front brake upgrade?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Justyn98, Jun 13, 2017.
  1. Jun 13, 2017 at 7:06 PM
    Justyn98
    Justyn98 [OP] Well-Known Member
    Justyn
    West Virginia and Kentucky
    09 barcelona red tacoma trd sport DCSB
    Led pod fog light inserts, kn cold air intake, Bilstein 5100 with 2 inch coil combo and progressive AAL. Touchscreen pioneer stereo and infinity components with 2 kicker comp r10's and jones turbine exhaust
  2. Jun 13, 2017 at 7:22 PM
    JCL73
    JCL73 Well-Known Member
    Jay
    Spokane, WA
    06' Silver DBLB TRD sport, 4x4, auto
    I got a set about 7-8k ago, noticeably better, worth the $.
    Justyn98[OP] likes this.
  3. Jun 14, 2017 at 3:59 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
  4. Jun 14, 2017 at 5:48 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    150k on my OEMs and sticking with it
  5. Jun 14, 2017 at 8:30 AM
    BKinzey
    BKinzey Well-Known Member
    Beauford
    Hollywierd, CA
    2015 White Tacoma Access Cab TRD Off Road 4x4 V6
    RCI aluminum front skid, SnugTop, Sliders, bedside supports, LED interior, CaliRaised fogs & brackets, rear diff breather mod, DIY bed platform
    Drilled rotors are more for sports cars, depending on your driving, you can take advantage of slotted. Rotors that are slotted, drilled, or both will wear out your pads faster by a noticeable amount. Lots of opinions on aftermarket Vs OEM. Good luck.
    ETA:
    Swapping over to SS brake lines should make a noticeable improvement too.
  6. Jun 14, 2017 at 8:34 AM
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    Get whatever makes you feel good. They will work.
  7. Jun 14, 2017 at 8:37 AM
    Ryan_3TacosIn
    Ryan_3TacosIn Well-Known Member
    Houston, TX
    '02 XTRA Cab, 4x4, TRD- Working on Restore
    OME Shocks, 883 Coilovers, Synthetic Brake Lines, Dakar Leafs with AAL, Baja Rear Bumper; ES Body mount Bushings, Light Racing UCAs, American Racing Wheels w/ 33" Hercules Tires, and more to come...
    This is what I'm running, I have the powder coat red ones.
    ^^^This. You'll notice an immediate difference with these. This is one of those mod's you'll be saying "why didn't I do this sooner?"
    Make sure you have at least 16" wheels (so they actually fit) and make sure you get the backspacing right on 16's as well. You can see what I did here:
    https://www.tacomaworld.com/threads/ok-so-here-we-go.486087/page-3
    and
    https://www.tacomaworld.com/threads/now-that-is-a-conundrum.491648/
    Also, the stock banjo bolt you'll have to drill out (there is a thread on TW for that as well) or you can get the SS brake lines from Wheelers and not have to worry about it. Might as well do it since you're down there and it's only $90 bones. Just make sure you torque the banjo bolt to spec.
    There is a wheel fit guide you can find on TW that can help with this.
    ^^^This
    These are drilled and slotted... Just make sure you do the "break in" procedure so they don't warp later on down the line.
    Edit: Just saw you're running a second gen. I had them on a previously owned 2nd Gen and these pads/rotors and they stop like a sports car on a 2nd Gen. You'll be happy.
  8. Jun 14, 2017 at 8:44 AM
    Sae68
    Sae68 Well-Known Member
    JimS
    Stockton, CA
    05 FJ 4x4 PreRunner
    I just installed set of Wagner OEX pads and Centric premium rotors . I definitely feel the difference in stopping power.
  9. Jun 14, 2017 at 9:16 AM
    BKinzey
    Beauford
    Hollywierd, CA
    Yes they are. If one decides they don't need drilled and slotted, they can go with just slotted or an OEM type.
  10. Jun 14, 2017 at 10:29 AM
    Ryan_3TacosIn
    Houston, TX
    :thumbsup:
