Free maintenance/ 1st oil change
Discussion in '2nd Gen. Tacomas (2005-2015)' started by moe1967, Jun 23, 2010.
  1. Jun 23, 2010 at 11:00 AM
    moe1967
    moe1967 [OP] Well-Known Member
    2010 TRD DC Off-Road PreRunner
    Went to dealership for my first "free" maintenance oil change, etc, and it says on the receipt that they used 5w-20 instead of 5w-30, I have a V6 :eek:
    Didn't realize this until I got home. I called the service dept and they said that is what is used in all oil changes and that my truck would be fine.
    Should I be concerned? Should I put the correct oil in?
    Thanks in advance
    I'm thinking i will ditch the "free maintenance" program
  2. Jun 23, 2010 at 11:02 AM
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    They should use what it says to use in the manual. 5w30 I believe.
  3. Jun 23, 2010 at 11:05 AM
    Brunes
    Brunes abides.
    Rotorhead
    Free maintainence - You get the quality you pay for. You are better off doing it yourself anyways.
  4. Jun 23, 2010 at 11:17 AM
    moe1967
    I concerned because i live in the bitchin' Louisiana heat
  5. Jun 23, 2010 at 11:24 AM
    BakoTruck
    BakoTruck Well-Known Member
    Herbie Hancock
    Bakersfield, CA
    05 PreRunner TRD
    Mostly stock for now, I have added a cb radio, various cheap mods and I plan on adding aftermarket wheels and other items in the future.
    X2! I didn't even take my truck in for a free oil change.
    Get some Mobil 1 5w-30, and put in.
  6. Jun 23, 2010 at 6:41 PM
    Primersinmyshoe
    Primersinmyshoe Old Sheepdog
    St. Louis, MO
    gray, shiny, dependable
    Glock 36, spare mag
    Crush washers??? Tall filters??? Do I just go to the Toyota parts desk and buy these?
  7. Jun 23, 2010 at 8:31 PM
    Hootbro
    Hootbro Omnipotent
    Delaware
    2009 Tacoma Regualr Cab 4x4 2.7L
    I repeat this warning on every thread I see with people calling out over-sized or tall filters while still in warranty. Using any filter that is not specifically cataloged to your application can be grounds for denying a warranty claim if said filter fails.
    Both the Toyota V6 and I4 in our trucks have deep sump capacities anyways and gain nothing by having a over-sized filter and the marginal increase in oil capacity. Mostly a placebo effect.
  8. Jun 24, 2010 at 2:44 AM
    TACOMA TRD
    TACOMA TRD Well-Known Member
    Tom
    PA
    2011 MGM SPORT DC 4x4
    Alpine HU, Apline 6.5 3 way Speakers, Access Cover.
    Good Point......
  9. Jun 24, 2010 at 5:02 AM
    moe1967
    The thought just occurred to me that those donkey dicks probably didn't adjust the tire pressure when they rotated my tires. I was right :-(
    I marked the tires before going to insure that they would rotate them correctly, which they did. But they failed to to adjust the tire pressure.
  10. Jun 24, 2010 at 6:03 AM
    Hootbro
    Hootbro Omnipotent
    Delaware
    Read what I said again. If it is cataloged, then you are fine. So if Toyota has thee different filters cataloged, then Toyota covers it.
    Problem mainly lies with people who go down to their local parts store and get filters like the PH3600 or Ford FL1A that offer larger capacity. If they do fail, Toyota will refer you regardless to the filter maker for restitution and the filter maker can deny claim for using the non cataloged filter for your application.
