front 5100's
Discussion in 'Suspension' started by redtacoma, Oct 1, 2010.
  1. Oct 1, 2010 at 5:38 PM
    redtacoma
    redtacoma [OP] Member
    san diego
    06 tacoma crew cab
    i just bought my truck about a month ago.how can i tell if i have aftermarket springs i believe i do. i just got a 06 tacoma prerunner DC it has the billy's 5100" in front set at 0. with a 2inch spacer on top plate the tires i run are 285-65-18 with no rubbing and no trimming done to the inner fender wells. any ideas if i am correct on the aftermarket springs or i could use stock spring and clear tire size?
  2. Oct 1, 2010 at 7:48 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    If the spacer itsself it 2" thick then most likely your lift is solely accomplished by the spacer. The truck will be lifted by TWICE the thickness of the spacer due to how the suspension is set up.
    If your 285/65/18's aren't rubbing then you definitely have 3" or more of lift.
    as for the springs question, I don't think you have aftermarket, but just to check, what color are your springs?
  3. Oct 1, 2010 at 7:56 PM
    redtacoma
    san diego
    06 tacoma crew cab
    the springs are black
  4. Oct 1, 2010 at 7:58 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    yup than there probably stock...like mentioned up above, its your spacer thats giving you the lift :)
  5. Oct 1, 2010 at 7:58 PM
    TexasTacoma37
    Yeah, I think OME's are black as well, but I'm going to assume you have stock springs and your lift is solely due to the 2" top plate spacer.
  6. Oct 1, 2010 at 7:59 PM
    TexasTacoma37
    Great minds think alike Scott...beat me by seconds!
