Front brakes w/ 16" rims
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Chocolates, Aug 2, 2017.
  1. Aug 2, 2017 at 11:18 AM
    Chocolates
    Chocolates [OP] Well-Known Member
    Seattle or Bellingham
    05 DCLB
    Unicorns and glitter
    While I'd love to be able to go the route of the DIY big brake kit (see here), it appears that no one has successfully done it w/ 16" rims. Makes sense w/ the lack of space.
    Sure, it'd be nice to go to 17" rims, but that's costly :)
    I see a fair amount of people are starting to run the power stop k137 stuff now. I'm figuring that may be my best route as far as a possible upgrade at this point w/ 16" rims.
    Two questions:
    Any obvious front brake upgrades I may have overlooked?
    Anyone running slotted rotors, did you notice how fast they warped (compared to solid rotors) on our trucks?
    Thanks!
    GilbertOz likes this.
  2. Aug 2, 2017 at 11:19 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    I'm running EBC's Stage IV slotted rotor kit with their pads. Good stuff! Fits fine with my 16" wheels.
  3. Aug 2, 2017 at 11:25 AM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    Seems like there's more tire/wheel options with 17's. Some companies aren't even making tires for wheels smaller than 17's
  4. Aug 2, 2017 at 11:55 AM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    This. Next year I think I'm gonna get a set of 17s and mount up some 37x12.5x17s can't find anything in a 37 for a 16 that I like. As for the big brakes, that's on my list.
  5. Aug 2, 2017 at 12:56 PM
    Chocolates
    05 DCLB
    Sure. But looking specifically at 16" rim options :)
  6. Aug 2, 2017 at 12:57 PM
    Bebop
    Nick
    With big brake kit? Not happening bro.
  7. Mar 21, 2022 at 12:36 PM
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 84K miles
    FOX 2.5, Deavers, ARB, OTT, 4xInnovations
    I found a high-quality big brake kit that works with 16" OEM 6-lug wheels:
    https://sosperformance.com/products...-brake-kit-fits-17-plus-wheels-2005-21-tacoma
    On that page, in the drop-down options there's a selector for "TR323 Slotted Rotors - Fit 16" or larger wheels".
    I contacted rep from SOS Performance & he confirmed that this kit will work with 16" or larger wheels.
    I haven't ordered yet. If I do I will post a build/install update & review here.
    Side note: I called Wilwood's tech support dept. to see if there are any Wilwood options that would fit a 16" Tacoma 6-lug wheel. The tech I spoke with said, "That's a good question.." After a minute or two of going through his database he confirmed that as of this time (3/22/2022) there are no part#s / SKUs that would make it work.
  8. Mar 21, 2022 at 1:25 PM
    SliMbo4.0
    SliMbo4.0 Well-Known Member
    Rick
    Colorado Front Range
    07 Tacoma DCSB TRD offroad
    BP51, BAMF hangers, BruteForce HC, SCS, Vagabond Drifter
    I'm running Stoptech slotted rotors with sport pads on 16s and haven't had any issues. Installed 2020.
    NuckTrutz likes this.
  9. Mar 21, 2022 at 4:28 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    If you have 05 calipers that's the first thing to rebuild or replace then I have the powerstop drilled/slotted rotors with z36 pads and stops great. If you have stock 05 brake lines time for an upgrade and flush the system. Mine are stock TRD offroad 16" alloys beat up and will continue to be. No rotor warping. After 55k I replaced the powerstop complete front stuff could have gone up to maybe 70k but when I pulled it apart for the calipers just did them. Did the rears at 125k new pads and drums too but those don't do much braking but parking brake in mts is used (cable adjustment under the center console). Many posts on brake combos on site so good hunting.
