Free High Flow Bolt-In Cat for Headers
Discussion in '1st Gen Tacoma Parts Marketplace (1995-2004)' started by anthonytacoma, Apr 30, 2014.
  1. Apr 30, 2014 at 8:08 AM
    anthonytacoma
    anthonytacoma [OP] Well-Known Member
    FREE- pickup ONLY- Lake Forest, CA 92630
    I had this on my 2001 3.4L tacoma with JBA headers.
    It bolts to the header collector and the factory rear exhaust location
    Its a single High Flow Magnaflow Cat
    it also has a O2 bung welded in(I had an AFR gauge)
    You will need to go to your local autoparts store and get some gaskets, I don't have part numbers for you, i just would dig through their bins of gaskets.
  2. Apr 30, 2014 at 8:10 AM
    anthonytacoma
    You must have headers for this to work
  3. Apr 30, 2014 at 1:52 PM
    n0ms
    n0ms Well-Known Member
    Angel
    San Diego
    1st gen i4 single cab 4x4
    Celica seats, Icon in rear and front with icon ucas, omd leaf springs, deckplate mod, lce header, Tundra brake swap.
    Think it would work fine on my 4banger with LCE headers?
  4. Apr 30, 2014 at 2:39 PM
    anthonytacoma
    the ID of the pipe is 2", and the mounting flange is 4.25" center of hole to center of hole. i'm not sure what the LCE flange is, so you'd have to check.
  5. Apr 30, 2014 at 9:10 PM
    TacomaTRD4x402
    TacomaTRD4x402 Well-Known Member
    So Cal
    '02 Tacoma TRD 4WD 3.4 5spd S/C Long Travel
    I might be interested in this. I have the TRD headers. im a bit confused though. So your saying one end bolts right up to the headers flange? and the other to the muffler pipe flange? What about the 1st cat? My header flange comes down at an angle into the first cat. :confused:
  6. May 1, 2014 at 7:44 AM
    anthonytacoma
    Ya the JBA header mount is parallel to the ground, so this would NOT work for you.
  7. May 1, 2014 at 8:33 AM
    TacomaTRD4x402
    So Cal
    Gotcha, thanks
  8. May 1, 2014 at 11:30 AM
    chvymechanic
    chvymechanic Well-Known Member
    Thomas
    New Hampshire
    04 Limited TRD Off Road 4x4 Xtra Cab
    Stuff and Thangs
    Is that catalytic converter actually for a 1st gen? I'm pretty sure 1st gen headers don't eliminate the first cat.
  9. May 1, 2014 at 11:35 AM
    TacomaTRD4x402
    So Cal
    I still got both cats. Lookin to upgrade everything from the header flange to the muffler and o2 sensors.
  10. May 1, 2014 at 11:43 AM
    chvymechanic
    Thomas
    New Hampshire
    Stuff and Thangs
    I just got Doug Thorley headers and 2 new cats and that cat wouldn't work on my 04 with out the front cat.
