Front bed rail
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dbayarea, Oct 16, 2016.
  1. Oct 18, 2016 at 7:19 PM
    ajsabra
    ajsabra Fully locked 3rd gen
    Sin city
    2016 Tacoma DCSB 4X4 Manual
    Front suspension : Extended travel Kings with Total Chaos UCAS Rear suspension : Deaver progressive AAL w/out overload & Kings Rims : SCS SR8 17" Tires : Bfg KO2s 285/70/R17 ARB Compressor ARB Lockers front and rear with 4.88 gears Nitro 4.88 Gears TRD Pro Grill, and fogs Headlight BHLM Rigid Radiance 32 stealth mounted.
    Mine works fine with my OEM Tonneau I took the rail off my 2006 before I traded it in.
    CygnusX191 likes this.
  2. Nov 26, 2016 at 6:16 PM
    Lt_Dan
    Lt_Dan Well-Known Member
    Daniel
    Cincinnati OH
    2017 TRD OR 4x4 DCSB A/T Super White
    I just got a new 3rd gen Tacoma and i would like to install this front rail, how did you install it? did you have to do any drilling? Thanks in advance.
  3. Nov 26, 2016 at 6:26 PM
    007TRUCK
    007TRUCK Well-Known Member
    Genuine Toyota Accessories PT278-35100-BH Truck Bed Header Rail https://www.amazon.com/dp/B00DWVN9CK/ref=cm_sw_r_cp_api_ApKoyb1RZ4CBY
    So this is the front rail? And it fits fine with 3rd gen Tacoma with Tonneau cover? Mine is Extang Solid fold 2.0 on DCLBOR
    CygnusX191 and Lt_Dan like this.
  4. Nov 26, 2016 at 7:24 PM
    Ducman4x4
    Ducman4x4 Yusi The Yeti
    Ducman
    SoCal
    Suuuper Duuuper White
    Stuff for Mall Crawling
    No drilling required. Just unscrew and replace new bedrail
    Lt_Dan[QUOTED] likes this.
  5. Nov 26, 2016 at 8:34 PM
    Spare Parts
    Spare Parts Well-Known Member
    Southern Maine
    2022 Off Road Premium 4Runner Lunar Rock
    Mine went from an 09 to the 17, no issues at all. Would never have known it was not there until I went to use it, thanks TW for informing me.
  6. Nov 26, 2016 at 9:06 PM
    NorCalTommy
    NorCalTommy Active Member
    Tommy
    Sonoma, Ca
    2017 Tacoma TRD Off Road
    Glad I stumbled across this. My 2008 Tacoma had the front rail, and the 2017 doesn't. Ordered!
  7. Nov 26, 2016 at 10:09 PM
    dolooper
    dolooper Active Member
    2017 DCLB SR5 4x4, 2005 Pre-Runner AC, 1992 4Runner
    Anybody know if this works from all gen 2s? I'll swap out from my 2005 Prerunner to the 2017 if it does...
  8. Nov 27, 2016 at 5:38 AM
    Spare Parts
    Southern Maine
    From what I understand yes. Took mine from a 09
  9. Nov 28, 2016 at 4:41 AM
    gpb
    gpb Well-Known Member
    Atlanta
    2017 White DCSB TRDOR 4x4
    Check pricing with your local dealer. Mine was several dollars cheaper than that Amazon product listing.
    It fits with with the OEM tonneau cover. I don't know how the Extang is mounted so I can't say anything regarding that particular cover.
  10. Nov 28, 2016 at 6:03 AM
    Hank_Scorpio
    Hank_Scorpio Better keep the egghead. He might come in handy.
    JR
    San Antonio
    2016 BR SR5 DCSB 4X4
    Yes, the front rail for the 3rd gen is the exact same part used for the 2nd gen. There should be no drilling involved, just unscrew the existing bolts that are already there. They use a torx 30 head. Be careful not to strip the bolts. They are on there pretty tight, and I almost stripped one.
