Fox Life!!! Anything Related to Fox Suspension
Discussion in 'Suspension' started by ThaiChillyTaco, Feb 25, 2018.
  1. May 31, 2021 at 2:57 PM
    #3061
    bttrbsch
    bttrbsch Well-Known Member
    Michael
    Bellingham, WA
    2018 Inferno Tacoma TRD Off-Road
    Kicker speaker upgrade Rockford Sub TRD Grill Raptor Lights Oedro Running Boards Seat Covers Black Emblems MBRP Exhaust Sound dampened doors Blacked out turn signals Pro comp 7069 wheels BFG KO2 285/70/17 Ram mount Joying Head Unit Fogs Soft topper canopy Fox 2.5 RR DSC Fox 2.0 RR rear HS AAL 1.5" rear plus overload (2" total) Center console divider Axe/Shovel Mount Traction boards 32" light bar Shift sense pro v2 iDrive throttle controller Xentec 35W HIDs Vair 88p air compressor Dome LEDs LED reverse lights + pods JBA Upper Control Arms Full size spare tire Driver seat riser
    One more question, I have a Stanley branded 5/16” punch that is just slightly too big for the collar… is there something unique about the harbor freight 5/16” punch that allows it to fit?
  2. May 31, 2021 at 3:55 PM
    #3062
    CAG Gonzo
    CAG Gonzo Ascendant Spaghetti
    2018 OR DCLB BarRed
    I think the hole on the collar is ever so slightly bigger than 5/16" as there's a small amount of play with that punch when I shove it in the hole, so to speak. Which I now realize only compounds your mystery. So perhaps quality of manufacture and tolerances?
  3. May 31, 2021 at 4:34 PM
    #3063
    G-shock!
    G-shock! Well-Known Member
    OC TACOMAN
    Orange County
    2GTRD4L
    Fox 2.0 frt/resi rr PolyPerf. UCAs
    Check out this thread on the Fox 2.0s. https://www.tacomaworld.com/threads...ar-2-0-remote-reservoir-review.433285/page-29
    BTW, is Tacos De Acapulco still off Nord? Go Wildcats!
    bttrbsch likes this.
  4. May 31, 2021 at 4:50 PM
    #3064
    bttrbsch
    Michael
    Bellingham, WA
    Interesting. I tried all the holes on the collar with my 5/16" and it didn't fit any. I just got back from Harbor Freight and picked up a tapered punch set... which looks like it won't work (the tapered portion is too small of diameter for the collar hole).
  5. May 31, 2021 at 5:13 PM
    #3065
    Codolten
    Codolten Well-Known Member
    Colten
    Orangevale, Ca
    08 Tacoma
  6. May 31, 2021 at 7:07 PM
    #3066
    CAG Gonzo
    2018 OR DCLB BarRed
    Maybe the HF punches are magic? That said, they feel sturdy enough and cost like 8 bucks for the set. I got a second set for easier spinning when the coilovers are off the truck and/or if the first breaks. I've used some of the other sizes for precision whacking of stuff with a hammer.
    bttrbsch[QUOTED] likes this.
  7. May 31, 2021 at 7:11 PM
    #3067
    G-shock!
    OC TACOMAN
    Orange County
    2GTRD4L
    Congrats! You are right, I was thinking Aca Taco! Soooo good… Tacos de is off Ivy. Chico was/is a righteous place for the college experience.
    To keep this on point, I just ordered FOX 2.0s front and rear w the resi. I’m doing an ECGS bushing, an Icon 3 leaf progressive AAL w newer Gen 3 leafs along w Wheelers bump stops. Looking at this brake line bracket bracket ( https://www.tacomaworld.com/threads...line-brackets-icon-deaver-old-man-emu.720254/ ) and JBA UCAs. Other considerations might be sway bar bracket relocate if it’s close to hitting and maybe a diff. Drop if I have driveline vibes. I hope this covers it all.
    Codolten[QUOTED] likes this.
  8. May 31, 2021 at 7:37 PM
    #3068
    Codolten
    Colten
    Orangevale, Ca
    08 Tacoma
    Perfect info. Thanks for the input. I’m thinking very similarly. I’ve read that the UCA’s aren’t always necessary unless you’re rubbing or going higher than 2.5”. Does that sound accurate or is there additional info I may be missing?
    Where did you order your foxes from? I seem to be finding a lot of back order/delayed shipping messages.
  9. May 31, 2021 at 7:41 PM
    #3069
    RangerComa
    RangerComa 58008
    Adam
    Marin, CA
    17 DCLB
    list is growing fast
    Tacos De is 5th and Ivy. The 2am diarrhea ticket. Go wildcats!
  10. Jun 1, 2021 at 7:10 PM
    #3070
    bttrbsch
    Michael
    Bellingham, WA
    Looks like the Harbor Freight punches are magic. I returned the incorrect set and bought the right one (the set of 5) and the 5/16” punch fit the collar. I followed Accutune’s instructions and lifted till my coilovers measured approx. 21” at ride height… this equals roughly 20ish threads showing on either side for me. Sitting at about 23” (hub to fender) or slightly more (not an exact level surface). I may not have the full 2.5” lift but am happy with the 21” height the coilovers are at now
  11. Jun 3, 2021 at 9:35 AM
    #3071
    bttrbsch
    Michael
    Bellingham, WA
    What compression settings is everyone using for both on-road and off-road driving conditions? I'm experimenting with my settings and am looking for what works for others who have the stock 600lb coil as well!
