Viejo, CA.
    04 Pre-Runner V6
    Fully Caged, Four Linked rear, Engage Long Travel front Arms Modified Spindle, King Shocks All Around, 2nd Gen front conversion kit. Stitchcraft racing seats with crow 5 point harnesses.
    I took out stock gas tank and components and put in a fuel cell.
    Check engine code is saying something about not having the evap or charcoal can. Anyone know how to bypass this to turn off check engine?
  2. Feb 25, 2012 at 8:00 PM
    ItsHerTruck
    ItsHerTruck The Primeministah
    Alex
    K-Town, Hawaii
    2010 Timber TRD Debadged
    Radflo coilover, dakar leaf pack, Light racing UCA,walker evens 9.5,ap ubolt flip,retro fits,wet O's,TRD catback,K&N intake,grill craft,allpro plate bumpers,warn m8000,safari snorkel,etc.
    I can't help exactly But, you need to put resistors for the sensors wires to give the ecu the right reading.... I don't Know the components resistance so im not sure of what size resistor. Maybe a service manual would have the info .... Or if you have a multi meter you can read the ohms of the stock components then replicate with the right size resistors...
    Uhhhh I hope that helps..LOL Good luck...If not.. Electrical tape over the light..LOL
  3. Feb 25, 2012 at 8:01 PM
    04LTtacoma
    04LTtacoma Well-Known Member
    Outer Space
    I want to see this truck.
  4. Feb 25, 2012 at 8:06 PM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    x2!
  5. Feb 25, 2012 at 8:19 PM
    04LTtacoma
    Outer Space
  6. Feb 25, 2012 at 8:23 PM
    Rmesa1
    Rmesa1 Well-Known Member
    reinstall the canister and purge valve plug off all lines that go from the canister to the tank. The ecu will run the monitor and test the canister only. As long as no leaks are present in the canister it should pass and not turn on the check engine light .
  7. Feb 25, 2012 at 8:38 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    I wana see this set up to
  8. Feb 25, 2012 at 8:43 PM
    04LTtacoma
    Outer Space
    ^ I know I want to see this guys truck!
  9. Feb 26, 2012 at 11:07 AM
    ocherp
    ocherp Well-Known Member
    Gilbert, AZ
    2016 V6 4X4
    SDHQ built
    [/QUOTE] Electrical tape over the light..LOL[/QUOTE]
    Same thing I was going to say, lol I just left my check engine light on and ignored it. When I get around to re-doing the cab, the engine check light will eventually get taken care of :D
  10. Feb 27, 2012 at 11:34 AM
    Dirtdevil
    Mission Viejo, CA.
    04 Pre-Runner V6
    All right thanks for the input guys. I just need it off to pass smog. And i uplaoded some pics for you guys, hope you like em.
  11. Feb 27, 2012 at 11:40 AM
    BAMFTACO
    Juan
    Sweet truck man
  12. Feb 27, 2012 at 11:45 AM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    I have the same issue, either reinstall the charcoal system or stick a piece of tape over the CEL.
    Mine is just on
  13. Feb 27, 2012 at 11:54 AM
    Dirtdevil
    Mission Viejo, CA.
    04 Pre-Runner V6
  14. Feb 27, 2012 at 12:01 PM
    blackhawke88
    SGV, CA
    07 TRD Offroad
  15. Feb 27, 2012 at 12:51 PM
    ocherp
    Gilbert, AZ
    2016 V6 4X4
    SDHQ built
    Don't quote me on it, but I'm pretty sure you won't be able to pass smog with a fuel cell, someone with more info will hopefully shed more light on the issue.
  16. Feb 27, 2012 at 12:53 PM
    mjp2
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    Depends on the state. Here in NJ as long as the CEL is off, you're good.
    My charcoal canister is sitting in the garage so I can reinstall when it's time to get the Tacoma back on the road.
  17. Feb 27, 2012 at 2:55 PM
    Dirtdevil
    Mission Viejo, CA.
    04 Pre-Runner V6
    Ya im in Cali, ill have to pay someone a little extra to pass me on the visual but from my understanding they cant pass it with a check engine light on. It shows up in the computer. I might just have to reinstall the charcoal can for the test and then take it back off. I was just hoping there was an easier way to bypass it. Maybe with a resistor like ItsHerTruck said.
  18. Feb 28, 2012 at 1:26 PM
    Rmesa1
    On a the evap system in our trucks resistors won't work the computer needs to see the pressure changes in. the canister and tank to pass the monitor
  19. Mar 2, 2012 at 11:52 PM
    noSKills858
    noSKills858 battlescars
    Alex
    Escondido, CA
    2003 5-lug Prerunner
    Couple shocks, some old tires, and a bad paint job
    Try plugging in the connector to the sensor of the canister and just doing a loop back with the hoses.
    Or
    Just do what I do and ratchet strap the stock tank on with all the crap and get it to pass.
  20. Mar 4, 2012 at 11:11 AM
    Dirtdevil
    Mission Viejo, CA.
    04 Pre-Runner V6
    Tried the hose loop that didn't work. Don't want to strap the whole thing back in. There's got to be a way to trick the sensor. How has no one figured this out yet? I think it just needs to sense pressure some how.
