Four Linked with fuel cell, now check engine???
Discussion in 'Long Travel Suspension' started by Dirtdevil, Feb 25, 2012.
  1. Mar 5, 2012 at 7:55 PM
    Rmesa1
    Rmesa1 Well-Known Member
    It needs to see the canister in the vehicle. The pump and vapor pressure sensor are in the canister and are what run the monitor
  2. Mar 5, 2012 at 10:02 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    Just reset the cel before you bring it in. It takes ur obd 60 miles to register error codes after resetting
  3. Mar 6, 2012 at 9:18 AM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    ^That usually wont work either. The system has to be "ready" and it will usually show that there are pending codes as well
  4. Mar 6, 2012 at 5:19 PM
    noSKills858
    noSKills858 battlescars
    Alex
    Poway, CA
    2003 5-lug Prerunner
    Couple shocks, some old tires, and a bad paint job
    Well if you really want it to pass, then you have to hook up all the EVAP parts to the cell/motor AND you must have the stock filler hose to basically take it back to stock. The other thing you have to find is a tech that won't mind letting you pass the visual inspection.
