free wheeling hub assembly
Discussion in '1st Gen. Tacomas (1995-2004)' started by bduane, Jun 26, 2012.
  1. Jun 26, 2012 at 5:52 AM
    bduane
    bduane [OP] Member
    Bernie
    Mn.
    '99 tacoma
    lift,wheels
    '99 tacoma's lockout on the pass. side will only turn 1/4 way.took off cover and found no snap ring or center bolt. is there a video showing how to disassemble the hub so i can see what all may be missing? can't seem to find one on line. got a break down from the chiltons manual but doesn't really show much. and can a person get just the snap ring and bolt? went to o'reileys auto and they can only get the whole hub for around $275.00. rather repair the one i have. thanx much,bernie:annoyed:
  2. Jun 26, 2012 at 6:14 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+295k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED), 2006 F350 King Ranch 6.0L
  3. Jun 26, 2012 at 11:09 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 v6 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch Diode Dynanics SS3 Sport Selective Yellow Fog Lights 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Doug Thorley Headers Magnaflow 18" Muffler w/upstream CAT delete 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Manual hubs?
    Only ADD equipped trucks have the lock nut on the end of the axle. On a manual hub setup there is no nut, only a spacer that slides over the splines and a snap ring to locate the axle. Those 2 pieces are a dealer item I believe.
    If your hub wont lock, sounds like a hub issue to me in spite of the missing snap ring.
  4. Jun 27, 2012 at 8:15 AM
    bduane
    bduane [OP] Member
    Bernie
    Mn.
    '99 tacoma
    lift,wheels
    thanx for the feedback. got it figured out. someone had taken it apart and put it back together wrong(the hub). good to go now. thanx again.:burnrubber:
