Fox 2.0 rear shocks and 2" block So. Cal
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by Kicker73, May 24, 2017.
  1. May 24, 2017 at 7:00 PM
    Kicker73
    Kicker73 [OP] Well-Known Member
    GMA
    So Cal
    2017 Tacoma SR5 4wd
    Too many to list
    Fox performance series 2.0 shocks
    BDS suspension rear shocks 4" lift
    Pt#98224953-1
    1500 miles on them in great shape with hardware. Full compression no wear on 5/8" shafts.
    17.57"compressed 29.82"extended
    2" blocks included.
    You can use AAL and 2" block
    Or 4" block.
    $180.00
    Located in Costa Mesa CA 92627
    Chhhhn and broketaco like this.
  2. May 24, 2017 at 7:04 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Price?
  3. May 24, 2017 at 7:24 PM
    Kicker73
    GMA
    So Cal
    2017 Tacoma SR5 4wd
    Too many to list
    $180.00 everything.
  4. May 25, 2017 at 12:11 AM
    Thyces
    Thyces 2 seater taco
    Ontario
    2009 DCLB TRD Sport
    Custom painted 6112's Fox 2.0 12" in the rear Allpro expedition leafs (garbage) Pelfreybilt aluminum single hoop front Full size pickup bedslide modded to fit Satoshi grill Ubolt flip kit Archive garage shackle flip 5" Sumo supersprings 1500lbs SPC uca's Full set RCI skid plates Weld on sliders ABS killswitch Pop'n'lock power tailgate lock Falken Wildpeak mt on FJ rims Plastidipped emblems Ebay projector headlights Smoked aftermarket tail lights High output led reverse lights Hella horns 330w 5d led bumper bar 18w spots on track facing rear (fuck you lights) B&m trans cooler Bussmann fuse box ECGS bushing Big 4 (0 gauge ofc wire) upgrade Mechman 240 amp alternator Jl 10w7 in a 1 1/2" thick wall custom box Alpine 1000w rms mono amp Group 31 AGM battery installed next to sub Yaesu 2800 Bearcat 980 in dash with wireless mic and stainless whip Diff breather mod Hilux snorkel Turbine pre filter Baja Rack low profile cab rack Rifle case on rack Shovel and axe on quick fists in bed Flat and spade shovel mounted in bed Highlift mount in bed Tech deck with magnetic ram mount Tab s7 on ram mount
    shipping to 48226?
  5. May 25, 2017 at 3:42 AM
    Thyces
    Ontario
    2009 DCLB TRD Sport
    Could these be used in a setup with just 3" lift? (Dakars, custom leaf pack) and I'm guessing I'll need new bump stops?
  6. May 25, 2017 at 11:54 AM
    Kicker73
    GMA
    So Cal
    2017 Tacoma SR5 4wd
    Too many to list
    @Thyces Designed for 4" but yes. With an appropriate bump location
  7. May 25, 2017 at 12:33 PM
    Thyces
    Ontario
    2009 DCLB TRD Sport
    Extended brake lines needed?
  8. May 25, 2017 at 6:06 PM
    Kicker73
    GMA
    So Cal
    2017 Tacoma SR5 4wd
    Too many to list
    No. Brakelines are more if a droop issue when you go 4" lift on the rear. I dropped my abs sensor. I put extended lines when I had deaver springs.
  9. May 26, 2017 at 10:13 PM
    Kicker73
    GMA
    So Cal
    2017 Tacoma SR5 4wd
    Too many to list
  10. May 27, 2017 at 11:24 AM
    Chrispytaco91
    Chrispytaco91 Well-Known Member
    Christopher
    San Diego,CA
    2016 Tacoma trd offroad 4x4
    Hey Guys I'm the one who bought these. I'm going a different route if anyone is interested these are still for sale.
