Frame rust recall
Discussion in '2nd Gen. Tacomas (2005-2015)' started by markey, Feb 14, 2013.
  1. Jan 30, 2016 at 3:01 PM
    #1901
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    ^No light? That's interesting. If the mechanic simply forgot to plug in an electrical connector at the front diff or T-case, I would expect a flashing 4WD indicator light.
  2. Jan 30, 2016 at 3:37 PM
    #1902
    Fitz235
    Fitz235 Well-Known Member
    Rob
    New Hampshire
    Black '22 DCSB TRD Offroad 4WD
    - TRD T4R Pro Wheels - TRD Lift Kit - TRD Skid Plate - 265/70/17 Toyo Open Country 3's - OEM Bed Lights - OEM Bed mat - Alpharex Tail Lights - TacomaBeast LED Interior Lights - Green Lane Offroad Aluminum Sliders - Place Holder for More Bad Financial Decisions...
    All the talk of undercarriage washing, and Fluid Film is all well, and good (I haven't used Fluid Film, but have always run the truck through a wash that has an undercarriage sprayer), but the most common failure point is by the cats. This is the boxed section, and by all appearances, looks like it's rusting from the inside out. As far as I can tell, it looks to me like a drainage issue. I don't know if Fluid Film would have stopped this, as it appears to start on the inside of the boxed section. The majority of my old frame didn't look bad for a 10 year old truck, it failed because of the area by the cats.
    Is using Fluid Film a good idea? Sure. Not too sure it would have stopped this issue though.
  3. Jan 30, 2016 at 3:55 PM
    #1903
    JeffSags
    JeffSags Member
    Thanks Ken.
    Yeah I'm not sure if the 4WD just happened to crap out at exactly the same time the frame was done or it something wasn't properly reinstalled.
  4. Jan 30, 2016 at 9:01 PM
    #1904
    KenLyns
    Belly of the Beast
    Either drainage issue or the protective coating Toyota used inside the frame is not as good as the outside. In Oct 2014, I went to my local dealer and paid to have the inside of the frame sprayed with corrosion-protective compound. The mechanic used the same stuff as specified in the 1st-gen service campaign, minus the etchant. The mechanic used a thin hose with a spray nozzle attachment to reach inside the frame.
    Fitz235[QUOTED] likes this.
  5. Jan 30, 2016 at 9:16 PM
    #1905
    Beaglesridefree
    Beaglesridefree Well-Known Member
    2018 Tacoma DBL cab 4x4 TRD Sport, Premium and Tech Pkgs
    Fisrt, Welcome to the forum. I think you can be pretty certain that your 4WD problem is related to your frame install. Call your dealer ASAP to have them get it fixed. And please let us know the outcome.
  6. Jan 31, 2016 at 2:41 AM
    #1906
    Fitz235
    Rob
    New Hampshire
    Probably a combination of the two. Having the dealer coat the inside is not a bad idea, I may look into this myself for the new frame. Did they use paraffin wax, or something else?
  7. Jan 31, 2016 at 7:23 AM
    #1907
    Armkb
    Armkb Well-Known Member
    Hudson Valley, New York
    09 TRD Sport DCLB
    Bilstein 5100, OME 885X, LR UCA, ARB/EL095R, ES LCA Rack & Sway Bar Bushings, Yellow Wire Mod, ABS Switch, TPMS Mod, Scanguage, Toyota Bed Mat, WeatherTech Floor Liners, Extang Trifecta Cover, Fumoto Drain Valve
    I agree. I always garage my 09 but do not when it has been in rain. Leave it outside to dry then park in garage with a dehumidifier when needed. I spray yearly with mix of 30 weight oil and WD40 and have absolutely no rust. And yes I have checked behind the cats...nothing there. Granted I dont drive in snowstorms or when roads are drenched in brine....but do drive all winter in New York.
    Markcal[QUOTED] likes this.
  8. Jan 31, 2016 at 5:42 PM
    #1908
    sea nymph
    sea nymph Well-Known Member
    PA
    2005 DC Off Road SR5 4x4
    Update - dropped my Tacoma off at the dealer on Thursday 1-28. Unsafe to drive so I got a loaner. I'm told 4 to 6 month wait :notsure:! Offered a Corolla or Camry, but I need a truck. They didn't have any so they set me up with an F150 4 door. Nice job on the dealers part, however, I'm really taking a liking to the F150. I "stole" my Tacoma from the dealer today to wash the salt off and did not like the ride at all! Hoping that changes with the frame or else I might be in the market for a Ford!
  9. Feb 1, 2016 at 5:17 AM
    #1909
    cynicalrider
    cynicalrider #NFG
    Jersey
    I gotta say I had one too and really liked it. Way too big for me for a trail rig/dd which mine is but for just a dd work truck I gotta say the ford impressed me.
  10. Feb 1, 2016 at 6:00 AM
    #1910
    PSUnick
    PSUnick Lets Go State!
    MA
    2007 AC 4x4 Sport
    Dogaminator posted a scan of the dealer instructions for coating the frames. They are using NOX-RUST 712AM.
    I coated the inside of my frame with 3M Rust Fighter using an Astro Gun and 3M Application Wand, and got the plugs listed in the dealer instructions. Note there are some errors in that version of the instructions.
  11. Feb 1, 2016 at 7:02 AM
    #1911
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    I just realized that Toyota replaced my SPC LCA cam bolts with factory ones..bastards..Do I raise hell or let it go. I bought the SPC ones because they were cheaper than factory when mine were seized.
  12. Feb 1, 2016 at 7:17 AM
    #1912
    PSUnick
    MA
    2007 AC 4x4 Sport
    Sandman I can see bare metal spots on the welds of your frame. Mine has the same issue. These unpainted areas are going to rust.
  13. Feb 1, 2016 at 8:30 AM
    #1913
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    Yup. GM And Ford were my ride for many many years. Looked Great, Ride Nice UNTIL just a few years go by.... Then, Fender / door bottom rusting our, Bad F wheel bearings, Dealer continually said "that's normal" to many of the shimmy, shakes, noises. I had to beg for Warranty service!
    Not IF, But When there are a major issues - Toyota issues TSBs , Recalls, Limited Service fixes, etc. My 2012 is still better than my last GMC !!
  14. Feb 1, 2016 at 8:37 AM
    #1914
    Sandman614
    Tim
    '06 SR5 Off Road
    I'll have to look at that in person and see if it's just the lighting or not.
  15. Feb 1, 2016 at 2:31 PM
    #1915
    Fitz235
    Rob
    New Hampshire
    Cool man, thanks for the info.
  16. Feb 1, 2016 at 3:14 PM
    #1916
    wils5150
    wils5150 Member
    massachusetts
    08 access cab
    Just dropped my 08 off. They found some holes. 5 months to get a new frame WTF.
  17. Feb 1, 2016 at 3:22 PM
    #1917
    Fitz235
    Rob
    New Hampshire
    That's half as long as it took to get mine.
  18. Feb 1, 2016 at 3:25 PM
    #1918
    wils5150
    wils5150 Member
    massachusetts
    08 access cab
    damn wish i could trade it in
  19. Feb 1, 2016 at 3:26 PM
    #1919
    Fitz235
    Rob
    New Hampshire
    Why can't you?
  20. Feb 1, 2016 at 3:28 PM
    #1920
    wils5150
    wils5150 Member
    massachusetts
    08 access cab
    i assume i would take a beating on it!
