Front Bull Bar
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kahanabob, Mar 25, 2011.
  1. Mar 25, 2011 at 8:43 AM
    kahanabob
    kahanabob [OP] Well-Known Member
    Maui
    16 TRD 2WD 4DR
    If I put a bull bar on the front will the front impact air bag system still work?
  2. Mar 25, 2011 at 8:43 AM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
  3. Mar 25, 2011 at 9:11 AM
    novataco
    novataco Well-Known Member
    NOLA
    06 Sport V6 auto
    Aries bull bar, Lund grill screen, blackened h/l, Weathertech plastic all over, Access LE tonneau, window tint, tube steps, DF-Toy aux adapter, cig plug always on, console vault, hitch step, 1700 watt in-cab inverter and dual battery (in-progress), Delta bike hitch mounts
    That is actually a good question, as I had not thought of that. My Aeries bullbar, just like the Westin, is attached by only two bolts, not four, so it would pivot into the bumper in a crash. I guess the question is would it diminish the performance of the airbag system.
    It is attached to the bumper, so its a question of the mechanics of the airbag system and how its deployed. I am interested to hear who has knowledge about this.
  4. Mar 25, 2011 at 9:13 AM
    crf69
    Ohio
    ummm yeah
    the sensor is inertia triggered.
    a certain amount of energy is needed to blow the bag
  5. Mar 25, 2011 at 9:16 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    the air bags are not triggered buy hitting the bumper. There is a accelerometer in the truck that triggers the air bags when the truck comes to an instant stop the air bags are deployed. You can't go hitting bumpers with a baseball bat like the movies and set off air bags.
  6. Mar 25, 2011 at 10:09 AM
    anethema
    anethema Well-Known Member
    J
    Dawson Creek,BC
    08 TRD OR Access cab 4x4
    ARB Bumper,OEM Roof rack modded for access cab, Allpro Rock Sliders,Icon Adjustable coilovers,More Tie Downs in bed, Firestone Airbags in rear,Block heater
    1. A bull bar provides 0 protection to your truck in a crash. they are made of thin tubing and pivot from the bottom of the truck. They are essentially just for looks or maybe to mount a couple lights to. It will not affect anything since it will not do anything. If you rear end someone your bumper will still be doing the work of soaking that energy up.
    They also tend to cause more damage than if they were not there, since a ton of the force is where the bull bar is pressing into the bumper, rather then distributed over the entire crash contact area.
    2. All of the above would matter if it was a strain gauge based system. It isn't afaik. As mentioned about it measures G forces, and if your truck experiences enough negative G's in the proper direction, the airbags deploy.
