Front and Rear Differential Fluids
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Coalie, Jan 23, 2021.
  1. Jan 24, 2021 at 8:51 AM
    elioregon
    elioregon Well-Known Member
    Eli
    2014 Tacoma 2.7L MT ACLB
  2. Jan 24, 2021 at 9:12 AM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    I just did this last weekend. Front diff and transfer case with Lucas 75-90. Rear diff with Lucas 75-140. My truck was banging loudly into and out of 4LO. Smooth as silk now. Last time I changed the fluid was 75 000 km ago.
  3. Jan 24, 2021 at 9:32 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
  4. Jan 24, 2021 at 11:08 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Probably the same reason some old guys still run 20w50 motor oil in their new truck...
  5. Jan 24, 2021 at 11:35 AM
    Boco10
    Boco10 Well-Known Member
    ADK
    I did my brothers 2009 on christmas morning. It was original oil and I almost puked when I opened the plug. I actually rolled truck out of the garage a bit to finish up. Ya that stuff is nasty. If you get some longer tubing you can kinda use a bottle like a IV.
  6. Jan 24, 2021 at 4:23 PM
    Sharpish
    Brian
  7. Jan 24, 2021 at 4:39 PM
    Gen2 Man
    Gen2 Man Well-Known Member
    Midwest
    07 Sport DCLB
    3rd Gen Sport wheels
    fixed it for you
    Delta09[QUOTED] likes this.
  8. Jan 24, 2021 at 4:39 PM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    Hahahahahahahaha I'm worried about your pinion...........bearings..............especially on frosty mornings. :D:rofl::p
  9. Jan 24, 2021 at 5:02 PM
    Sharpish
    Brian
    75 000 km on 75-140 and the magnet was clean and the oil still clear.
    ECGS is the most popular regearing vendor on this site and they mandate 85-140 in the front and rear diffs to maintain warranty, which is even thicker.
    It’s all academic bro, it makes a lot less difference than you’d like to think. You do you.
  10. Jan 24, 2021 at 5:10 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    :lalala::annoyed::goingcrazy:
  11. Jan 24, 2021 at 5:28 PM
    ABNFDC
    ABNFDC Well-Known Member
    Granite State
    2008 4WD Access Cab TRD OR "Rugged Trail"
    265/75/16 Wildpeaks, Dakar rear, HS 2.5" front coils
    because of this thread and realizing it has been about 50K miles since my last change, I decided to order some gear oil. 5 quarts of 75w-110, and 1 quart of 75w-90.
    Look back at my maintenance logs, I've changed gear oil 3 other times in the 3 boxes. I've never used the same combo twice. It's all close enough.
  12. Jan 25, 2021 at 4:14 AM
    12taco12
    12taco12 Well-Known Member
    rochester NY
    2012 TX Pro
    Billy 5100s OME 886 Billy remote resi 5125 rear General hd packs TImbren superbumps/flipkit Pelfrey steel full hoop front SOS bolt on sliders Baja squadron amber fogs Baja 20" bar Aux fuse panel and switches custom 10 sub box double din
    Amsoil severe gear 75-90
  13. Jan 25, 2021 at 5:57 AM
    Markcal
    Markcal Well-Known Member
    That is the one I use too, some people complain it takes forever but between going years between changing my gear oil and the fact it's so inexpensive that I bought another one just for when I do my steering fluid it's worth it to me.
  14. Jan 25, 2021 at 6:18 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
  15. Jan 25, 2021 at 7:00 PM
    #35
    Steve_P
    Steve_P Well-Known Member
    TN
    09 Tacoma SR5 4WD 4cyl
    The cult following of Lucas oil is funny; this is a company built solely on marketing. The founder is a truck driver; not anyone that knows anything about tribology.
    What auto manufacturer recommends 75W-140? I'm not aware of any. What is special in ECGS gears (that they don't manufacture) that requires this; but somehow no mass produced vehicle (AFAIK) specifies?
    A great business opportunity is to buy the supertech 75W-90 and relabel it as 75W-500. It'll sell. Because "it's an upgrade, it's better"
