Frame rusted through club
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BlueT, Jun 26, 2011.
  1. Jul 1, 2011 at 6:59 AM
    #141
    rjg
    rjg Yes
    RJ
    PA
    2007 Regular Cab 4x4 5 Spd 2.7
    LCE header, AFE filter, Blinglight Fogs, URD Short Shifter, Delay wipers
    Nice to live in a low road salt area! :)
  2. Jul 1, 2011 at 7:08 AM
    #142
    rjg
    rjg Yes
    RJ
    PA
    Yeah, winters up here are harsh on vehicles. Really it's all the crap used by the PA DOT. It's either rust, paint chipping and/or windshield damage from all the anti-skid/salt mixture used.
  3. Jul 1, 2011 at 7:14 AM
    #143
    wlmuncy
    wlmuncy Well-Known Member
    William
    Knoxville, TN
    2007 Double Cab Manual 4*4
    I do wonder one thing, is the purely an issue with Toyota truck, SUV, undercarriages or has anyone seen the same issues with corolla and camery undercarriages? I know this is a tacoma forum, but wonder if they have the same issues or do they have a different treatment for those vehicles.
  4. Jul 1, 2011 at 7:16 AM
    #144
    Burgman
    Burgman I KEEEEEL YOU
    Stephen
    Ric VA
    08 PreRunner TRD sport Silver
    K&N intake, Boston Acoustic SL 60 6.5 components up front, Rockford Power T16 6.5 in rear, Pioneer P4100 HU, Soon to be Pioneer Prs 4200f
    this is what im sayin wiscdave, even tho ur frame is rusting away and ur not doing anyhing about it, u still dont have pitted metal like the op and he only has the one spot. Im not a frame or rust specialist so i could he talking outta my ass but it seems strange to have one spot of rust soo advanced with no other rust present
  5. Jul 1, 2011 at 7:17 AM
    #145
    BlueT
    BlueT [OP] Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    We wanted to trade up wife's car to Sequoia but this is not gonna happen. With my second Toyota truck battling rust I think I am done. I won't sell the pickup but I will not buy Toyota car again either. Sequoia owners For now I am going to fill NHTSA report.
  6. Jul 1, 2011 at 7:37 AM
    #146
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    My wife has an 02 camry and its way better..but then again it doesn't have a frame. The LCA and rear wheel wells have slight surfase rust strarting to show. I had a DD - an old 94 GEO (coralla) that was in better shape than the 1st gens a couple years ago.
    That top part of the frame that is not completely boxed and has holes in it towards the front is the worst design.. It traps salt and it eats from the inside. I should have put oil or made sure it was treated right off the lot..3years later I'm screwed.
  7. Jul 1, 2011 at 8:40 AM
    #147
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    My splash guard came loose and it looks like I clipped it in the wrong hole, it should have been clipped in the hole to the left. Things would line up then.
  8. Jul 1, 2011 at 9:44 AM
    #148
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    Look at the bottom of wiscdave's cab sheetmetal... I think it's just frames that have this.
    Body panels (camry and corolla are unibody) are electro-galvanized for rust protection.
  9. Jul 1, 2011 at 9:52 AM
    #149
    wiscdave
    Northern Wisconsin
    Tundra Rock Warrior
    That's not my truck its a member named Nad
    I agree its the Frames and it hasn't changed yet.
    I've gotta take some pics of mine..its not bad yet cause I undercoated but the undercoating is flaking off in big pieces - Undercoating was done by Ziebart and has been touched up every year.
  10. Jul 1, 2011 at 1:31 PM
    #150
    Blackbear
    Blackbear Hardtooree Member
    Maine
    2008 Blk SR5 2.7 4X4 5 spd ACab
    (DIY)...Fog lights, alloys, wheelwell liners, tonneau, frame cleanup & rustproofing, floor mats, trailer hitch.
    BlueT, it's just a guess but the rust in your photo looks to be originating from outside the frame but inside the inner paint layer (that orange paint)...suggesting that it may have started by water somehow leaking in behind the paint and getting sealed/sitting in paint pockets/bubbles (i.e., not rusting from inside the frame to outside the frame). I've seen it happen on painted metal before, generally when the paint is applied very thick and either never got a good initial metal bond or simply expanded or contracted away sometime after application.
    I agree though, the metal used in Toyota truck frames seems quite poor and even reasonably good maintenance often isn't enough to prevent bad rust. The best that can be done is to put heavy doses of clean rinsewater on and through the frame (through the front boxed sections) during winter, and use paint + some kind of oil/wax coating to keep the metal sealed off as much as possible. BTW, many car washes recycle their rinse water...so what you are really doing at a car wash is rinsing with the salty water from cars that went through before you. Home rinsing with a hose is better...except for the crawling around on the ground part.