    Thanks,
  11. Jun 1, 2017 at 7:30 PM
    shrreddoggin
    shrreddoggin Member
    Justin
    MT
    '12 turd TX pro
    allpro UCA's allpro aal 1.5" timbren bumps allpro front & rear bumpers allpro sliders, trany skid, diff skid, sway connects spindle gussets Jersey built hubs readylift HD steering links extended lines bilstein 6112 & 5160"s
    What would you change for just the shocks to 59801?
  12. Jun 1, 2017 at 9:09 PM
    Chrispytaco91
    Christopher
    San Diego,CA
    Sorry man they sold
  13. Mar 4, 2020 at 2:41 PM
    ThatTacomaThough
    ThatTacomaThough Well-Known Member
    2017 White Tacoma TRD Off-road
    - SUSPENSION: - 6”BDS Full Suspension Lift w/ Fox Shocks - SPC Adjustable Control Arms RIMS AND TIRES: - Vision Off-Road 412 Rocker Satin Black Rims (20x13) - Hankook All Terrain Tires (35x12.5xR20 ) LIGHTING: - Custom headlights-Painted black and white on inside with products from TheRetrofitSource-Halos, Demon eyes, Custom DRL board (All on controller) - Meso Customs LED Side Markers (In headlight) - Meso Tacoma Puddle Pods - Meso Customs BD5 Brake Light Kit - YotaMafia 6 Piece Rock Light Kit (Turns On When Car Unlocked) - Unique Racing Style Switchback White/Amber LED Smoke Mirror Turn Signal Light - Vision Pro Led Bulbs F2 - VIPMOTOZ LED License Plate Lamp Assembly - Morimoto Type T XB LED Projector Fog Lights - FCKLight Bar RGB V-2 Series - Meso Custom Map & Dome Lights - Custom Made Raptor Lights From Step Bar LED Strips - Rough Country LED Ditch Lights 2” Square CREE (DRL Mode) PERFORMANCE: - S&B Filters 75-5096D Cold Air Intake - MBRP S5338P 3" Cat Back Single Side Aluminum (Cut slanted at 45” angle over axle) Exterior - Prinsu Roof Rack - TacomaBeast 8DX LED Tail Lights - TRD Pro Grill (W/ White Lettering) - GatorTrax Tonneau Cover - N-Fab Black Textured Wheel 2 Wheel Step Bars 3’ Tube AUDIO: - PIONEER TS-SW2502S4 10-Inch, 1.200 Watts Shallow-Mount Subwoofer X 2 - Pioneer GM-D1004 400W 4-Channel GM Digital Series Class FD Amplifier (For Door Speakers) - Kicker 46CSC674 6-3/4" 2-way car speakers (Front Speakers) - Kicker 43CSC6934 CSC693 6x9 3-Way Speaker Pair (Read Speakers) - Genuine Subaru H631SFJ101 Tweeter Kit - Rockford Fosgate R400-4D Prime 400 Watt Full Range Class-D 4-Channel Amplifier (For Pioneer Subs) ACCESSORIES - Black Inlays For Chrome Vent Rings - JDMCAR Center Console Organizer - TuffSkinz Coaster (White Inserts) - Black Tacoma Lettering Tailgate - White “Toyota” Lettering on tailgate by camera - Steering Wheel White Lettering (Over Tacoma Logo on Steering Wheel) - Painted Brake Calipers White - Door Sill White Lettering - Runnin4tacos 3/4” D-Ring Shackle (Buddy White) - Tacovinyl Grille Badge - AJT Key Fob - Remote Start - MICTUNING MIC-FB-202 Blade Block,12-Way Fuse Box Holder - Rockford Fosgate Single In-Line AGU Fuse Holder for 4 AWG or 8 AWG Wire
    What shocks did you use to replace these? I’m trying to upgrade my rears to 2.0 with resis and adjusters but the length is so wonky I’m not sure what kind will work or how much travel I’ll need in the shocks etc
  14. Mar 5, 2020 at 10:47 PM
    tacotuesday12345
    tacotuesday12345 New Member
    rusty
    2012 toyota tacoma
    Just wanted to confirm are the shocks sold ?
