Frame Replacement - Lessons Learned?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NumNutz, Dec 11, 2018.
  1. Dec 11, 2018 at 6:17 PM
    NumNutz
    NumNutz [OP] One of the original 7928
    Virginia Beach, VA
    07 Tacoma 4x4 - Kings, TC, Dakars, broken stuff
    Lots.
    Great. Thanks for the info!
    george101 likes this.
  2. Dec 12, 2018 at 1:11 PM
    maal11
    maal11 Active Member
    CT
    2020 MGM TRDORDC
    Redline Hood Struts Access Literider Tonneau Cover OCD Console & GB Organizer Bed LED Plug/Play Lights NOXUDOL Undercoating MESO AT Bucket
    Had mine done beginning of 2018 and was given an all clear on additional parts - my dealer just wanted to complete the frame without caring for my truck. Here is my list of items I should have had done and am in the process of updating:
    1.) Transmission Lines - made of same stuff as brake lines that are replaced with frame
    2.) Power Steering Lines - same as above
    3.) Lower Oil Pan
    4.) Exhaust Headers
    5.) All Shocks and Springs - new leafs included in frame replacement
    6.) Upper Control Arms - lower arms included in replacement
    7.) Transmission Flush
    8.) Front, Rear Diff and Transfer fluid changes
    9.) Motor Mounts - if over 150k
    10.) Tie Rods and Stabilizer Links with alignment
    11.) Steering Intermediate Shaft
    I took some photos of the new frame in the crate and the old frame once removed. I will try to find these and update this post, but OMG the old frame was really rotted. The frame could have been built better, but I doubt Ford would replace a frame with 160k miles. Still love my truck!
    Rick's 2012, cleats50 and george101 like this.
  3. Dec 12, 2018 at 5:11 PM
    NumNutz
    Virginia Beach, VA
    Lots.
    Thanks for the reply. I'll look into a few of those
  4. Feb 16, 2019 at 11:56 AM
    NumNutz
    Virginia Beach, VA
    Lots.
    Charles Barker Toyota in Virginia Beach will be finishing up with the truck early next week. The dealership told me this is the worst truck they've ever seen. They've spent over $17,000 so far in the replacement of the frame and additional parts.
    5qXFw-HOylg9PBymw3Y1a0j8anJ4LkZ30NmkTl3d_472bc49581606e51fd76bf56d3225c3976a1cb99.jpg
    5dgHkbZcZfcOqpC8XrmXt_FiK3Il8R0WDtKDTfxg_6b9ac874a4f84b43c0c2b6f1ff3fd53c2631a770.jpg
    q3lqRYPUQLFLbIKCoUqkNqEAx6O5CqKKxa_nie49_bfafb6acda61bcc7e5b20f59f9a82e6f558877ff.jpg
    OyJMx1Rp5BOIkcW9EX_mmpeYUc8dnqVJXUEDHyQ9_144e9ac145fb734c6a41291909f6b6d7263d2883.jpg
    9qL-vyabGBmHLOPLetx48Gs9nggBr0n5TXhNqB6g_342fd0fcaf307d4cff4345d9039ce6cac03e1ce9.jpg
    I7irpQcXQMScobwyZeuna5r5HuH_zbs9fkNEtQBc_9c8da5916ba564950c2022086d12a79cdd49fe06.jpg
    YONqIYEOW3qNGmAXDgb0KzugDQlpREg9kiCm335l_8ad61579739c3609bd631e24127e3c1a1d73363a.jpg
    MFXzOF7-X_kTAa548d17JPQ0S9ZjewbzxZuGsZSX_51a872b818f118f7ef75ddcae035e1b8e870c798.jpg
    TRGt1aiuoSOJGvB4HTf7cEMmHDjcKjXisWXy60Sp_48e095ba7a0b7b75af6938645d01ff67cefd0a11.jpg
    rN6jLeBDz0siCYHGOpnAERhUMQMwrY8sPkgA-012_291419bdf4007ef2b4ea9a0b053732c7add073e5.jpg
    uQQ8Jr5kfQGUklop5BrRXa7kIbm8uV5r-Vnkm95q_43641a7e841258808244be78e4e0a973dfeefbc6.jpg
    H7nbFarEOl26VWL55xUbJVB2JvriUTK-8jDNWbmP_4e3059ca3ac308336da146b696c5678404adec6e.jpg
    s4hewclcaWulloGpPAfkmcfNm4yCfZ1-Qd6X5ExZ_df2e1bf215e95f2abf40624cfdbe7a4b5fcad932.jpg
    1g9LkgmN8X0fmatsm8bTlEH3Fn1R49GpBn7cjXwU_781c0f5e1669eee5608384fa348ec5e8c363fae1.jpg
    P9h9SnRjutJR67oPg51fY3rJxqWBA9sQRNKooM2__251b64c8c8bd765f20f20fe160a52e73f6af72d1.jpg
    sKa8_yfaF4tYIpIWn0nyr7Da7_sIkVAhMEcj7dOt_11f6e9620e50026c968c8f3c460a47560b648f36.jpg
    kJkRprebbLmqt2tTOYeKW9pvUohEGA9QBrzVDggL_188cc0940a2ba5a5a6e3ff0f2b242fb3f65f138d.jpg
    rY8_z5Q5-J2Om6xv4FU92GB6xEziH-iIrhhs1d5c_9a6fe006fe142c8a49eb8a3775fc4e6f67bb050e.jpg
    Rick's 2012, b_r_o and 91859706 like this.
