Fox COs top plate
Discussion in 'Suspension' started by ktmrider, Oct 22, 2010.
  1. Oct 23, 2010 at 9:41 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    ^^that is definitely not right. the top plate has to sit flush on the strut mount. same way with every other CO i've seen
  2. Oct 23, 2010 at 9:45 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Dr's mount the same way as the Fox. It was set up correctly.
  3. Oct 23, 2010 at 9:47 PM
    ktmrider
    ktmrider [OP] Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    How the hell do you get it through the coil bucket then? I couldnt get it through with the allan head bolt in the way.
  4. Oct 23, 2010 at 9:52 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You may have to rotate it one way to get it in, then rotate it to the correct orientation to line up the bolts. ALso, check to make sure the allen bolt is tight.
    anthony250f likes this.
  5. Oct 23, 2010 at 9:52 PM
    jr114
    jr114 Well-Known Member
    Jon
    SoCal
    Truck
    Icon Ext travel CO, Icon tubular uniball UCAs, Maxtrac Spindles, Icon RR rear w 2"aal.
    cant find a good pic, but yes they did come the same way. ill try to take a pic of it in the morning. too dark right now.
    ill look for a better pic in a minute, but im pretty sure that my icons were also like that with the top plate looking "upside down"
  6. Oct 23, 2010 at 9:53 PM
    ktmrider
    Junk
    sounds good ill try that right now.
  7. Oct 23, 2010 at 9:58 PM
    jr114
    Jon
    SoCal
    Truck
    x2
  8. Oct 23, 2010 at 10:00 PM
    The_Hodge
    SC
    that's crazy...apparently correct, but still crazy. i cant even fins another pic of a set of fox 2.5s w/ the top mount like ktm has. would explain the extra lift though
  9. Oct 23, 2010 at 10:08 PM
    ktmrider
    Junk
    I still couldnt get it in after rotating, I might have to remove the tie rod to rotate it in from the side.
  10. Oct 23, 2010 at 10:11 PM
    jr114
    Jon
    SoCal
    Truck
    ya remove the tie rod end. i did went in relatively smooth. just make sure you get a pitman arm puller..think thats what theyre called.. to separate the tie rod from the spindle. will make life much simpler
    fwiw..icons instructions, and some of the other ones i have seen, all mention removing the tie rod end.
    http://www.iconvehicledynamics.com/tech-support/instruction-manuals/ click on 5-8630 / 5-8635
  11. Oct 23, 2010 at 10:37 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    Yeah just measure how much shaft is poking out, pretty simple.
  12. Oct 24, 2010 at 11:33 AM
    numbah57
    numbah57 GIVE THE MALL A BREAK...WHEEL THAT SHIT
    kahai
    Maui, Hawaii
    09 tacoma 2.7 Beaten not Babied
    URD ARB G2 PELFREY BAMF LCE AFE
    Any updates to this?
  13. Oct 24, 2010 at 11:36 AM
    ktmrider
    Junk
    yeah I called the guy, he says they fit, they are like the donahoes but i cannot fit it through the coil bucket. It sucks. I guess im going to try to get a new bolt to mount the top plate to the coilover, one with a little more clearence because there is no way that it is fitting in there. I would love to have a close up pic of a set that does.
    they are not the long travel ones. they are 6 inches
  14. Oct 24, 2010 at 11:39 AM
    numbah57
    kahai
    Maui, Hawaii
    I have some pics on my phone, there not the best but if you wanna see them I can email or text them to you.
  15. Oct 24, 2010 at 11:42 AM
    #35
    jr114
    Jon
    SoCal
    Truck
    op..did you wind up removing the tie rod ends to try and rotate them into place?
    *just read your post about getting a shorter bolt. make sure to get one that sits as close to flush as possible.
  16. Oct 24, 2010 at 11:43 AM
    #36
    ktmrider
    Junk
    Im looking for a picture with the top plate mounted like mine. Thanks though.
    Like this one chris had
  17. Oct 24, 2010 at 11:44 AM
    #37
    numbah57
    kahai
    Maui, Hawaii
    No prob
  18. Oct 24, 2010 at 11:54 AM
    #38
    jr114
    Jon
    SoCal
    Truck
    hope these might help
  19. Oct 24, 2010 at 6:09 PM
    #39
    ktmrider
    Junk
    thank you all, I went to orchard supply got some new allan head bolts, grinded part of them down and installed. They ride really nice, but it was a pain in the ass to get here
  20. Oct 24, 2010 at 6:58 PM
    #40
    jr114
    Jon
    SoCal
    Truck
    glad you got it figured out. i know from reading your posts that it was a pain but hey you figured it out and did all the work yourself. just think of all the money that you saved, and the experience you gained and can now pass on to others when they come across similar issues. now...post some pics lets see it!!
