Fox Shox OEM Replacement Issues
Discussion in 'Suspension' started by mountainprimat2, Aug 31, 2012.
  1. Aug 31, 2012 at 7:22 AM
    mountainprimat2
    mountainprimat2 [OP] Well-Known Member
    Stefan
    Proctorsville, VT
    09 DC TRD Off-Road 6spd man
    Ironman Foam Cell Coilovers (FRONT), Rough Country (Rears), Toytec Bumps, ICON RXT Multi-Rate Leaf Spring, Ironman UCAs, Toytec Carrier Bearing drop, Toytec Front Diff drop, 33inch BFG KO3s on 17'' American Racing Wheels, TRD Cat-Back Exhaust, TRD CAI, Grillcraft Grilles(U/L), MOT's Badge Grille Mod (Red), Custom Fab Rear Bumper, Bushwacker Pocket Style Fender Flares, Leer Bed Cap, OEM Roof Rack, Husky Floor Liners, TRD 6spd Shifter Knob, Cobra CB w/ Firestick II, Interior LED Map(RED)/Dome(WHITE) Lights, LED Licence Plate Lights, Baja Designs LED Amber Fogs, Plasti Dip Badges, Trailer Harness Relocate
    just did some measurements to find that the drivers side sits a full half inch lower then the passenger side, and that should be the otherway around, ahh don't you love incompetent people who work on trucks......looks like I need to find someone who actually takes pride in their work and tacomas......ahhh cali looks sweet right about now
  2. Aug 31, 2012 at 7:26 AM
    Namyo
    Namyo -
    I held off on removing mine for years, finally after a ton of people here telling me to remove, and the links squeaking, I did. Drove on mountain roads and gave it hell to see how scary it would be, it's fine ;) Drives better actually.
    Plus your clunk will be gone, cranking the coilovers to match the back was not the problem. Tis sway bar.
  3. Aug 31, 2012 at 7:27 AM
    mountainprimat2
    Stefan
    Proctorsville, VT
    that might have somthing to do with the bottoming out "clunk" as the sway bar is far enough away and not touching the coilover it seems. Might be interesting to take it off just the same to check that feel out.
    Any other thoughts guys, this is helpful and I appreciate it. Might look to take a leaf out of the rear pack aswell.....thanks for the idea Tim
  4. Aug 31, 2012 at 7:30 AM
    mountainprimat2
    Stefan
    Proctorsville, VT
    Tis a good idea Namyo, I think I might take your advice this very weekend.
  5. Aug 31, 2012 at 7:34 AM
    Namyo
    Namyo -
    Shouldn't have to take a leaf out, I run the expo pack, and ride with locals that do also with no added weight in the rear end. No problem, just need the correct length shock for them.
    Do some flexing in the yard and check out the seen ;) Sway bar or the UCA may be making contact with the coilovers when flexed, double check the rear shock length as well with how far the wheel drops.
  6. Aug 31, 2012 at 8:07 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    How much fuel is in your tank?
  7. Aug 31, 2012 at 11:09 AM
    mountainprimat2
    Stefan
    Proctorsville, VT
    21 gallons soo that might have something to do with it, but then again she is almost on empty and is lower on the drivers side i.e. gas tank side
  8. Aug 31, 2012 at 11:11 AM
    sirsaechao
    Tim
    CA
    Yeah the springs should be DS and PS specific or left and right. Post the numbers on the springs and we can tell you.
  9. Aug 31, 2012 at 11:26 AM
    mountainprimat2
    Stefan
    Proctorsville, VT
    Are we talking to leaf springs or the coils?
  10. Aug 31, 2012 at 11:28 AM
    mountainprimat2
    Stefan
    Proctorsville, VT
    I feel like that is very possible as well because of the ride height and the geometry being off. We shall see when I back the coils down a bit and see how the geometry of the front suspension changes.
