Frame coverage for 2011+
Discussion in '2nd Gen. Tacomas (2005-2015)' started by stefanlg55, Feb 1, 2019.
  1. Sep 27, 2020 at 8:48 AM
    #241
    420taco
    420taco Well-Known Member
    Justin
    PA
    Yeah because a steel Ford frame won’t rust in the same conditions...
    SR-71A likes this.
  2. Sep 27, 2020 at 9:29 AM
    #242
    Michigan Curmudgeon
    Michigan Curmudgeon Well-Known Member
    From fairly recent experience, my 2001 F-150 which I sold at 12 years and 135K miles that WAS driven in the winter here had only surface rust on the frame, nothing structural.
    I sold the Ford because I couldn't keep oil in the engine and got tired of replacing oil pressure senders, rear disc brakes, and EGR valves. Not because of frame rust. Then there was the mild annoyance of rebuilding the front end every few years. Ford has the worst ball joints and tie rod ends in the industry. I owned one, and only one, Ford truck.
    That Ford frame, however, would last 20 Michigan winters. My Tacoma? We don't know yet.
    Norton likes this.
  3. Sep 28, 2020 at 7:55 AM
    #243
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Cant have everything...
    Also, like others have said, nothing will last forever. Preventive maintenance and rust prevention are a must
  4. Sep 30, 2020 at 4:52 PM
    #244
    oly51
    oly51 Well-Known Member
    Gary
    S.E. MA
    2017 Tacoma, TRD Sport, MGM
    I called about the recall last week. While I was on the phone the service advisor looked up my VIN and determined that my '17 was CRC coated at the factory and only need to have the plugs installed. They were put in yesterday.
  5. Sep 30, 2020 at 5:02 PM
    #245
    Muddinfun
    Muddinfun Well-Known Member
    I w
    I would get that in writing if I were you. The 11-17 WEP is very clear that if it’s not CRC treated within 2 years of the original WEP notice, you don’t get a free frame.
  6. Sep 30, 2020 at 6:08 PM
    #246
    oly51
    Gary
    S.E. MA
    I looked at the frame and noticed a film coating near the openings on the frame that had the plugs put in.
    A friend who had the full recall done to his 2011 has the same film around the plugs.
    tacomich, SR-71A and Muddinfun like this.
  7. Dec 23, 2020 at 9:32 AM
    #247
    tacomajon
    tacomajon New Member
    jon
    medway, ma
    2011 tacoma sr5
    my 2011 tacoma with 54k miles has been at dealership since 27 nov. awaiting a new frame. Does anyone know how long I will have to wait? Will Toyota try to get me to pay for worn parts found during the disassembly/assembly? Any info will be greatly appreciated
  8. Mar 7, 2021 at 9:23 PM
    #248
    Toyota Tech 81
    Toyota Tech 81 Member
    Usually it could take 1-2 months just to receive the frame from the supplier but that was with the 05-10 frames... now with the new K0D recall who knows how long. At my dealership I am the tech who sprays the frames for the recall and haven't seen any with holes in them, just wish I had more frames to spray cause it's easy money and definitely worth it for the frames.
  9. Mar 16, 2021 at 6:47 AM
    #249
    jeffmansion
    jeffmansion Well-Known Member
    16UTILITY4x4MT2.7
    K&N 63 series CAI, AVS Vent Visors, 16x8 Level 8 MK6 Rims, 285/75/16 MT, Eibach Pro lift, JBA UCAs, Wheelers 3leaf AAL, DV8 skidplate, Westin bedmat, Backrack, swaybar delete, Magnaflow cat-back, 9Drive throttle controller, 2LO Mod, Cali Raised Rock Sliders, Tyger rear bumper, Chinese Body Armor front bumper clone, 10K pound Winch, Smoked headlights, LED Bulbs.
    My local dealer is pushing me to get this KOD frame recall done. I have applied Krown undercoat on my truck annually. It has a thick coat built up. Will the KOD recall affect my existing undercoat? Will my existing undercoat have to be removed anywhere? The dealer is telling me no, and it is only applied to inner frame rails. My hesitation is I don't want the existing krown removed/messed with. The people that Krown my truck said the inner frame rails are already krowned, and they would have to remove my exisitng krown undercoat to put the toyota stuff on. Does anyone know what the actual answer is?
  10. Mar 16, 2021 at 7:33 AM
    #250
    Michigan Curmudgeon
    The procedure includes cleaning and drying the application site. There is no mention of solvent removal of existing coatings. They are instructed to use a wire brush, an air hose, and to inspect with a scope through the frame holes to check for a specified level of cleanliness. The wax is obviously intended to be applied to a clean bare frame.
