Frame rust
Discussion in '2nd Gen. Tacomas (2005-2015)' started by epeters, Oct 28, 2009.
  1. Oct 28, 2009 at 1:35 PM
    epeters
    epeters [OP] Member
    2008 TUCOMA 4 CYL. 5 SPEED
    2008 TUCOMA
    I HAVE RUST ON MY FRAME OPPISITE SIDE OF WHERE THE WELDS WERE DONE. ANOTHER WORDS ON THE BACK SIDE OF THE FRAME,
    HAS ANYONE NOTICED RUST ON THEIR FRAMES,
    I HAD TOYOTA LOOK AT IT AND THEY SAID THEY WOULD HAVE TO REFER IT TO LOCAL REP:eek:
  2. Oct 28, 2009 at 2:32 PM
    09sportowner
    09sportowner Well-Known Member
    Texas
    09 Sport
    where do you live?
  3. Oct 28, 2009 at 2:55 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    Damn man...rust on an 08? That didn't take long eh? wtf!!!
  4. Oct 28, 2009 at 3:19 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    I have a 2.7 08 access cab so I'd be interested in seeing pics of your rust problem. Curious George
  5. Oct 28, 2009 at 3:34 PM
    epeters
    epeters [OP] Member
    New York
  6. Oct 28, 2009 at 3:38 PM
    epeters
    epeters [OP] Member
    Pic's I will send asap
    I've done some checking on the internet. It appears there are others with rust problems.
  7. Oct 28, 2009 at 4:09 PM
    george3
    New Jersey
    Thanks
  8. Oct 28, 2009 at 4:29 PM
    09tacoLI
    09tacoLI Well-Known Member
    long island ny
    09 off road
    Shrockworks sliders,Shrockworks Front bumper,Warn 9.5xp winch,Toytec Ult.3in,Total Chaos UCAs,AP expo Rear, Fox remote resi shocks Bud built skids,Piaa 7in,Piaa yellow plasma Off road lights.
    :popcorn:I gotta see this.
  9. Oct 28, 2009 at 4:35 PM
    GTVAPSAMTIK
    GTVAPSAMTIK Well-Known Member
    SOHAIL
    Fort Carson, CO
    2010 TRD OFF-ROAD 4X4 Automatic
    EXTANG Tuff WeatherTech Liners Toyota Bed Mat Coverkind Seat Covers
    man you got me worried too. I just shelled all my savings on 2010 Tacoma TRD OFF ROAD. Possibly to see some pics and how bad is it. I love in middle of SNOW STORM. Fort Carson, CO.
  10. Oct 28, 2009 at 4:36 PM
    WNYTACOMA
    WNYTACOMA Well-Known Member
    Clarence, New York
    09 Metalic Grey TRD OFF ROAD
    Toyota Nerf steps Bugflector 2 Tool box Weathertech floor liners Wet Okole F/R - Bk/Char
    In New York with our salt use, did you have the frame treated before hand?
  11. Oct 28, 2009 at 4:43 PM
    mikedaz
    mikedaz Active Member
    NH.
    07 SR5 I4 4x4, access cab, 5 speed,
    bug deflector, vent guards, running boards ,stainless tip,summer + winter tires + wheels,secondary filter removed,60 series delta flowmaster,tow hitch,pop+lock
    I live in NH. They love the salt. I spray the frame and under body with hydraulic oil once a year, than run the dirt roads. Makes a good barrier against rust. I have an 07 and no rust.
  12. Oct 28, 2009 at 4:50 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    As far as treating the frame, what can be done? I didn't go for the undercoating because I've read that water can get trapped underneth it. Is there another service that sprays a rust inhibitor that someone could recommend that they've had good results with?
  13. Oct 29, 2009 at 2:27 PM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    Get a quart of normal ATF at the autoparts store. Thin it a little using some paint thinner and place it into one of those "pump up" pressurized sprayers. get under your truck and go to town on/inside the frame and cross members.