  11. Aug 31, 2012 at 11:36 AM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    The shocks might not have any nitrogen in them? My Icons at 2.5-3" ride damn good and CV's look stock. Something's binding (ball joints, cv's or sway bar) or the shocks need a charge!
    Just saw you have TC uppers and lowers, was everything greased and installed right? Make sure EVERYTHING's torqued to spec too! You should be fine w/o a sway bar with full mid-travel like that!
  12. Aug 31, 2012 at 12:09 PM
    sirsaechao
    Tim
    CA
    Leaf that's what's you are referring to right about the driverside being lower?
  13. Aug 31, 2012 at 3:48 PM
    mountainprimat2
    Stefan
    Proctorsville, VT
    no I mean the coilovers are cranked a little higher up on the driver side to account for the gas tank and drivers weight. Is this just a rumor that you should crank the driverside a little higher?
  14. Aug 31, 2012 at 3:56 PM
    mountainprimat2
    Stefan
    Proctorsville, VT
    I'm starting to think that I got shafted with the length of these shox. After adjusting the ride height down a bit the clunk has disapated because of the fact that this set of coilovers have a very small amount of travel to begin with.
    How many inches of "up" travel are you guys riding on? I literally had less then an inch at 1 1/2 inches of thread showing. Its insane ti think that people wanting to gain 2.5 to 3 inches of lift out of these are sacrificing bottoming the shock out to achieve height. There has to be a longer shaft and more equal travel for "up" and "droop".
    I will post pictures of what I'm dealing with in the morning. Thanks guys for helping out, i appreciate you staying with me on this thread and offering your $.02
  15. Aug 31, 2012 at 4:47 PM
    #35
    sirsaechao
    Tim
    CA
    My driverside front is higher.
  16. Aug 31, 2012 at 4:52 PM
    #36
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    If its stiff why don't you go with a softer spring? I don't know what spring rate it comes stock but you might look into it. adjusting the ride height really shouldn't affect the stiffness.
  17. Sep 1, 2012 at 4:40 PM
    #37
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    The heavier side is the drivers side with the battery, driver and gas tank being on that side......sounds like you got OEM replacement shocks instead of the ext travel ones. Ext travel only give you an inch of travel but that's about the best you can do. Every bit of lift you get comes from the down travel so youl lwant the least amount of lift pssible....the manufacture of the shock usually has them at the ideal performance setting which is usully 2" of lift. That gives 2" of downtravel or 3" if you have the ext version. You should be able to have them converted without buying new shocks.
  18. Sep 4, 2012 at 7:02 AM
    #38
    mountainprimat2
    Stefan
    Proctorsville, VT
    Yeah this was my fear, I have a feeling that they are OEM replacement and not extended travel. I wonder if fox would be down with helping out and converting them as part of a rebuild perhaps.
  19. Oct 16, 2013 at 12:54 AM
    #39
    ffdawson
    ffdawson Dirt Head
    Penngrove
    08 Tacoma Rugged Trail 6spd
    Kings, Armor, big taaaarrrs
    Hey I know this thread is a million years old, but I'm curious to find out what your solution was. I have exactly the same situation. Fox 2.5's in front, ran em with 1" of lift for ever and they are great. Just upgraded to fresh 285 MT-R's and needed a bit more lift to clear the tires, bumped the foxes up to 2.75 and now it rides like dog shit. Bouncy, clunking all over the place, UCA almost maxed out sitting still... Frustration!
    I need a bit of lift to clear the tires, but don't want it to ride like a f-Ing low rider mini truck!
    Any solution to your issues?
  20. Oct 16, 2013 at 5:22 AM
    #40
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    They may need a rebuild but most likely what your feeling is the lack of down travel? They're already extended to the point of only having 1.25" left before they're over extending. You could just trim up where it rubs and keep the lift low......think of a trophy truck with a lower center of gravity and big ass tires that fully stuff.
    Could be a combination due to the tires, heavier compound/tire pressure, etc?
