Frame rot got a passing grade.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Darkhawk, Jan 24, 2016.
  1. Jan 25, 2016 at 3:59 PM
    #41
    85GT 79FJ40
    85GT 79FJ40 Well-Known Member
    Ken
    New Hampshire
    19 TRD Sport DCSB 6M - 2017 Honda Africa Twin
    My understanding is the trucks are covered for 10 years under the TSB if uncoated. If it's inspected, passes, and is then coated they extend the original 10 years to 15. So if the truck is over 10 years and was never coated the OP could be on his own. In 1991 I bought an 84 Toyota pickup that had originally been owned by a construction company. 125k on it. The inside framerail on the passenger side was rotted from the rear spring hanger to the motor mount. I could stick my arm through the holes in the sides of the bed too. It happens here where they salt the roads, especially if you don't take care of them. It doesn't mean the truck is junk but if they don't cover it I hope he can weld. I've fixed far worse.
    Toyota has a very loyal following and I think they've handled this whole frame deal very well. Had this been one of the big three they would have told everyone to pound sand.
    Beaglesridefree and Lawfarin like this.
  2. Jan 25, 2016 at 4:11 PM
    #42
    oldtoyotaguy
    oldtoyotaguy Well-Known Member
    Peter
    Ontario, Canada
    2018 4 Runner ORP
    Stock but with a Warn 10s winch Used to be a lightly modded Tacoma
    Yes, I'm amazed that they replace frames. I agree with 85GT 79FJ40.
    Beaglesridefree likes this.
  3. Jan 25, 2016 at 4:22 PM
    #43
    oldtoyotaguy
    Peter
    Ontario, Canada
    2018 4 Runner ORP
    Just wondering, do the Toyota dealers in Canada replace frames under this program as well or is it just a US thing?
  4. Jan 25, 2016 at 4:22 PM
    #44
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Both
  5. Jan 25, 2016 at 4:23 PM
    #45
    OZ-T
    Peter North
    British Columbia
    The frame replacement program covers 2005-2008 trucks so far
    oldtoyotaguy likes this.
  6. Jan 25, 2016 at 4:29 PM
    #46
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    Cant believe they missed that. Most trucks with frame rot is in the same place, drivers side near the exhaust manifold, so you would think they would already know where to look...
  7. Jan 25, 2016 at 5:33 PM
    #47
    Darkhawk
    Darkhawk [OP] Member
    It was slightly behind the crust. You can see it in my first picture, but I'm sure you could miss it if you were in a hurry.
  8. Jan 25, 2016 at 5:58 PM
    #48
    OZ-T
    Peter North
    British Columbia
  9. Jan 25, 2016 at 6:06 PM
    #49
    sea nymph
    sea nymph Well-Known Member
    PA
    2005 DC Off Road SR5 4x4
    image.jpg I have my inspection this week!
    Here's a photo of mine in the same location. I can only see it getting worse so I hope it doesn't pass!
  10. Jan 25, 2016 at 6:10 PM
    #50
    OZ-T
    Peter North
    British Columbia
  11. Jan 26, 2016 at 7:20 AM
    #51
    cynicalrider
    cynicalrider #NFG
    Jersey
    15 years from new. It sounds like @Darkhawk's dealer has no idea what the hell they are doing.
  12. Jan 26, 2016 at 7:51 AM
    #52
    tgear.shead
    tgear.shead Well-Known Member
    The problem is that you're hitting the outside of the frame with the washer and oil, but the problem is on the inside. Look at your front cab mounts just behind your front wheels -- at the back of them is a BIG HOLE exposing the inside of the frame to the salt that sprays off the trailing edge of the front wheels. In other words, salt sprays STRAIGHT up into the frame, and RIGHT AT that spot where you have the rust through.
  13. Jan 26, 2016 at 5:09 PM
    #53
    Skunkman
    Skunkman Well-Known Member
    Syracuse - Tug Hill
    2007 Tacoma Access Cab ,
    They have had mine for nine days now....and called tonight to say she is ready in the morning. We'll see. Sure hate to give this 2016 back.
  14. Jan 26, 2016 at 5:15 PM
    #54
    amkaos
    amkaos Well-Known Member
    What are the differences with the new frames? Structural?
  15. Jan 26, 2016 at 5:17 PM
    #55
    OZ-T
    Peter North
    British Columbia
    They're not rusted
  16. Feb 4, 2016 at 8:14 PM
    #56
    96_taco
    96_taco Well-Known Member
    Clayton sandgren
    Northern va
    1996 Tacoma 2.7 4x4 extended cab
    33" bfg mud terrains, cold air intake, flowmaster with side exhaust, manual swapped, manual hub swapped, lifted on bilsteins
    If anything it would be lower than normal shop rate cause it would probably be billed as warranty.
  17. Feb 4, 2016 at 8:21 PM
    #57
    96_taco
    Clayton sandgren
    Northern va
    Yeah i would say it isn't necessarily the dealer giving you shit so much as their district rep not wanting to approve it. Their district rep has to show Toyota good numbers on warranty repair work (that they're not doing too much unnecessary warranty work) so that they can be better than the other dealers in the area. If that makes sense... I would go to a different dealership. Dealerships get paid for warranty work, though slightly less than normal a frame replacement is still big money for a service department to add to their monthly totals
  18. Feb 6, 2016 at 5:35 PM
    #58
    Redtaco704
    Redtaco704 Well-Known Member
    Jon
    Charlotte, NC
    05 DCSB 4x4
    Bilstein 5100's all around, Pro-Comp AAL, Pioneer in Dash DVD, Image Dynamics Component speakers, Custom 10" sub enclosure
    Did they pass or fail it?
  19. Feb 8, 2016 at 7:52 AM
    #59
    tgear.shead
    There are some structural differences, but the structural differences are for strength rather than rust mitigation. There were structural differences introduced in mid 2006 in the motor mount area, and more in 2009.
    In addition to structural differences, they are actually manufactured by a different company, and in a different country (Mexico). When Dana burnt themselves (by taking shortcuts on Tacoma frames), first the assets (including factory) were transferred to metalsa, then eventually metalsa moved production to Mexico, and much closer to the Toyota factory in San Antonio, which is where the frames would mostly have to end up anyway. The old frame factory was close to NUMMI where Tacoma *used* to be manufactured.
    On top of all that, frame preparations and coatings are changed now. One of the problems under Dana is that they didn't clean the oil off the uncoated frames properly before painting, which caused the coatings to not adhere properly. So a proper cleaning, plus a better paint, and hopefully longer lasting frames. Not to mention stronger.
    amkaos[QUOTED] likes this.
  20. Feb 8, 2016 at 8:00 AM
    #60
    amkaos
    That's what I'm talking about
