Frame restoration - did it myself
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SeNate, Mar 23, 2015.
  1. Sep 11, 2015 at 4:07 PM
    #61
    Mad Man Marty
    Mad Man Marty Well-Known Member
    Marty
    PA
    2007 Tacoma SR5 TRD Sport
    6speed, TRD intake, bed tie downs, weathertech rear,Tint
    Your both welcome.
    Thanks for the info Alpha.
  2. Sep 11, 2015 at 4:43 PM
    #62
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    Crom likes this.
  3. Sep 21, 2015 at 6:02 PM
    #63
    putter2010
    putter2010 Active Member
    Terry
    20104x4regcab
    3 inch lift,bull bar,chrome grille, 265 65 18 BF Goodrich tires
    How do you spray the fluid film on frame?
  4. Sep 27, 2015 at 1:34 PM
    #64
    tacoma4
    tacoma4 Well-Known Member
    I used a grinder and rustoleum spray paint on the rear axle a year ago and it already was chipping and falling off, so I decided to do it right this weekend. Followed these instructions over the course of 2 days and it looks great now. Hoping it will hold up better than before. I put 3 coats on to be sure, thanks for the how to.
  5. Sep 27, 2015 at 1:43 PM
    #65
    millertime89
    millertime89 Flatlander
    Erik
    Saskatchewan
    06 TRD Sport DCLB 4x4
    Yes sir
  6. Sep 30, 2015 at 11:54 AM
    #66
    SeNate
    SeNate [OP] Well-Known Member
    Salt Lake City
    05 SR5 TRD 4x4 6spd
    Satoshi Grill (HomerTaco), Ambiguous' headlights, refinished my frame with POR-15 after half a week of prep and rust removal
    nice work. It should hold up, mine still looks great and it's been about a year.
  7. Oct 15, 2015 at 6:29 AM
    #67
    jjsul
    jjsul Well-Known Member
    James
    New Hampshire
    95.5 OME
    I'd like to do this to my truck before the winter hits. I just moved back to Massachusetts and brought with me a 95 Tacoma from California.
    The frame is almost all rust free maybe a couple little spots here and there. I'm wondering if I need to treat sand or scuff the frame before applying POR 15. Could I just wash the frame down and then paint right on top of the original topcoat? Or should I sand it first?
    Also I'm wondering if anybody's been coating parts other than the frame. Control arms? Looks like people are doing the rear axle.what about the front differential?
    Cheers,
    James
    Toyko Joe likes this.
  8. Oct 15, 2015 at 12:44 PM
    #68
    SeNate
    Salt Lake City
    05 SR5 TRD 4x4 6spd
    If your frame is mostly rust free, just paint POR-15 over the top of the rust spots imo. Make sure it's not flaky rust, maybe tap it with a hammer and sand it a bit. POR-15 loves to stick to surface rust. In your case, I'd hit the frame (since its still in good shape and not rusted everywhere) with fluid film linked in a post above.
  9. Oct 15, 2015 at 1:14 PM
    #69
    ColoradoTaco
    ColoradoTaco Well-Known Member
    Boulder
    2013 DCSB OFFROAD
  10. Jul 2, 2016 at 4:08 AM
    #70
    WrecklessWilli
    WrecklessWilli Member
    Austex/Telluride
    2009 Access TRD OR
    nada
    I'm curious if anyone here has tried Waxoyl ? Coming from a Defender 90, which are destined to be rust buckets if not treated, this is the number one product most owners use.
    No affiliation but Rovers North carries it here in the US. The company says one application for the life of the vehicle. They have one product that is used for cavities, and I'm guessing it would be the ticket for the frame cavities.
  11. Jul 2, 2016 at 4:17 AM
    #71
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    What happens to the bolts that get covered with por15? Can I still remove the bolts after that section is treated if I need to for some reason?
  12. Jul 2, 2016 at 7:21 PM
    #72
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Good question. I wouldn't coat the threads. Maybe put grease on them just before you paint.
