Frame rust prevention?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Wadezilla in ky, Aug 25, 2019.
  1. Aug 25, 2019 at 2:45 PM
    Wadezilla in ky
    Wadezilla in ky [OP] Member
    2000 tacoma sr5
    Anybody know how to keep my frame from rusting?? Tractor enamel??
  2. Aug 25, 2019 at 4:36 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    what area are you located?
  3. Aug 25, 2019 at 5:24 PM
    onakat
    onakat Well-Known Member
    Canada
    2000 indestructaco!
    4x4Taco2012, Xbeaus and taco57 like this.
  4. Aug 25, 2019 at 5:37 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    do you spray the fluid film all up inside the engine compartment everywhere?
    i had the battery removed today and there is large hole into the fender area
    maybe good to put some FF into that area and fill it up?
    and what happened to your paint job?
  5. Aug 25, 2019 at 6:18 PM
    Wadezilla in ky
    2000 tacoma sr5
    Im located in kentucky. My frame doesn't really have any rust.. but i dont want it to start its a 2000 sr5 with 137.000 miles.. what about dependability? This is my first import ever!! But i love this littile truck.. just not sure what to expect??
    GQ7227 likes this.
  6. Aug 25, 2019 at 6:26 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    If you can get the frame very clean and paint with POR15 that would be best. Then spray it every year with something like flood film. If you want the easier way just spray it every year in the fall with fluid film or woolwax and skip the grinding, sanding and painting.
    I spray my frame (inside and out), suspension, undercarriage, battery terminals, body ground bolts, axles, brake backing plates, sub frame, supports, the underside of the bed, back side of body panels, exposed sheet metal under the hood, shock towers, inside rockers and doors....everywhere that I can reach and then some.
    GQ7227 likes this.
  7. Aug 25, 2019 at 7:22 PM
    onakat
    Canada
    2000 indestructaco!
    yeah, it's not a bad idea to spray on the fenders, under the battery tray, the shocks mounts and what you can reach of the frame but don't spray on the engine, or else it will smoke
    as for the paint job, it's on it's way :oops: The whole bed is done and on primer, ready to be painted. They'll start working on the cab this week. Can't wait to get it back, it's going to be looking good!:thumbsup:
    GQ7227 likes this.
  8. Aug 25, 2019 at 7:25 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    i find it weird that the front skid seems to be non-corrosive in nature but that fuel tank shield/skid certainly is not!
  9. Aug 25, 2019 at 7:26 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2004 4x4 2.7L
    Wha? Looking back at your truck after the first ride with fresh fluid film and thinking your truck is on fire is the best part. Think the stuff smells bad going on? Try smelling it while it burns off the headers...
    onakat and pudge151 like this.
  10. Aug 25, 2019 at 7:28 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    bad smells?!
    i don't like the smell of bad smells!
  11. Aug 25, 2019 at 7:33 PM
    Littlemule1
    Littlemule1 Well-Known Member
    2015 SuperWhite Tacoma DCSB TRD Sport
    I like the smell of a fresh coat ff
    Silentshredr and pudge151 like this.
  12. Aug 25, 2019 at 7:35 PM
    Blue92
    Daniel
    North Carolina
    2004 4x4 2.7L
    It does grow on you. Although the truck doesnt go in the garage for atleast 3 days after a FF application.
  13. Aug 25, 2019 at 7:53 PM
    onakat
    Canada
    2000 indestructaco!
    yeah, it's weird I know. My gas tank skidplate was rusted to shit but not the front one
    Fluid Film does not smell very good but it sure does work against rust...
    GQ7227, taco57 and pudge151 like this.
  14. Aug 26, 2019 at 3:16 PM
    SStavin
    SStavin Active Member
    Dan
    01 Prerunner
    Iv'e gone through alot of these treads and fluid film seems to be the general consensus.
    Colchicine and pudge151 like this.
  15. Aug 26, 2019 at 4:58 PM
    Wadezilla in ky
    2000 tacoma sr5
    Thanks for your help yall fluid film it is..
    surfandturf likes this.
  16. Aug 26, 2019 at 5:01 PM
    Wadezilla in ky
    2000 tacoma sr5
    How much fluid film should i buy?
    GQ7227 likes this.
  17. Aug 26, 2019 at 9:36 PM
    pudge151
    Sean
    Connecticut
    You gonna go with aerosol cans or a spray gun and bulk material. I would say at least 6 spray cans but if you buy a gun and a gallon it'll be cheaper in the long run. I used about a gallon on my tundra but sprayed it everywhere and went heavy. I estimate it will take a half gallon per application from now on. If you buy gallons they are about $40 for fluid film and $50 for wool wax (woolwax is a little thicker and supposedly lasts longer) , and the gun is about $30 and it works great at about 80-100psi on my little pancake compressor.
    If you buy gallons, try advanced auto, autozone, O'Reilly's online, they always have coupons for online shopping. I just got 5 gallons for just over $100 using a 25% advanced auto online coupon, 10% discount code added to credit card, and 5% shopping at advanced auto via an app called ibotta.
    GQ7227 and Colchicine like this.
  18. Aug 27, 2019 at 5:37 AM
    Colchicine
    Colchicine Well-Known Member
    Newport News, Virginia
    | 2000 | 2.7L | 4x4 | Auto | Standard cab |
    I'm very interested in doing this, but I have to do it under a shade tree and as economical as reasonable. I couldn't find anything on a "soapy gun", but I did find this:
    https://www.amazon.com/TCP-Global-Proofing-Undercoating-Suction/dp/B07QR18BT7
    However, it requires 6+CFM and my 2HP 4gal air compressor can only do 4.4CFM @ 90PSI. You said your pancake compressor did just fine.
    FYI- Here's an Amazon link for a flexible wand attachment for the aerosol cans. Which makes me wonder if I really need a high CFM to spray Fluid Film...
    https://www.amazon.com/Fluid-Film-Spray-Extension-Wand/dp/B00CLUGXFI/
    GQ7227 and pudge151 like this.
  19. Aug 27, 2019 at 5:55 AM
    Blue92
    Daniel
    North Carolina
    2004 4x4 2.7L
    My front skid has a giant rust hole in it, and Im not even in the rust belt really. :notsure:
    I can do my truck with 4 cans and get a pretty even, medium to thick coverage. I only do the frame and crossmembers and the rear axle with it. I dont coat the underside of the cab or shoot it into door panels or anything as thats not really necessary where I live.
  20. Aug 27, 2019 at 8:31 AM
    pudge151
    Sean
    Connecticut
    Stupid auto correct. I meant to say spray gun, not soapy gun.
    And yes my little pancake compressor worked fine. I had it cranked up to 120psi. It ran pretty much the whole time but worked out just fine.
    Colchicine likes this.
