Fox rear shocks, FJ on a Tacoma
Discussion in 'Suspension' started by 08pretaco, Apr 2, 2011.
  1. Apr 2, 2011 at 4:23 PM
    08pretaco
    08pretaco [OP] Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    Who is running the FJ length rear shocks on their 05+ Tacoma, keep in mind these are for the people running 1.5"+ rear lift.
    What did you need to do for bump stops? IE: possibly lengthening them due to a longer compressed length
    Thanks In Advance
  2. Apr 2, 2011 at 7:01 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Think Capt Morgan on the AZ threads is running those.
  3. Apr 2, 2011 at 7:04 PM
    Dibblit
    Dibblit Eh?
    Paul
    Stony Plain
    Truck
    Icon Suspension ARB OBA
  4. Apr 2, 2011 at 7:22 PM
    08pretaco
    Oliver
    az
    I know how to make them fit, remove the FJ bushings by removing the snap ring and replace with the Tacoma bushings.
    The only thing I was looking for was weather people are topping the shock out (not enough collapsed length).
    On that note: I will do a search but does anyone know the travel numbers of a J66 leaf pack?
  5. Apr 2, 2011 at 7:38 PM
    08pretaco
    Oliver
    az
    If this helps any the 5100 is:
    0" to 1.5" Rear Lift Shock Part #: BE5-C476-H0
    Extended Length: 22.94"
    Collapsed Length: 14.02"
    Oh and the FJ numbers are 24.45" extended and 14.85" collapsed. http://www.offroadwarehouse.com/prod...productID/3980
    So does the .83" really make too much of a difference on the collapsed length? Ill be running Timbren stops with the setup
  6. Apr 2, 2011 at 7:40 PM
    08pretaco
    Oliver
    az
    Oh and for 3-4" of lift:
    3" to 4" Rear Lift Shock Part #: BE5-B110-T5
    Extended Length: 27.28"
    Collapsed Length: 16.34"
    So from the numbers it seems like I SHOULD be ok especially since I will be running the Timbrens which "engage" start bumping sooner than stock...or is that the wrong way to think?
    If I add the axle shims to correct the driveline angle will that add that little bit of lift needed?
  7. Apr 2, 2011 at 10:23 PM
    08pretaco
    Oliver
    az
    Problem is I'm not running what I'm ending up with.
  8. Apr 2, 2011 at 10:23 PM
    08pretaco
    Oliver
    az
    That's reason for asking.
  9. Apr 3, 2011 at 3:16 PM
    ruler
    ruler Well-Known Member
    SoCal - Los Angeles - SGV
    08 Tacoma, TRD Sport, DC 4x4
    Fox Extended Travel Coilovers 2.5 (front), Fox 2.0 shocks (rear),Total Chaos UCA's, AllPro Expedition leaf pack, AllPro front plate style bumper,BHLM, GrillCraft MX series Grill, ATX Thug 17inch rims, Toyo Open Country MT (295,70,17), TRD CAI,Rear smoked LED tail lights, slimcubby HID Head Lights (50w 1200k), ADVMonster 60 Series 3600 Lumen LED Off Road Lights , Pioneer Avic-F700bt (navigation,head unit)
    I have the Fox Rear shocks from ORW ( Part# 980-02-372-A ) anyone know If I will have any issues running these with the AllPro 3 inch expedition leaf pack?
  10. Apr 3, 2011 at 4:46 PM
    08pretaco
    Oliver
    az
    DSM has billys with a 16" collapsed and 27" extended shocks that they recommend for the 3-4" lift. So I would look into shock with those specs.