    I am putting rubber caps or hose on most of the larger bolts.
  13. Jul 5, 2016 at 9:36 PM
    #73
    thumpper
    thumpper Well-Known Member
    Bob
    Nebraska
    2008 Taco
    To the OG poster I may add to this if you don't mind. I did very similar project with mine but used a brush to do it and then used rattle can flat black paint to get the 'shine' off.
    I tried to avoid threads on the hitch area but then again I used a brush. I've also heard of guys wrapping their brake likes with aluminum foil if they are going to spray the frame.
  14. Jul 5, 2016 at 9:47 PM
    #74
    QMEDJoe
    QMEDJoe Proverbs 3:5-6
    Joe
    Columbus Grove, Ohio
    2003 Tacoma, V6, 5 speed, 4x4.
    Fox 2.0 Coilovers in the front and Fox 2.0’s in the rear, Total Chaos UCA’s, Al-lpro expo leafs, K&N cold air intake, TRD headers,Magnaflow catback exhaust,URD short throw shifter, switched out my 60/40 bench seat for some Tacoma Limited seats, Replaced the vinyl shift boot for a leather one, completely soundproofed the cab w/ Frost King. Replaced stock radio with a Pioneer AVH series head unit. Focal component system w/a 10" sub powered by 2 Alpine amps. Weathertech floor mats. Line-X'd the bed. SCS Ray 10’s, Installed an A.R.E. MX series camper shell. All-Pro Apex front bumper w/ All-Pro skid plates all the way back to the Trans. Low Range fuel skid plate.
    WOW! Great job! I literally just got back from applying Fluid film. My frame isnt that bad at all. A little fairy dust on it from parking it at the dock in Louisiana (I work in the GOM) I'd definitely love to spend a good portion of the weekend and do this. I don't have much prep work because I think the frame was replaced. I would just like the reassurance that my frame is completely protected from the elements.
    GQ7227 likes this.
  15. Aug 14, 2016 at 1:10 PM
    #75
    SeNate
    Salt Lake City
    05 SR5 TRD 4x4 6spd
    The best part of all of this is that I received a letter from Toyota wanting to inspect my frame. It seems they took their time getting to me in the list. I tried to take it in to a dealer before I did this work and ask them to look at it. I know the frame is fine, but I guess I can take it in to hear them say "oh it looks great".
    This post isn't a sticky, so it does sometimes resurface. I wonder how many people are looking for this kind of information? Maybe we could get a frame sub-forum?
    Manfred likes this.
  16. Aug 15, 2016 at 8:20 AM
    #76
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    That is a good idea. @tcBob ?
  17. Aug 15, 2016 at 8:30 AM
    #77
    tcBob
    tcBob Gringo Bandito Moderator
    Bob
    07 PreRunner SR5 V6 Black
    Stickied... And will be mentioned in the upcoming email newsletter to everyone
  18. Aug 24, 2016 at 2:54 PM
    #78
    andrew8404
    andrew8404 Well-Known Member
    ANDREW
    Albuquerque, NM
    17 DCSB TRD OR 4x4 (Sold) 19 Ford Ranger Sport XLT 4x4
    Good info need to get this done.
  19. Aug 25, 2016 at 11:56 AM
    #79
    SeNate
    Salt Lake City
    05 SR5 TRD 4x4 6spd
    If I did this again and could have anything.
    • remove the bed of the truck (half the truck easily reached)
    • warm weather and outside
    • a lift when I do the front half of the truck. Being able to walk under it would be amazing, or just having a creeper helps.
    • when the 2nd coat of POR-15 is tacky, have some auto paint of your choice (flat black or chassis black look the best) and spray over the POR-15 when it's tacky but not wet.
    deanosaurus, GQ7227, Tbrom and 3 others like this.
  20. Aug 25, 2016 at 1:25 PM
    #80
    andrew8404
    ANDREW
    Albuquerque, NM
    So does that rattle can help maintain the Por 15 whats the reasoning behind it?
