Free 1GR-FE Serpentine Belt Stickers
Discussion in '2nd Gen. Tacomas (2005-2015)' started by deanosaurus, Nov 15, 2022.
  1. Nov 15, 2022 at 9:21 AM
    deanosaurus
    deanosaurus [OP] Caveman
    Northeast Region
    09 TRD OR AC
    Hello.
    Is mailing away for cereal box prizes still a thing??? It is now. (Edit: Giveaway complete! Try again next time!)
    I had these 1GR-FE serpentine belt diagram stickers made using the graphics from some Toyota reference material. Toyota doesn't put these anywhere on our trucks for some reason, at least that I've seen.
    Check out this poorly centered and uncropped picture:
    I put mine on the inside of the hood where I could see it from under the truck with the hood popped. Some trucks have room on the inside front lip of the hood, others have indentations in the way. There's no "correct" placement so just do whatever. Wipe the spot clean as you can with alcohol or something before you stick it on and it'll last probably forever.
    They're pretty factory-looking. Not out of place at all.
    If you want one, send a self-addressed stamped envelope (S.A.S.E.) to:
    GIVEAWAY COMPLETE - TRY AGAIN NEXT TIME
    They are free while supplies last. I've given a couple away but there are probably close to a hundred left and have been rattling around my toolbox for too long.
    I'll update the thread when they're gone. If your S.A.S.E. is in the mail (postmark dated) before I run out but gets here after I run out, I'll send you a different, dumber and more colorful sticker instead.
    No need to PM - if you're not familiar with a S.A.S.E. giveaway, here's a link explaining them.
    (No need for the "bigger envelope" nonsense. Just fold up one regular first class envelope so it fits inside another.)
    As best as I can tell this follows the forum rules - there is no money changing hands here and I don't want there to be. I just think it would be fun to sprinkle these around the world.
    If you lurk any 4Runner forums, feel free to share the link to this thread - they have 1GR-FEs too.
  2. Nov 15, 2022 at 1:03 PM
    mikkydee
    mikkydee My Taco 2007 DCLB 4x4 Man Truck
    Doyle
    Florida
    2007 Silver DCLB Tacoma, 4X4, 4.0 Liter, 6" lift, 20" rims, 34" tires
    6" lift, 20 " inch rims, 34" tires, billet grill, aftermarket fender flares, custom rear bumper, DVd player with backup camera, all LED lights
    Wow, thanks bro! I'll get a envelope in the mail tomorrow :)
  3. Nov 15, 2022 at 2:43 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Nice gesture. But common guys, just print a copy, apply clear packaging tape and cut it. I have a copy in glove box and a pic in my phone. Also have printed diagrams in the garage to the cars I maintain, along with torque values and capacities to common maintenance procedures.
  4. Nov 15, 2022 at 2:49 PM
    General Chaos
    General Chaos I like pie.
    Joe
    NC
    2022 MGM Tacoma OR TRD 6MT
    As a non-mechanical guy..I was like:
    jackn7 and deanosaurus[OP] like this.
  5. Nov 18, 2022 at 11:40 AM
    JKD
    JKD Well-Known Member
    Two "Idler No. 2"? :D (But, still, nice resource)
  6. Nov 18, 2022 at 1:10 PM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    Saved it in my notes. Thanks man.
  7. Nov 18, 2022 at 9:00 PM
    TOMB
    TOMB Well-Known Member
    Tom
    Newington Ct. 06111
    2013 Access cab Sport -super white
    Changed all drain plugs to Dimple Magnetic plugs UNI filter on air pump
    Thank you for the offer.
    S.A.S.E. in the mail.
    TOMB
  8. Nov 19, 2022 at 3:33 AM
    deanosaurus
    Northeast Region
    09 TRD OR AC
    Yeah, it's actually in the technical documents that way. The only thing I can think of is part number differences? I don't recall them being different when I replaced my idlers, but I could be wrong.
  9. Nov 19, 2022 at 3:53 AM
    [KD]
    [KD] Used Import
    Dan
    Halifax, NS
    06 DCSB 6MT
    Correct (different part numbers)
    Rock Auto has them listed as upper and lower pulleys
  10. Nov 19, 2022 at 12:34 PM
    Chuy
    Lakeside, CA
    Silver Taco
    The bearing inside idler #1 pulley is twice as wide as the bearing inside idler #2. Matter of fact, when I replaced the bearings inside the pulleys, I pressed two of the idler #2 bearings into the #1 idler pulley because no one, not even Toyota, sold, or currently sells, the wide body bearing for the #1 idler pulley.
    eljedi68 likes this.
  11. Nov 19, 2022 at 2:10 PM
    deanosaurus
    Northeast Region
    09 TRD OR AC
    Do you have the old bearings? They should have a size stamped in them, almost always in the dust shield. There are a lot of supply houses out there and bearings are fairly standard size and spec.
  12. Nov 19, 2022 at 3:31 PM
    Chuy
    Lakeside, CA
    Silver Taco
    deanosaurus[OP] likes this.
  13. Nov 28, 2022 at 4:25 PM
    TOMB
    Tom
    Newington Ct. 06111
    @deanosaurus
    Thank you for the belt routing sticker, it arrived in today's mail.
    Nice quality!
    TOMB
  14. Nov 28, 2022 at 11:23 PM
    Chuy
    Lakeside, CA
    Silver Taco
  15. Dec 6, 2022 at 4:23 PM
    4xdog
    4xdog Well-Known Member
    Santa Fe, NM
    03 DC TRD OR, 15 DC TRD OR, 08 RX350, 62 TR3B
    Received. Thanks, @deanosaurus. Nicely done.
    I modified mine slightly with my corner-rounding punch to make it a little less likely to lift under the Tacoma's bonnet.
  16. Sep 9, 2023 at 1:06 PM
    deanosaurus
    Northeast Region
    09 TRD OR AC
    Just a reminder - this giveaway is still alive and well.
    hemitruk and TnShooter like this.
  17. Sep 11, 2023 at 7:20 AM
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    Cool idea.
    I'll get this in the mail today. Thanks!
  18. Dec 10, 2023 at 3:14 PM
    deanosaurus
    Northeast Region
    09 TRD OR AC
    Just a reminder that this is still a thing.
    YotaFAB and DesertRatliff like this.
  19. Dec 10, 2023 at 3:46 PM
    DesertRatliff
    Mt. Hood, OR
    Mas Tacos Por Favor
    I forgot to say thank you for mine. Thank you!! Nice, factory addition to the engine bays on our Tacomas.
  20. Dec 10, 2023 at 4:16 PM
    Williston
    Williston Well-Known Member
    New England
    2014 Tacoma 040 SR5 4x4 DC SB V6 AT5 Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter) OEM All-Weather floor mats (summer).
    Very nice of you to do this! Thank you. I did a screen-shot of your diagram, printed it out and put it in my owners manual for future reference.