    I see earlier on the thread a few settings mentioned:
    "Does anybody have the DSC dialed in for on and off road driving? Right now I turned both knobs counter clockwise all the way, then the blue knob clockwise 5 "clicks" and the yellow clockwise 7 "clicks. " it was a kinda rough around town."
    "I'm at 7 from open on HS and 1 on LS. feels nice on shitty streets of Long Beach , CA"
    "I ended up fully closed on HS and 1 click from full open on LS for now. The extra caster I added to clear the 275 really has a negative effect on everything."
    In the 72 hours I've had the Fox installed, I'm currently running:
    - open in the rear (no weight in the bed)
    - 7 clicks from open Low speed (600lb coil, no armor in front)
    - 1 click from open High speed (600 lb coil, no armor in front)
  12. Jun 4, 2021 at 9:07 AM
    #3072
    sicki
    sicki Well-Known Member
    I run 1 click from open on everything until i hit the trails. I like it soft and have no sway bar.
    If Im driving up a twisty mt road, i close the LS knobs completely to keep sway down, and it works real well as replacement for my sway bar kind of.
    Once I hit the trail, i anticipate my speed and the terrain and close the knobs accordingly typically around 8 click on HS and 1 turn on LS. I probably rarely use the same settings each time i go offroad. Its fun to play around with them in the dirt and see the difference.
  13. Jun 4, 2021 at 10:16 AM
    #3073
    bttrbsch
    Michael
    Bellingham, WA
    Interesting. I'm currently the opposite, I keep LS closed for the road (control body roll) then open for the dirt (soft for the bumps). My HS is open most of the time - always want to eat up the sudden potholes or bumps.
    I'll try your settings though and see how I like - always fun to try different setups
  14. Jun 4, 2021 at 1:13 PM
    #3074
    sicki
    I like to drive fast when offroad. So tune for compression at High Speed. I have been on runs where Im stuck with slow people and I keep everything open to make it soft yes.
    A lot of it depends on how I feel I will be driving, and here in Los Angeles, my slow driving is on-road, because I have no choice haha.
    For example two weeks ago I was on the Mojave Trail, I was blowing thru my travel too quick and hitting the bump stops so I closed HS a few clicks more and solved the problem, acquiring a smoother ride for the speed I was traveling
    Tango Bravo and bttrbsch like this.
  15. Jun 5, 2021 at 3:25 PM
    #3075
    RYNO16
    RYNO16 Member
    2016 tacoma TRD Sport
    Prinsu design studios cab rack with 40 inch light bar.
    I bought the 5/16 punch from harbor freight but I didn't get the tapered. The straight punch works perfectly. I just had to crank on my collar today bc my front end was sitting lower. I used a combination of the spanner wrench and the punch.
  16. Jun 9, 2021 at 10:15 PM
    #3076
    chuymoreno
    chuymoreno Well-Known Member
    El Paso, Texas
    Tacoma SR5
    Can a bad alignment contribute to a stiffer ride?
    My current setup is 2.5 fox with dsc adjusters, 14” 600 lbs coils, C4 hybrid bumper and 12k winch.
    I took off some preload of my shocks, right now I’m at 21” from eye to eye since that is the recommendation. My concern is that I still feel like the ride is a bit too stiff even with the compression adjusters turned all the way to the - sign. BTW the shocks have been tuned by @AccuTuneOffroad with the street tune. I’m thinking I may need to remove more preload so that’s why I haven’t take it to get aligned.
    Before I installed the fox i was running king shocks and had some positive caster to help clear the tires.
  17. Jun 10, 2021 at 6:59 AM
    #3077
    AccuTune Offroad
    AccuTune Offroad Well-Known Member Vendor
    El Cajon, CA
    If you have the adjusters all the way open, at correct 21" shock length and still experiencing a stiffer than desired ride, it could be a few things. E-rated tires can cause a bit of a stiff ride, and those 14" x 600lb springs may still be too stiff for the amount of weight you have up front. Shoot me a message, or contact your sales rep with us and we can look at some options for you.
    chuymoreno[QUOTED] likes this.
  18. Jun 10, 2021 at 9:55 AM
    #3078
    bttrbsch
    Michael
    Bellingham, WA
    I'm always curious to hear how people think the Fox compare to Kings. I know Accutune recommends Fox, but how was your experience?
    I personally went with Fox as I could get them in 1 week from time of order, otherwise would have seriously considered Kings (35 week lead time!!!!)
  19. Jun 10, 2021 at 9:57 AM
    #3079
    RangerComa
    RangerComa 58008
    Adam
    Marin, CA
    17 DCLB
    They’re pretty much identical. You’ll never be able to tell the difference as long as valving and springs are the same. They are both progressive valved shocks.
  20. Jun 10, 2021 at 9:58 AM
    #3080
    bttrbsch
    Michael
    Bellingham, WA
    That's the consensus I've seen searching around TW. Happy with the Fox so far!
