front bumper project
Discussion in '2nd Gen. Builds (2005-2015)' started by crazieN8, May 10, 2009.
  1. May 10, 2009 at 9:42 PM
    crazieN8
    crazieN8 [OP] ________________
    yorktown Va.
    95 4x4 taco
    3" lift, custom bucket seats, removable doors, KnN, eclipse sound system
    ^^^BEFORE^^^
    i picked up some 2 3/8" pipe, angle steel, & some other misc metal from the scrap yard for about 40$.
    only strong enough mount point is the factory hook locations, bought some stronger and longer bolts for about 14$
    not having a tube notcher sucked but i made due with a drill press both for the main verticle tubes and the small gussets
    i forgot to take some pics in between but as you can see with out a pipe bender it was all angles for this guy
    i figured i had plenty of extra metal so making an extra angle support made sense
    buddy of mine helpin with the final welding and cleanin up
    first coat, i primed as well
    yes im a noob welder
    two coats, used three cans, 7$ a piece
    installed and undergoing the high lift test
    passed and approved
    now for the rear bumper....................................
  2. May 10, 2009 at 9:46 PM
    allupinsydeyou
    allupinsydeyou Well-Known Member
    so cal / vegas
    v8 swapped yota. dyno tuned @ 400hp
    modified total chaos uppers and lowers... king coilovers, deaver leafs, full cage, 351w motor swap, etc..
    invest in a bender
  3. May 10, 2009 at 9:49 PM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    Not bad for custom.
  4. May 11, 2009 at 7:04 PM
    TheTacoManChach
    TheTacoManChach I AM THE GREAT CHACHOLIO!!!
    Brian
    Fayetteville, TX
    2006 Toyota Tacoma Double Cab Prerunner SR5
    Halo Headlights Black W/ LED LED TailLights Bermuda 3rd Brake Black Pioneer/Alpine System Debadge Entire Rebadge Driver Side Door Black Volant CAI Tool Box ARB Front Bumper Flat Black Painted Grill Surround
    Or Just a box of tiger disk
    if you clean up all those welds till their smoothe
    I think thatd really set it off.
    Good job though
  5. May 11, 2009 at 8:09 PM
    life11
    life11 Well-Known Member
    Tempe, AZ
    lifted 04 base V6
    Fabtech 3 inch lift, full magnaflow exhaust, 32 Inch toyo tires, 18 inch rims.
    thats a hella good job.
    i wish i had tha tools to do that!
