Frame Protection... Alternatives to Fluid Film
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fitz235, Dec 23, 2016.
  1. Dec 23, 2016 at 4:19 PM
    anonemoose
    anonemoose Well-Known Member
    Bill
    Big Pine, Calif
    2015 White TRD Sport V6 DCSB
    Ride-Rites, Everything Weather-Tech Makes Added some 12 volt outlets with relays
    But we are leaving this Mexican slum next year and moving to the Eastern Sierras. Traveling with our tear drop we have hit some bad weather and plan on some winter camping so I am looking for truck and trailer protection.
  2. Dec 23, 2016 at 4:28 PM
    Fitz235
    Fitz235 [OP] Well-Known Member
    Rob
    New Hampshire
    Black '22 DCSB TRD Offroad 4WD
    - TRD T4R Pro Wheels - TRD Lift Kit - TRD Skid Plate - 265/70/17 Toyo Open Country 3's - OEM Bed Lights - OEM Bed mat - Alpharex Tail Lights - TacomaBeast LED Interior Lights - Green Lane Offroad Aluminum Sliders - Place Holder for More Bad Financial Decisions...
    What about WD-40? That was the original intent of this stuff to displace water, and prevent rust.
    When I used to ride, I tried all kinds of the latest, and greatest chain lubes. All attracted dirt (which speeds the wear of the chain), and ultimately just ended up using good ole WD. worked as well, if not better. Just needed to lube it more often was all.
    Obviously a different application, but it's an oil that protects from corrosion, and doesn't attract dirt/debris.
    surforegon likes this.
  3. Dec 23, 2016 at 4:33 PM
    Markcal
    Markcal Well-Known Member
    X2 - These aren't being installed after doing the LSC when they should be, all the newer 2nd generations have them installed from the factory for a reason and I know they will extend the longevity of your frame.
    Fitz235[QUOTED][OP] likes this.
  4. Dec 23, 2016 at 4:37 PM
    Sugar Silva
    Sugar Silva Well-Known Member
    Dave
    San Diego, CA
    16 Toyota Land Cruiser
    Kings Sliders TRD Rock Warrior Wheels Tint
    I think you've been reading rust threads too often and it has you paranoid. There's really no need for rust prevention in SD.
    Edit: I see you're moving to the sierras.
  5. Dec 23, 2016 at 4:40 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    WD will dry out rubber components and stink..... not as much as FF though.
  6. Dec 23, 2016 at 4:42 PM
    Fitz235
    Rob
    New Hampshire
    I would say based on what every frame pic I've seen shows (including my own), that the plug kit would probably do more than FF, or any other frame coating would for the Tacoma frame issue. They all rotted from the inside out. In fact I always thought my frame looked pretty good for a 10 year old truck that lived it's whole life in NH (besides the obvious holes by the cats). Only a little surface rust visible here, and there.
    It says it in the CRC .pdf. To paraphrase: "Install to prevent salty spray from entering the frame".
  7. Dec 23, 2016 at 4:44 PM
    Fitz235
    Rob
    New Hampshire
    WD would be like a sweet perfume compared to FF.
    surforegon and File IFR[QUOTED] like this.
  8. Dec 23, 2016 at 4:49 PM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    Plug kit will help a little but nothing like fluid film. Your still going to get spray up in the frame.
  9. Dec 23, 2016 at 4:50 PM
    Markcal
    I saw a YouTube video of a previous FF user change over to chain bar oil used for chainsaws. He said that type of oil would adhere better than FF, but is harder to apply, so you may have to thin it out before applying.
  10. Dec 23, 2016 at 4:57 PM
    Fitz235
    Rob
    New Hampshire
    If I had to pick one over the other, I would go with the plugs. I definitely advocate getting some type of coating inside the frame if you can. I like the idea of something that doesn't attract dirt/debris though.
  11. Dec 23, 2016 at 5:01 PM
    jake72
    Jake
    N.E. PA
    The dirt and dust that sticks to fluid film actually helps make a better protective barrier. Don't put too much faith in that plug kit you may end up sorry.
  12. Dec 23, 2016 at 5:02 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Rust Cure Formula 3000
    Fitz235[OP] likes this.
  13. Dec 23, 2016 at 5:38 PM
    Markcal
    Nov 22, 2013 at 6:39 PM
    #207
    DoorDingIntentionally obtuse
    That Rust Cure 3000 is like maple syrup for your frame. Strong stuff.
    Sugar Silva likes this.
  14. Dec 23, 2016 at 5:43 PM
    OZ-T
    Peter North
    British Columbia
    It works
  15. Dec 23, 2016 at 6:26 PM
    #35
    Fitz235
    Rob
    New Hampshire
    At this point, I have FF, and the plug kit. Not much more I can do. Not too crazy about the FF though. It'll do for this winter, but looking for alternatives for future winters.
  16. Dec 23, 2016 at 6:30 PM
    #36
    Fitz235
    Rob
    New Hampshire
    That stuff looks promising. I like the comment about no sticky residue.
  17. Dec 23, 2016 at 6:43 PM
    #37
    OZ-T
    Peter North
    British Columbia
    It displaces water too
    Norton and Fitz235[QUOTED][OP] like this.
  18. Dec 24, 2016 at 12:14 AM
    #38
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Wow ! Don't get no betta then dat - thanks man. Just thought of a question - do you have a 4.0 or 2.7 ? That would effect the part number for the plugs - I have a 2.7. Thanks.
  19. Dec 24, 2016 at 12:43 AM
    #39
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    He posted a flurry in his last couple of days here then complete silence. Hope he didn't die or something. Was darn good to have around here posting.
    beertimecontinuum likes this.
  20. Dec 24, 2016 at 5:26 AM
    #40
    Fitz235
    Rob
    New Hampshire
    No problem brah.
    As far as a difference in kits, I'm not sure. I would think there wouln't be any difference. In either case, the kit I ordered, was the part number I got from @Markcal, who also has a 2.7. I have the 4.0, and everything fit.
