Frame Cleaning
Discussion in 'Detailing' started by Sideways1, Dec 6, 2019.
  1. Dec 6, 2019 at 9:59 AM
    Sideways1
    Sideways1 [OP] Old Dirt Rider
    Dan
    Portland Oregon
    2015 TRD Sport 4x4 DCLB Pyrite Mica
    ADS 2.5 with Extended travel/ADS 2.5 Piggyback rear. Dakars. Pelfreybilt Aluminum front bumper,Skid and Brute Force Fab HC rear bumper. 5 x SCS Stealth 6's in Matte Bronze wrapped in Nitto Ridge Grapplers. Wet Okole front and rear seat covers. Wilco Bed Rail Tire Carrier. Light Racing Upper Control Arms. Marshall Fabrications sliders with kick out. Mobtown Tailgate Reinforcement Skin. hyper15125 retrofits. And many many odds and ends.
    Howdy,
    I was wondering what you use to keep the frame looking like new. What I use now is Simple Green and pressure wash. But there is still a lot of wipe down and you have to scrub a lot. Is there a spray on hose off method that doesn't take a crew to get done. lol Just looking for a easier way.
    Be Safe..
    Dan
    GQ7227 likes this.
  2. Dec 6, 2019 at 10:01 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
  3. Dec 6, 2019 at 3:29 PM
    gorram
    gorram Well-Known Member
    2016 Limited
    Even with these ceramic coatings and a pressure washer the paint can't be really cleaned without something wiping it down. No way under a vehicle with those rough surfaces is going to fair better. And if there is a spray that could work it's probably not safe to be spraying around your vehicle.
  4. Dec 6, 2019 at 3:32 PM
    DrFunker
    DrFunker Well-Known Member
  5. Dec 6, 2019 at 4:51 PM
    RearViewMirror
    RearViewMirror Saw things so much clearer once you... were in my
    Craig Christ
    State of Love and Trust
    2023 Subaru WRX GT Manual
    Not so. 303 Aerospace protectant works wonders underneath a vehicle. I traveled in the mountains of Colorado all the time and before I went I'd spray the entire underbody with 303 and it just washed off. By the time I was done... it looked like it came off the showroom floor.
    Sideways1[OP] likes this.
  6. Dec 6, 2019 at 5:06 PM
    Sideways1
    Dan
    Portland Oregon
    Thank you
  7. Dec 6, 2019 at 6:03 PM
    NMTrailRider
    NMTrailRider Well-Known Member
    New Mexico
    A303 is a plastic/vinyl/rubber protectant. Not sure why you’d use it elsewhere? Genuinely curious here.
    Too Stroked likes this.
  8. Dec 6, 2019 at 6:12 PM
    RearViewMirror
    Craig Christ
    If I can find the pictures of the underside of my truck you'll understand.
    NMTrailRider[QUOTED] likes this.
  9. Dec 6, 2019 at 6:28 PM
    RearViewMirror
    Craig Christ
    Since Photobucket fucked me with all my pictures this is the only one that I could find that let you see how clean everything was under the truck. Spray 303 all over it and wash it off once you get back. Crawl under and clean what you can reach and it looks like it's showroom new.
  10. Dec 6, 2019 at 6:31 PM
    AR15xAR10
    08 SR5 4x4 V6 IndigoInkPearl ACLBFTMFW
    Simple green or if its really bad, purple power.
  11. Dec 6, 2019 at 6:38 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Wow, you guys sure have some pretty undersides! :rofl:
    I can see doing this where roads are salted, but not out here in the desert. We just run through puddles and call it good.
  12. Dec 6, 2019 at 6:42 PM
    Northern Taco
    Northern Taco Well-Known Member
    2022 Tacoma trd off road premium 2023 tundra trd off road
    That scrubbing bubbles foam shower cleaner is good stuff. Very strong and I've used it in the spring to clean mud and undercoating off the exposed sections of my new frame (almost 3 years old now) a good pressure washer makes a big difference as well
  13. Dec 7, 2019 at 5:54 PM
    Nickgbmx
    Nickgbmx Well-Known Member
    Nick
    2010 Tacoma Trd
    Shine supply classy chassis
    pudge151 and S550ilver like this.
  14. Dec 11, 2019 at 5:45 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    i will try some 303, had been using WD40 but it left it oily for awhile
    have no idea where you are located so my results may vary!
  15. Dec 13, 2019 at 4:41 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    I think the effect that he's seeing is much the same as you'd get from spraying any tire dressing / Armor All / silicone type product underneath a vehicle. It will look better. Does it actually clean or protect the underside? That's another whole discussion. I've sprayed Mequiar's Hyper Dressing in the wheel wells and on the underside of vehicles to temporarily make them look better too. (Old detailing trick.) It doesn't do crap to clean them, but they look better.
    NMTrailRider[QUOTED] and GQ7227 like this.
  16. Dec 13, 2019 at 1:02 PM
    BDSKJChris
    BDSKJChris Well-Known Member
    Albany, NY
    2019 Quicksand TRD OR DCSB
    you could try griot's garage foaming surface wash or Star-brite salt off, i had my undercarriage ziebarted when I got the truck, and before winter, i coated everything in fluid film, so my input may be useless.
    as far as products like simple green and purple power go, keep in mind they can harm aluminum and tend to leave a residue. so what is more important to you: removing every trace of road spray, or protecting the frame and factory coatings, paint, metals?
  17. Dec 25, 2019 at 11:23 AM
    madcratebuilder
    madcratebuilder Well-Known Member
    PNW
    ZR2 Deepwood Green
    skidz, gears, tune, zeon 12-s
    I have been using Chem Guys Undercarriage spray for a few years now, petroleum based it looks good and helps fight rust and corrosion.
  18. Feb 11, 2020 at 9:58 AM
    jay993
    jay993 Well-Known Member
    Jay
    09 TRD Sport V6 AC
    bone stock
    Anyone reapply undercoating or something like rhino liner?
