Frame rust recall
Discussion in '2nd Gen. Tacomas (2005-2015)' started by markey, Feb 14, 2013.
  1. Aug 31, 2015 at 9:12 AM
    #861
    hobiecat111629
    hobiecat111629 Well-Known Member
    2015 Tacoma Access Cab
    Too lazy to scroll through all 44 pages, but does anyone know if the 15s are already treated? I just bought mine the other night and am worried now. Not sure if I should go get it ziebarted or not with just 300 miles on it.
  2. Aug 31, 2015 at 9:19 AM
    #862
    ethompson02
    ethompson02 Well-Known Member
    Castle Rock, CO
    2017 TRD Off-Road Tacoma and 2018 TRD Off-Road 4Runner
    Tacoma - RCI Bed Rack, RCI IFS Skid Plate, RCI Rock Sliders, Odin Designs RTT, ICON Rebound Wheels, 275/70/17/ BGF KO2s, TRD Pro Grill, Prinsu Roof Rack, ARB 2500 Awning 4Runner - TRD Pro Wheels, 265/70/17 Duratracs
    I would be interested to know this as well! ^^^
  3. Aug 31, 2015 at 9:26 AM
    #863
    Mad Man Marty
    Mad Man Marty Well-Known Member
    Marty
    PA
    2007 Tacoma SR5 TRD Sport
    6speed, TRD intake, bed tie downs, weathertech rear,Tint
  4. Aug 31, 2015 at 9:41 AM
    #864
    danteisme
    danteisme Well-Known Member
    South Western PA
    06 DCSB Sport, 96 Integra GSR
    thanks for positng up that pic, i'll get that plug kit for sure.
  5. Aug 31, 2015 at 9:54 AM
    #865
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    Ok I'll take a stab at this - I'll give a very general response since all the info from Toyota and Dealers/ posters gets non specific - so please no Crap storm - but corrections appreciated if they have a reference to valid info.
    Frame MFG Dana made crappy frames and was successfully sued by Toyota for a couple? hundred million. Toyota made a change to Quality checks and changed manufacturing site (Dana went bankrupt?).
    Around 2010 Toyota made some frame changes - believed to be - Frame material composition (Steel) + process changes / final coatings. This is why the recall stops about 2009. Around 2013 I was told by my dealer that "additional" changes were made - and were increased " Frame material composition (Steel) + process changes / final coatings.
    IMO , 2010 + should be better for corrosion resistance and 2014+ even better. But to my knowledge there is no heavy coatings on the frames.
    Again, This is what I gleaned form the Forum and my dealers info.
    Edit - They also added in the Frame Plugs somewhere around 2011 or so. My 2012 came with the plugs.
    Jake1530 likes this.
  6. Aug 31, 2015 at 10:44 AM
    #866
    tgear.shead
    tgear.shead Well-Known Member
    Could you post pictures of the contents of that kit as well? i.e. open with the parts laid out to see what all is in it?
    Thanks.
  7. Aug 31, 2015 at 10:45 AM
    #867
    Mad Man Marty
    Marty
    PA
    Or maybe the '10 + haven't rusted yet.
    My "new" frame was put on last week,was made in Mexico,and look exactly the same as my rusted one.
    I am going to spray the boxed section with fluid film,and install the plugs.
    I would do the same if I had a '15.
  8. Aug 31, 2015 at 10:48 AM
    #868
    Mad Man Marty
    Marty
    PA
    Round,rectangle,bigger rectangle.
  9. Aug 31, 2015 at 10:52 AM
    #869
    tgear.shead
    Did it come with a manual that shows where they all go? Or is it matter of clipping it all onto wherever it can fit?
    Do yourself a favor, and look up into the front cab mounts with a flashlight. You will see that they are open to the inside of the frame. It would be a good idea to close that off, since road sludge will otherwise shoot off the tires and right up into and through the frame.
    If you look at the picture posted at #863, you can really see the relationship between the cab mount opening and the section where the worst rust happens.
  10. Aug 31, 2015 at 11:21 AM
    #870
    Mad Man Marty
    Marty
    PA
    no tgear.
    if u do a search for the tsb manual, #173?, it will show u all the locations.
    its the toyota manual for techs doing the spraying on frames.
  11. Aug 31, 2015 at 11:28 AM
    #871
    Canufixit
    New England
    I did the same to my 2012 which I bought new. Besides the Frame I used the small nozzle extensions/gun from FF and did up into every crevice I could get into underneath - Including the Bottom of the Doors, In the Rockers, door frame bottom sills, in the Rear Tailgate, etc. ...
  12. Aug 31, 2015 at 12:25 PM
    #872
    Mad Man Marty
    Marty
    PA
    I have the same Fix It. Its a great idea for all of us to do.
    Did u ever think of wrapping the exhaust with cool it wrap,where the exhaust comes close to the frame (see post #863)?
  13. Aug 31, 2015 at 12:29 PM
    #873
    tgear.shead
    That won't help, because heat is not the issue.
  14. Aug 31, 2015 at 12:43 PM
    #874
    Mad Man Marty
    Marty
    PA
    is it just dirt and salt getting into the holes?
    dont u think heat is playing a factor also? since that is the primary spot most frames rust?
  15. Aug 31, 2015 at 12:44 PM
    #875
    tgear.shead
    That is the primary spot, because that is the primary surface against which the sludge shoots in from the cab mount.
  16. Aug 31, 2015 at 1:33 PM
    #876
    danteisme
    South Western PA
    i havent crawled under my truck yet to look, how does the new chain spare tire holder work?
  17. Aug 31, 2015 at 1:48 PM
    #877
    balljoint
    balljoint Well-Known Member
    Dave
    Ontario
    '18 DCLB
    I believe that heat cycling definitely plays a part. In the same way that the dynamic stresses on the engine mount add to the rust problems at that point and increase the failure rate.
  18. Aug 31, 2015 at 2:01 PM
    #878
    aamin
    aamin New Member
    Amir
    05 Tacoma access cab 4x4
    hey, I have an 05 tacoma bought in NYC and shipped to south america a few years ago, do you know if I'd be covered for this recall?
    Thanks
  19. Sep 1, 2015 at 6:24 AM
    #879
    Mad Man Marty
    Marty
    PA
    Better call Toyota corporate.
  20. Sep 1, 2015 at 7:24 AM
    #880
    Canufixit
    New England
    How Would they know where the truck was prior to your frame inspection ???
