Frame rot got a passing grade.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Darkhawk, Jan 24, 2016.
  1. Jan 25, 2016 at 12:53 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I would be worried about that. I would think you would want a dealership that has done several frame replacements already.
  2. Jan 25, 2016 at 12:54 AM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    I have a few buddies at the Toyota dealer home, they said two days to get one done. Granted that was for 1st gens but I can't see them being all that different.
  3. Jan 25, 2016 at 2:37 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    They may pay 40 hours but not at the normal shop rate .
    Unless Toyota pays quite a bit more warranty rate then others.
    2 people 40 billable hours is not very long.
    No wonder they replace all the other corroded parts it would take much longer .
    Trying to remove things
  4. Jan 25, 2016 at 4:01 AM
    85GT 79FJ40
    85GT 79FJ40 Well-Known Member
    Ken
    New Hampshire
    19 TRD Sport DCSB 6M - 2017 Honda Africa Twin
    I could be wrong but I think the TSB stated the warranty was 10 years or 15 if you had the CRC coating done after the first inspection. If the hole wasn't seen before that 10 year mark the OP might be hosed. It could be repaired but in that spot you would probably want to pull the motor. I fixed a 96 with a rotted frame a few years back that the owner was too lazy to get re-inspected by Toyota and his time ran out. Of course I was the fool who bought the truck afterwards.... Thankfully it was cheap and mint otherwise. FWIW rusting frames on Toyota's or any other truck for that matter is nothing new in the states that see road salt. It's why you almost never see anything old on the road. I've seen fullsize Fords and GM trucks with rotted frames that are 10-12 years old also.
  5. Jan 25, 2016 at 5:10 AM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    They don't have 2 people on the job. Usually takes one guy 1.5-2 full days usually 14-18 hours. Depending on a few things I've seen take longer. Around here usually every bolt is rusted up and some stuff it just makes more sense to have them replace while doing the swap. They try to up sell while they are doing the swap (suspension, brakes, ect) to make more money and help the swap go smoother. Sure the first few someone does will take longer but once they get in a rhythm they jam them out. I've seen a couple take 3-4 days. You do need 2 bays so it takes away from other work. The shop still makes money, while its not as good as customer pay, or extended warranty (3rd party) it's still money and your keeping your techs busy. They don't make money standing around.
  6. Jan 25, 2016 at 5:56 AM
    Skunkman
    Skunkman Well-Known Member
    Syracuse - Tug Hill
    2007 Tacoma Access Cab ,
    Hopefully I will be getting mine back today with a new frame. They got it a week ago, and put new lower control arms, brake lines, frame, and did a clutch job on it while there. It took a couple months for the frame to come in, and my local dealer has been very good about working with me. They had no Tacoma's as loaner vehicles, but he understood I needed a truck for work, and handed me a brand new 2016 Tacoma to use. My truck was lifted, had aftermarket parts, and an ARE topper on it, so I figured it would take longer than a couple days to get back. So far the only parts they tried to up-sell me was a front CV axle that had a bad boot. I put 100-200 miles a day on this truck and hope there are no surprises when it comes back.
  7. Jan 25, 2016 at 6:13 AM
    Gregoryk
    Gregoryk Well-Known Member
    Greg
    tri cities, TN
    05 SR5 4x4
    Had mine done in jc
  8. Jan 25, 2016 at 6:22 AM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Later I'll find the lawyers contact info that's handling a class action suit for the second gens. L
    Pick up the phone and call this attorney, he is litigating the second gen frame rot war.
    Ben Barnow
    Barnow and Associates, P.C.
    One North LaSalle Street, Suite 4600
    Chicago, Illinois 60002
    Tel: (312) 621-2000
    Paulita likes this.
  9. Jan 25, 2016 at 7:09 AM
    Darkhawk
    Darkhawk [OP] Member
    I would like to thank all of you for taking time out of your day to help a fellow Tacoma owner out. I am contacting a few sources before I escalate, because I still have hope that Toyota will make it right.
    However, this is my last attempt at a polite resolution. I am not the type of person who would file a lawsuit, but for the first time in my life I believe I might entertain the idea. I am a very patient man, but I refuse to roll over and play dead.
    I welcome any ideas as to what steps to take if I am left in the cold again.
    Old School likes this.
  10. Jan 25, 2016 at 7:14 AM
    oldtoyotaguy
    oldtoyotaguy Well-Known Member
    Peter
    Ontario, Canada
    2018 4 Runner ORP
    Stock but with a Warn 10s winch Used to be a lightly modded Tacoma
    Does anyone know the cost of a frame? Are they hard to get?
  11. Jan 25, 2016 at 7:17 AM
    Gregoryk
    Greg
    tri cities, TN
    05 SR5 4x4
    I had to wait a about 4 months irrc.
  12. Jan 25, 2016 at 7:17 AM
    Darkhawk
    I think Toyota cost is something like 12K for parts and labor. I remember reading in the frame rot thread, but I cannot remember exactly what it was. I do know that it is damn expensive.
  13. Jan 25, 2016 at 8:46 AM
    stbear
    stbear Well-Known Member
    SE PA
    2015 DCSB TRD Sport MGM
    Toyota recovered a large settlement from Dana who produced the defective frames. I don't remember how much it was and not sure if it was enough to cover all the costs.
  14. Jan 25, 2016 at 8:46 AM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    That was for the 95-2000 frames
  15. Jan 25, 2016 at 1:20 PM
    #35
    Darkhawk
    Yes, thanks to a salesman at Modern in Winston-Salem and a few other Toyota employees things are looking up.
    Modern Toyota contacted me and assured me that they would do everything in their power to get Toyota Corporate to stand by their product. If not, the dealer has to foot the bill which is what may happen.
    I also contacted my "home" dealership who also got on the phone to Toyota as well.
    I emailed Jim Lintz as advised by more than one member here.
    So, the ball is in their court.
    The first photo which is time-stamped before my inspection clearly shows a hole in the frame. There is no way to fake or damage the frame to mimic that sort of corrosion.
    However, I would like to believe that they made an honest mistake and I believe that they will stand behind their product.
    Ridgeline001 likes this.
  16. Jan 25, 2016 at 1:22 PM
    #36
    cynicalrider
    cynicalrider #NFG
    Jersey
    This is the part I am not understanding about your case. My 01 was fine in 2012 when it was inspected and coated per the TSB. In December even though my frame "passed" and was coated I found a hole from rot and am now getting a new frame because the warranty covered me for 15 years.
  17. Jan 25, 2016 at 1:53 PM
    #37
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    I have a 2gen manual so I guess someone is full of shite.
  18. Jan 25, 2016 at 2:00 PM
    #38
    george3
    New Jersey
    Is that 15 yrs from when new or when coated ? Thanks.
  19. Jan 25, 2016 at 3:23 PM
    #39
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    No dealership is going to cover that on their own expense. They will do what they can to get Toyota to except your claim but none will foot everything in hopes they will be reimbursed by Toyota
  20. Jan 25, 2016 at 3:26 PM
    #40
    Skunkman
    Syracuse - Tug Hill
    Dana settle with Toyota for 25 Million on the first gen. rot issues. They claim 110,000 trucks were affected between 1995-2000
