Fox coilovers vs drop bracket lift
Discussion in 'Suspension' started by especk, Aug 22, 2010.
  1. Aug 30, 2010 at 7:17 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    he said "lift" not coilovers:)
  2. Aug 30, 2010 at 7:23 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    For 35's you will need to go 4.88 otherwise 33's and 4.88 at 75 you will be pushing 3k easily, maybe a little more. Also depends on which 33's you go with. Most 285/75/16's are actually less than a 33" tire. A true 33" tire is 255/85/16 which is a tad over 33". With a true 33" you will be at 3k at 75 with 4.88. If I was you, I would go balls out like you a really wanting to. Go with the 4.88 and 35's. The only thing about doing that is you have to be SURE you are going to want to continue running large sized tires if you go 4.88 otherwise you are pissing your money away!
  3. Aug 30, 2010 at 7:27 PM
    Jason'sLawnCare
    Assuming you mean adjusted to preload the spring and provide "lift" there are still sacrifices as mentioned earlier. May be minimal but sacrifices none the less.
  4. Aug 31, 2010 at 10:59 PM
    DevL
    DevL Well-Known Member
    Dont forget the VSC activating when it shouldnt!
  5. Jan 25, 2013 at 7:11 PM
    XREILLYX
    XREILLYX Well-Known Member
    Reilly
    okanogan
    07 white double cab
    blacked out taillights, White OME 885X's, Billy 5100's around, added 120v/aux charger, Browning sticker!
    why dont you run a 4 inch drop bracket and 2 inch coilovers? that will give you your 6 inch and high clearance.
    Eviscerhate likes this.
  6. Jan 25, 2013 at 7:15 PM
    sk8rjess
    sk8rjess IG: @whoishack
    Cody
    Nashville, TN
    02 4x4 sr5
    some duct tape and zip ties
    i'm on 37s with a 2.7l and 4.3 gears(granted it's only temp), i still have a enough power. regearing to 4.88 you'll be fine. 4.88 with 35's are a perfect combo, no matter what engine you have.
  7. Oct 31, 2013 at 2:40 AM
    Jkohler
    Jkohler HUH?
    Justin
    UT
    02 4DR Taco TDR Supercharged SR5 6in lift
    12" Icon 2.5 coilovers, 6" Drop Bracket, Tuff Country 5" lift knuckles, Icon 4''-8'' Extended Coilovers, Light Racing upper control arms, 7" Alcan leafs, 13" icon 2.0 smooth bodies in the rear. 2.5" exhaust with Magnaflow cats and Thrush muffler. 295x75x16 AT's (34.4") Superchargers Other shit like rear breather mod relocate, gray wire mod, intake elbow removed, led's, toolbox, etc
    DOOO ITT! :D
  8. Oct 31, 2013 at 3:47 AM
    bigtaco06
    bigtaco06 Well-Known Member
    Jared
    Nor-Cal
    13 TRD OR DBCB SB
    Floor mats, shorty antenna, brute force hybrid front bumper, ICON stage 3, method double standards, 285/75/16 KM2's, cool stickers
    3" for go 6" for show.
    3" pros:
    Lower CG
    NOT cutting of your trucks crossmember
    Resale
    If you decide running 35" tires isn't your thing you can go back down and your truck wont look stupid assuming if you went with a DB lift.
    Higher clearance at the crossmember
    Can still run 35's with work
    3" cons:
    Won't pull as many sluts at the mall
    Doesn't look as cool
    6" pros:
    Looks bad ass
    Sorta capable if you go with 35's
    6" cons:
    If you don't run 35's your truck looks funny
    If you do run 35's your gonna want gears to get power back
    If you want to run anything bigger than 35's prepare to break shit.
    Most 6'' kits runs blocks in the rear
    There are lots of options for both and 4'' kits are another option good luck with your endevors.
  9. Oct 31, 2013 at 3:57 AM
    Monster Coma
    Monster Coma Well-Known Member
    Corey
    Pittsburgh, PA/Houston, TX
    Sponsored by Mom and Dad
    :gossip: this thread is 3 years old
  10. Oct 31, 2013 at 4:02 AM
    bigtaco06
    Jared
    Nor-Cal
    13 TRD OR DBCB SB
    I can justify this by saying I'm extremely bored at work on my 11th hour of twelve. :anonymous:
    10trdtaco likes this.
