Front axle
Discussion in '1st Gen. Tacomas (1995-2004)' started by livnlrn, May 11, 2012.
  1. May 11, 2012 at 1:09 PM
    livnlrn
    livnlrn [OP] Well-Known Member
    Rick
    Elkton, Virginia
    2009 TRD double cab
    Went to clean truck today & found grease all over the front drivers side shock. Grease is slung all over. Looks to be coming from axle boot. Would this be an axle seal?? I have never had one of these front ends apart before, so Im not sure what the problem is. Also, I can move the axle up & down a good bit, is this normal? The pass. side moves a little too.
  2. May 11, 2012 at 8:29 PM
    Brad H
    Brad H Well-Known Member
    Lisbon Falls, ME
    01 4x4 SR5
    Deck Plate, Marlin Crawler Rear Bumper, All-Pro APEX Front Bumper and Skids, Bilstein 5100s w/ Eibach Springs front, Wheelers 5Pak w/ OME, '01 Tundra Front Brakes, CBI Bolt-on Sliders, More to come
  3. May 11, 2012 at 11:08 PM
    valon5150
    valon5150 Well-Known Member
    Steven
    redding
    01 taco turd
    all pro lift, 33s, home made sliders, bumpers, skids
    CV fo sho. you can keep driving on it the cv's last surprisingly long with no grease. unless you want to re boot it. Then you should do it soon. i have kept my original torn ones for trail spares, and replaced with a oriellys cvs with lifetime warrantys.
  4. May 13, 2012 at 6:22 AM
    livnlrn
    Rick
    Elkton, Virginia
    2009 TRD double cab
    Thanks for the replys. I cleaned it up yesterday & found about an inch cut in the cv boot. Bought a new axle & had it fixed in less than an hour. Pretty easy job. Thanks again for the help guys.
