Frame rust recall
Discussion in '2nd Gen. Tacomas (2005-2015)' started by markey, Feb 14, 2013.
  1. Sep 30, 2015 at 12:57 PM
    #1001
    TXTaco13
    TXTaco13 Taco/T4R Enthusiast
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    The 2016 frames are the same, just "reinforced". The liability was absorbed both by Dana and Toyota, with Dana taking most of the responsibility, I believe. It's crazy to think that they would be running the same frame in the 2009+, but Toyota also let the shitty frames run for 13 YEARS prior to that. That is an interesting point about the 2016 frame. I never really thought about that possibility. The fact that the 2016 frame is "reinforced" and fits previous years, leads me to believe that they didn't make many changes to the prior frames, and have an available replacement already in a production run if the 2009+ rust out. If that is true, it just shows how much they cut corners.
    ^^^ THIS. I think BlueT is right on with the fact that the 2016 frame will fit the 2009+ if they rust out. Unbelievable.
  2. Sep 30, 2015 at 1:44 PM
    #1002
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    The issue with the frames is not Dana fault (at least not totally) there is a design/process problem here.
    The only changes Toyota did to improve rust protection was to include plastic plugs to cover holes in the frame at the front wheels. They did that after I started this thread
    https://www.tacomaworld.com/threads/winter-trick-to-help-protect-frame.128974/
    I started thread after I realized tires pack inside of the frame with salt and snow.
    Plugs help, but the paint process is the same which is what the real issue here is. Toyota is the only company, that makes frames to order. Frames are constructed from multiple pieces of metal sandwiched together and quickly painted with powder process before frame is sent to assembly manufacturing facility.
    Other companies make their frames with large continues beams a head of orders. Continues beams are better for powder coating and frame has more time to clean and cure since its not made to order.
    When you sandwich two sheets of metal, than weld them together, powder paint has no way to get in between. But over time moisture will find its way and rust from inside out (which is what happening)
    Sadly Toyota haven't changed that in 2016 trucks either. so those frames failures will continue.
    Big question is how many frames they going to replace before they call it a day. 2009+ guys have a real fight with Toyota in front of them unless you get some Eng to take a case and prove its a design failure like in the case of GM ignition.
    Oh so you know those mofos gave me a new frame but did not gave me plugs for the front of the frame to prevent snow packing inside ...back to aluminum tape again. :)
  3. Sep 30, 2015 at 4:55 PM
    #1003
    Huskerskier71
    Huskerskier71 Member
    07 Tacoma TRD Sport
    Has anybody on here in Utah had their frame inspected or replaced? If so what dealer did you use and how was your experience? I'm glad Utah was included in this recall because the roads here are extremely salted in the winter. You'd think there was an unlimited supply nearby the way they use that stuff! ;)
  4. Sep 30, 2015 at 5:43 PM
    #1004
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    Took mine in this morning and dropped it off for the inspection. It passed, got the undercoating, not sure how I feel about the undercoating and it's longevity.
  5. Sep 30, 2015 at 9:45 PM
    #1005
    fredgoodsell
    fredgoodsell Well-Known Member
    Salt Lake, UT
    2017 DC TRD OR
    Salt Lake City here. Failed inspection at Mark Miller, where I've had good service in the past. The service advisor told me it would be "average of $1500-2000 out of pocket for stuff they'll break while disassembling," and gave me a bad impression all around.
    Called Larry h miller the same day and even over the phone they were much more helpful and explained that most parts just take an authorization call to Toyota to get covered. Took my truck there and failed their inspection. Frame ordered. Told me three month wait, it's been one.
    Sandman614 likes this.
  6. Oct 1, 2015 at 4:52 AM
    #1006
    Huskerskier71
    07 Tacoma TRD Sport
    Thanks for the reply! I live closer to karl malone toyota so obviously it's more convenient but I got a gut feeling it will end up costing me if it fails based on past experience there. I actually bought my truck from larry h miller and the experience was good so I'll give them a shot.
  7. Oct 1, 2015 at 6:15 AM
    #1007
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    Sounds like Larry needs to be sent a box of Leeches .....
  8. Oct 1, 2015 at 3:01 PM
    #1008
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Do you realize...putting tape on those holes traps moisture inside the frame? ...and.... well, we all know what happens when you trap moisture inside frames.
    Stay out of the snow drifts, problem solved. ;)
  9. Oct 1, 2015 at 3:51 PM
    #1009
    BlueT
    NorthEast
    Covering holes at the wheels would lock moisture in the frame? Since I am not sure if you are serious, I am going think it was attempt at sarcasm.o_O
  10. Oct 1, 2015 at 5:41 PM
    #1010
    Canufixit
    New England
    :rofl:
  11. Oct 2, 2015 at 8:56 AM
    #1011
    Sampson90
    Sampson90 Well-Known Member
    Maryland
    2005 DC LB
    Got my truck back today. Took 4 days for the frame replacement, etc. Felt fine driving but I'll have to wait and see how it feels after a few weeks. Saw the Toyota Corp bill from the dealer for the replacement costs, including the rental for me, $12,483 !!! KBB value is $14,600 Just keep laughing about this one !!
  12. Oct 2, 2015 at 11:57 AM
    #1012
    BlueT
    NorthEast
    Thats how they roll, now they will spend another $3000 for leaf replacements, they should have bought all those trucks.
  13. Oct 2, 2015 at 4:10 PM
    #1013
    Janster
    Jandy
    Lancaster, PA
    ....and Toyota isn't loosing any money on this. They're not stupid. They're reaping the benefits of someone else's F-up and I'm sure there's insurance claims to cover the rest.
    They're not stupid and they've been in business for a long time. They wouldn't do it if it didn't benefit them in some way.
  14. Oct 2, 2015 at 5:32 PM
    #1014
    BlueT
    NorthEast
    I thought they took a write off on the loss when they issued recall. They did not got a lot from Dana Corp since they were in bankruptcy already. So most of that money has to be covered by Toyota. Even if they got some money for 2005-2008 they will get nothing for 2009+
  15. Oct 2, 2015 at 5:43 PM
    #1015
    NJ.TACOMAN
    NJ.TACOMAN Active Member
    New leaf springs were part of my frame replacement along with new brake lines, wire harness, lower control arms, spare tire carrier.
    I'm glad they didn't give me $15k for my truck instead. I could not replace it for that. Now I have a like new truck.... well except for the 145k miles on it !!!!! LOL
  16. Oct 2, 2015 at 5:48 PM
    #1016
    Canufixit
    New England
    With New Frames, Decent Body condition and Ability of these engines to go many Many miles, I wonder if / how many will hit a Million miles and still be running after who knows how many years ...
  17. Oct 3, 2015 at 4:05 AM
    #1017
    Janster
    Jandy
    Lancaster, PA
    Does anyone really & truly know what or how it went down? No...... You can't believe anything you read online. Only the Toyota suits and accounting folks know the bottom line. They wouldn't do it if they didn't see some sort of benefit.
    It was a warranty ..... Unlike a RECALL that is forced by government & NTSB.
  18. Oct 3, 2015 at 4:10 AM
    #1018
    Dagosa
    Dagosa Well-Known Member
    New England
    2015 Taco TRD OR
    Debaged
    Undercoating is false security. It hides more problems then it cures.
    Tacobajasr5 likes this.
  19. Oct 3, 2015 at 6:50 AM
    #1019
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    This is why I am hesitant about going in and getting the coating. My frame has surface rust but no holes right now.
  20. Oct 3, 2015 at 6:54 AM
    #1020
    Canufixit
    New England
    That's why I went with Fluid Film.