    What they actually do to comply with the service bulletin will have nothing to do with your wishes and what you might be told by the dealer may not be anything resembling the truth.
    If you comply or not depends on how badly you want the 12 year frame warranty.
    jeffmansion, SR-71A and Muddinfun like this.
  11. Mar 16, 2021 at 8:21 AM
    #251
    Toyota Tech 81
    I am a tech at a Toyota dealer and the only one able to spray them and as per the technical instructions if a frame is previously sprayed we are to contact toyota quality compliance and they tell us what to do.
  12. Mar 16, 2021 at 8:43 AM
    #252
    jeffmansion
    16UTILITY4x4MT2.7
    interesting, thanks.. I am honestly not very concerned about this rusting as im very krowned/undercoated, and was told all those areas are already sprayed. Just trying to decide what's best to do here.
  13. Mar 16, 2021 at 8:51 AM
    #253
    Toyota Tech 81
    I hear ya.
    Now on my end it's a big money maker cause it pays me a ton and I get it done quick and perfect. Hell I've been handing out business cards for free oil changes to tacos I see on the street just so I can do the recall and my manager approved of that. I don't upsell anyone just the spray is what I care about lol.
  14. Mar 16, 2021 at 8:51 AM
    #254
    TacoFergie
    TacoFergie Well-Known Member
    Iowa
    Would you happen to know if they would perform this bulletin if my truck is out of the "approved" states for free? I live in Iowa and they use quite a bit of salt and liquid brine but for some reason it is not listed on the service bulletin.
  15. Mar 16, 2021 at 8:56 AM
    #255
    Toyota Tech 81
    It's actually a recall and has to be a cold climate state either purchased in one or live in one if im not mistaken. If your ok with sending me your Vin number I can tell you if you're truck is in this recall..
  16. Mar 16, 2021 at 9:07 AM
    #256
    TacoFergie
    Iowa
    Yup, it was bought in IA by the original owner and then I purchased it 4 years ago in IA where I also reside. I was just surprised that IA and NE weren't included considering we have just as much cold/snow and salt/brine used as most of the states listed. When I was a Toyota Tech (until 2009) we did a handful of frame replacements even early on. But its been 12yrs since I have worked at Toyota dealer! haha I'll PM you with my VIN shortly
  17. Apr 19, 2021 at 9:45 AM
    #257
    bishtaco
    bishtaco Well-Known Member
    Virginia
    2013 TACOMA BASE TRD OR
    I was in the dealer today to get an oil change and the service advisor told me about this campaign. I didn't get a letter in the mail but the notices are on the Toyota Care website. It's free, takes two days and I get a 2021 Sport loaner so I said why not. The campaign could be a good thing.
  18. Apr 19, 2021 at 12:59 PM
    #258
    ace96
    ace96 Well-Known Member
    Western KY
    '11 SWB DC TRD SPORT
    AVS bug deflector, Weathertech digital fit floor mats, TRD skid plate w/ Sockmonkey decal, SOS Cocept sliders w/ Line-x, Pioneer 3500, Hybrid Audio Technology Mirus 6X9s & 6.5s, back up cam mod, Wet Okoles-front & rear, TRD exhaust, 17X9 XD Spy w/ Falken Wildpeaks, Avid light bar
    I would get it done. If you don't and you later have a frame issue, Toyota could leave you on the hook for repairs.
    jeffmansion[QUOTED] likes this.
  19. Aug 5, 2021 at 9:47 AM
    #259
    Roll_Terps
    Roll_Terps Well-Known Member
    Maryland
    2017 SR DCSB White
    So I brought my 2017 truck to the dealer for the frame rust service campaign in July 2020 and they performed frame inspection, found no frame corrosion, applied a protective coating (Nox Rust) and frame hole plug kits (not rust holes, just factory frame holes to prevent water getting into the box portion I guess?). They put ZKA as the service performed on the paperwork.
    Now I'm getting calls from the dealer to bring it back in for the K0D. I tried to explain to the service advisor that I already had it done, but then they said if I don't bring it in, I wouldn't have the 12 year extended frame coverage. They were able to pull up the service record, but said "this is a new, different recall." They offered me a loaner for the time its in, so I'll do it, but I'm pretty sure they'll put it up on the lift and the tech is going to say its already been done and it will be a big waste of everyone's time.
    Is my understanding of difference between ZKA and K0D correct? ZKA is the inspection to determine if frame replacement is necessary. K0D is the application of preventative coating. If they applied a coating last year, then they did KOD while performing the ZKA inspection, right?
  20. Aug 5, 2021 at 10:21 AM
    #260
    ace96
    Western KY
    Why would you not do it? Other than time you are not out anything.