    For getting rustproofing inside the boxed sections of Taco frames I've found that a length of 12/3 electrical wire (with sheath still on for easier gripping), with a sponge soaked in oil/wax coating on the tip, makes a decent swab for treating inside the boxes. Messy, but seems effective. Buying a sprayer with nozzle extensions that can spray 360 degrees and reach the entire frame interior would be best...but somewhat pricey and even more messy.
    I'm about to make some wheel well skirts to reduce how much slush/water/mud can fly off the tires and onto the rear frame rails/spare tire supports/inside bumper (unlike cars, trucks have pretty open wells). Anything to keep water and crap contained in the wells until it can fall to the ground, instead of blowing all over the undercarriage.
    For you boys that don't have much/any experience in salt country, you may intend to be helpful but be careful about wearing the expert hat and assuming that you know the score when it comes to rust prevention in salt belt areas. No matter how much you read about it, unless you've actually lived/driven/suffered in it (and a few years ain't enough) you really can't imagine what it's like or know how to deal effectively with the rust thing. The how-to for snow belt rust prevention (including how often and how much) is definately a learned experience here.
    Happy swabbing.
  11. Jul 1, 2011 at 4:24 PM
    #151
    Syncros
    Syncros Well-Known Member
    The roads are salted and brined here every winter. My 06 gets minor surface rust in a few area's. I don't see what is so hard about getting under there with a wash brush and a hose once or twice a year, touch up with whatever paint/corrosion guard you prefer, I use marine products.
    It also rains 8-10 months a year here so there is plenty of fresh water on the roads that rinses the salt off after winter. Its almost not necessary to get under there and clean it but it looks nice.
  12. Jul 2, 2011 at 9:08 AM
    #152
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Now why can't there be more of you around here. :thumbsup:
  13. Jul 2, 2011 at 2:45 PM
    #153
    2008taco
    2008taco Well-Known Member
    chris
    san diego
    Because we live in the eminem age. This is the age where no body wants to take responsibility for their own actions, and looks for someone else to blame. Oh your kid is doing bad in school, must be those eminem records, couldn't be you, all you did was sit on the couch watching tv. You're morbidly obese, it's mcdonalds fault you can't stop eating. Your tires went bald and one blew out, it's toyota's fault for not having a light to remind you to change your tires. It is easier to point fingers than to take responsibility.
  14. Jul 2, 2011 at 3:28 PM
    #154
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    The factory frame paint is garbage , that's a fact Marshall .
  15. Jul 2, 2011 at 3:31 PM
    #155
    WNYTACOMA
    WNYTACOMA Well-Known Member
    Clarence, New York
    09 Metalic Grey TRD OFF ROAD
    Toyota Nerf steps Bugflector 2 Tool box Weathertech floor liners Wet Okole F/R - Bk/Char
    The no older than 3-4 year GMC Sierra frame i was next to in traffic today looked very similar to the o5 frame shots pictured above.
  16. Jul 2, 2011 at 3:33 PM
    #156
    brian
    Elizabeth City, NC
    Serious man... we all know that, we are NOT disputing that. That is not what him and I, or any other person on our side is saying..... what were saying is most of the guys know this, so why aren't they taking care of it. Thats all, and it irritates the hell outta me. That being said....
    When it cools off this summer, I'm doing an entire recoat in POR, just haven't had the motivation while I was in Cape Cod. Stuff is worth its weight in gold.
    http://www.por15.com/POR-15/productinfo/1GB/
  17. Jul 2, 2011 at 3:39 PM
    #157
    OZ-T
    Peter North
    British Columbia
    I agree , you should take care of your own vehicle , including cleaning , brushing and painting surface rust on your frame , I know I do , and will continue to do .
    What my problem is that if the factory frame paint is showing failure after 6 months , even if you do your best to stay on top of the areas you can see , you are fucked for the areas you can't see or get at .
  18. Jul 2, 2011 at 3:53 PM
    #158
    Dmonkey
    Dmonkey Well-Known Member
    Branden
    NorCal
    VZN159L (2002 DC)
    Eibach height adjust shocks in front, KYB monomax shocks in the back. Stock springs front and back. Level 8 MK6 10mm offset wheels on Cooper ATP tires (stock size)
    I'm not really sure why you're blaming a rapper when in fact the issue is this PC nanny state society we live in. You sound like an out of touch old guy when you say things like we live in the enimem age, the guy isn't even relevant anymore lol
  19. Jul 2, 2011 at 4:02 PM
    #159
    WNYTACOMA
    Clarence, New York
    To anyone with a clue, the schmuck never was relevant...
  20. Jul 2, 2011 at 4:05 PM
    #160
    Syncros
    Not sure! :p