  5. Feb 16, 2019 at 1:14 PM
    NumNutz
    Virginia Beach, VA
    Lots.
    Of the pictures attached above I'd like to draw attention to several specifically as the dealership is recommending I replace the following parts:
    Front brake calipers, pads, rotors, and brake lines- $1,118.24
    Front crank pulley and crank seal- $396.19
    AC Compressor and clutch- $1,092.13
    Water pump- $252.60
    Front timing cover reseal- $1,005.94
    Rear main seal- $437.71
    Total- $4,560.98 (all labor costs and tax included)
    The first photo is a picture of the front timing cover. It's obviously leaking. I was looking to see if someone would provide an opinion on how bad they think that is? The dealership wants to charge $1,006 to reseal it, but I'm more inclined to let it ride and replace the engine when the time comes down the road (truck has 135k miles on it). The second photo is of the rear main seal and really I have the same question as above. Is it worth replacing for $437?
    Di6uQRh6wY-yhhqMJyIHOxvpZFK3r7bUZ0S_SQz5_53cadf77dd78c91ab880eff0f25dd9604a7fbb10.jpg
    f8BBv-ono1_8FOGsldAzbCJdKmC6xMxiq2bMvFo9_193d4878c864cfdfebd657a331a6f797dd848059.jpg
    The calipers are obviously fucked. Based on the other people's experience, should they be covered under the warranty?
    eVLqjbZIc_L3pys2F6yTMqle3jBH1NFxOFJoUK9Q_491a458a6f29e7725df05e9c8bb6ce623296e4d2.jpg
    Jeffch and DLillest like this.
  6. Feb 18, 2019 at 10:12 AM
    NumNutz
    Virginia Beach, VA
    Lots.
    I went ahead and had the dealership replace some parts, but I couldn't stomach the OEM dealership prices. Instead I went with aftermarket parts I picked up at AutoZone:
    4Seasons A/C Compressor and Clutch - 639392
    Duralast Waterpump - DWP-1981
    Dorman Harmonic Balancer (Crankshaft pulley) - 594-350
    Duralast Crankshaft Seal - 2025
    It probably ended up saving about $500 on parts.
    I'll probably need another $500 in brake parts.
    Rick's 2012 and Jeffch like this.
  7. Feb 18, 2019 at 10:21 AM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Dammm!!
  8. Feb 18, 2019 at 10:39 AM
    NumNutz
    Virginia Beach, VA
    Lots.
    No it hasn't. It spent 4 years in Upstate NY while I was in college and it also spent a couple years in Corpus Christi, TX being driven on the beach a decent amount. I thought I did a decent job washing the undercarriage after each use, but I didn't do well enough. While I don't regret enjoying the truck on the beach, I wouldn't do it again knowing what I know now.
    However, I have to give it to Toyota and Charles Barker specifically for spending over $17,000 on my frame replacement at no cost to me.
    I'll end up writing them a check for around $800 for additional work, parts, and time they've put in. Another $1,000 in aftermarket parts they installed.
    When I pick up the truck next week they will have replaced my:
    - Rack and pinion
    - Tie rod ends
    - Intermediate shaft
    - Alternator
    - Serpentine belt
    - Idler and tensioner pulleys
    - AC Compressor and clutch
    - Front diff drain plug
    - A front transmission line bracket
    - Front crank pulley and crank seal
    - Water pump
    - A fuel pipe clamp
    - Positive battery terminal
    That doesn't include any of the parts that were replaced covered under the frame warranty.
    To answer your question, I'd say their communication is above average. I think their master tech doing the replacement is pretty knowledgeable. They gave me a little bit of a hard time for some aftermarket parts (bumper, winch and suspension) wanting to charge me extra labor for taking that stuff apart and putting it back together. After I called their bluff on that things went pretty smoothly.
    Rick's 2012 and 01x4[QUOTED] like this.
  9. Feb 18, 2019 at 11:41 AM
    NumNutz
    Virginia Beach, VA
    Lots.
    Definitely. Do you have any leads on a shop that will spray fluid film for me? I'm in the middle of workups and don't really have the time.
  10. Mar 15, 2019 at 2:01 PM
    NumNutz
    Virginia Beach, VA
    Lots.
    I picked the truck up today. I'm pretty happy. I ended up paying:
    $535 for mostly labor to Toyota
    $663 to Camelback Toyota for parts
    $644 to Rockauto for parts
    $685 to Advanced Auto for parts
    Total = $2,527 OTD
    The master tech said this was the most painful replacement he's ever done and it took him 30 hours for which a normal Tacoma frame replacement takes about 15 hours.
  11. Mar 15, 2019 at 2:16 PM
    roadking1
    roadking1 Well-Known Member
    n.j.
    2023 Solar Octane TrdPro 6-speed manual
    Probably a good idea to bring the poly bushing kit with you .I installed mine after the frame replacement while trying to locate a noise.the dealer did not install the original bushings correctly.bent bolts and lopsided bushings.
