Front and Rear measurements ?????
Discussion in '2nd Gen. Tacomas (2005-2015)' started by skistoy, Mar 8, 2011.
  1. Mar 8, 2011 at 6:17 PM
    skistoy
    skistoy [OP] Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    Question:
    Are the front and rear fender heights suppose to be equal when the truck is level?
    I ask because i see how often people are measuring these points
    to determine if their truck is level.
    Personally, i dont think the fender heights are equal when the truck is level.
    I look more toward the frame, and bed rails to see if truck is level.
    I have been wondering this for awhile, and want to get others impression.
  2. Mar 8, 2011 at 6:33 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    Rear is supposed to be higher. It will settle when loaded.
    If you dont load it and dont care , "leveling" kits bring them more together. You'll need to adjust your headlights though.
  3. Mar 8, 2011 at 7:01 PM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
  4. Mar 10, 2011 at 5:13 PM
    skistoy
    Western New York
    the reason i bring this up is i hear people saying there truck is level
    because their fender heights are the same.
    and to me that would really mean they are sitting nose high
  5. Mar 10, 2011 at 5:15 PM
    skistoy
    Western New York
    Im talking more about how do you determine if your truck sits level.
    not how to level your truck
    some use the fender heights.
    im saying that would be a wrong indication
  6. Mar 10, 2011 at 5:17 PM
    skistoy
    Western New York
    I gues what im really asking
    how do you determine if your truck sits level?
  7. Mar 10, 2011 at 5:25 PM
    raycie
    raycie Well-Known Member
    Oahu, HI
    16 T4R Trail
    In need of $$$
    Good question.. guess you could be on level ground, and put a magnetic level on the underside of the frame. But right there is where another problem lies.. Haven't found "true" level ground yet..
  8. Mar 10, 2011 at 5:31 PM
    Mr Salty
    Mr Salty "Give up the good to go for the great"
    Hermmy
    SoCal (Bro Capital of the world)
    White SR5 Pre-runner
    Lots of chrome
    I get what you are asking...
    I'd just take a level to the chassis and see what it tells you. Of course you would need the truck on level ground to begin with.
    The thing is why do you care?
    Most just care about the physical appearance and stance of the truck. Understanding that what appears to be a level shell doesn't necessarily equal a level chassis.
  9. Mar 10, 2011 at 5:36 PM
    skistoy
    Western New York
    i bring it up because so many give measurments , mostly from the fenders
    and if the fenders aren't equal when the truck is level
    then how do you determine it.
    im not losing any sleep over this, its just a interesting question
    how do you measure your truck being level, or noise high, etc ??
  10. Mar 10, 2011 at 5:38 PM
    skistoy
    Western New York
    I'll start a new thread