  11. Nov 28, 2016 at 7:14 AM
    neilbedwell
    neilbedwell Well-Known Member
    Neil
    Deep in the hills of Eastern KY
    2017 White Tacoma SR5 DCSB
    I managed to strip one of the bolts when I put the weatherstripping on for my tonneau. Anybody got a link or a part number where I could buy them?
  12. Nov 28, 2016 at 8:12 AM
    Sagebrush
    Sagebrush Well-Known Member
    Gens 1, 2, 3, and 4
    I pulled the rail from my 2007 Taco and stuck it on my '16. It's the same part.
    SB
    Spare Parts likes this.
  13. Nov 28, 2016 at 8:13 AM
    Sagebrush
    Gens 1, 2, 3, and 4
    I stripped the head–not the threads–in one of mine. I ran down to the hardware store and bought a stainless metric bolt. I don't recall the size.
    SB
  14. Aug 13, 2018 at 9:58 AM
    Robman
    Robman Well-Known Member
    Rob
    Hawaii
    '14 Tacoma Double Cab
    Sorry to bump an old thread but...for those of you that installed the header rail, do the nuts on the bed stay in place when you back out the bolts. I shined flashlight back there, it doesn't look like the nuts are being held in place by anything and i'm concerned that I wont be able to hold them in place when threading the bolts back in. Thanks in advance!
  15. Aug 13, 2018 at 10:15 AM
    #35
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I had no issues installing the one from my old 2015 onto my 2017
  16. Aug 13, 2018 at 6:08 PM
    #36
    jmauvais
    jmauvais Received 2 votes in a poll one time.
    NorCal
    2018 TRD OR 4x4 DCSB
    ...stuff
    Nuts won’t go anyway where. I installed and removed the front rail multiple times, never had an issue.
  17. Aug 14, 2018 at 9:58 AM
    #37
    Robman
    Rob
    Hawaii
    Thanks everyone!
    shakerhood likes this.
  18. Sep 5, 2018 at 7:44 PM
    #38
    wcoffman
    wcoffman Well-Known Member
    '18 TRD Sport DCLB 4x4 SuperWhite
    Fr pass door handle replace, Tyger step rails and soft bed cover, DDSS3 fogs, TRD skid, OR front tow hook, SokieTech hood struts, fr seat covers (neoprene), metal oil filter housing, magnetic oil plug, Cyclone under hood lights, Blue Sea Systems 5025 Fuse Block ST Blade 6 Circuit with Ground and Cover, Blue Sea Systems 60A DC Panel Mount circuit breaker.
    Installed the rail (PT278-35100-BH) and found the RockyMounts DriveShaft Track Locking Thru-Axle Mount wouldn't mount flush. Noticed the upper bed rail (square cross section; 65409-04010) mount isn't symmetrical so I took the rails off, flipped the upper bed rail around, and installed the rails again. The rail (PT278-35100-BH) now sits "proud" of the top rail and the RockyMount installs / functions as expected.
  19. Mar 31, 2019 at 6:37 PM
    #39
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Old thread, but useful. Have a replacement oem bedhead rail coming, mounting it on an 18 Sport, mounting maxtrax carrier mount as well this weekend (assuming everything g arrives on time).
    Every website that sells the bed Head rails claims they won't fit 3rd gen tacos, every thread on every forum says they will. TW ftw.
    Edit: it fits like a glove
    old man 895 and Chew like this.
  20. Sep 12, 2019 at 8:56 PM
    #40
    willongboarder
    willongboarder New Member
    The dealership was $10 cheaper than Amazon ($45).
    Thank you for the part number, the dealership needed that since 2019 doesn't recognize that bar.
    The torx 30's are tough to get off but they come, and the stock bolts are plenty long enough to put the front rail on.
    Factory tri fold tonneau fits finefand the little support piece on the front of the bed doesn't interfere with the rail.
